Home » Modeling » UML2 » Unable to read profile or model file programatically
Unable to read profile or model file programatically [message #471180] |
Thu, 01 March 2007 03:42  |
I'm using eclipse 3.2.1 with UML 2.0.2 and EMF 2.2.0, and have worked my
way through the tutorial 'Introduction to UML2 Profiles'
( http://dev.eclipse.org/viewcvs/indextools.cgi/uml2-home/docs /articles/Introduction_to_UML2_Profiles/article.html).
I have successfully generated a profile output file that is readable by
the eclipse profile editor, and have a model file that uses this profile
(also readable by eclipse UML editor). But as yet I am unable to read
either of these files from my test code.
Here's how I'm attempting to load the file(s):
ResourceSet RESOURCE_SET = new ResourceSetImpl();
Resource resource = RESOURCE_SET.getResource(uri, true);
package_ = (org.eclipse.uml2.uml.Package)
EcoreUtil.getObjectByType(
resource.getContents(),
UMLPackage.Literals.PACKAGE);
The return value is null for either the profile or for the model file URI.
Any help would be greatly appreciated.
Re: Unable to read profile or model file programatically [message #471345 is a reply to message #471184] |
Fri, 02 March 2007 09:21   |
Paul,
No, this code isn't correct; what you need to do, assuming you're running
stand-alone, is ensure the package, extension, and pathmaps are registered.
This source for the profiles article
( http://download.eclipse.org/modeling/mdt/uml2/downloads/arti cles/uml2.articles_200607181325.zip)
shows how to do this; alternatively, you could follow the advice in the FAQ
at
http://wiki.eclipse.org/index.php/MDT-UML2-FAQ#What.27s_requ ired_to_load_a_UML_.28.uml.29_resource_from_a_standalone_app lication.3F.
Kenn
"Paul Gribben" <paul.gribben@gmail.com> wrote in message
news:eea9d951de0b1834b2f35a0fe56db4ea$1@www.eclipse.org...
> Having looked through the source code for the UML2 plugin, I've managed to
> solve this problem as follows (although I'm not convinced it's the correct
> approach). The resourceSet object must be initialised in the following
> manner:
> EPackage.Registry ePackageRegistry = new
> EPackageRegistryImpl(EPackage.Registry.INSTANCE);
> ePackageRegistry.put(UML22UMLResource.UML2_METAMODEL_NS_URI,
> UMLPackage.eINSTANCE);
> ePackageRegistry.put("platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore ",
> ResourceSet resourceSet = new ResourceSetImpl();
> resourceSet.setPackageRegistry(ePackageRegistry);
Re: Unable to read profile or model file programatically [message #476704 is a reply to message #471345] |
Wed, 05 December 2007 09:41   |
When I use the technique described in the wiki (see code below) the
profile is always null.
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,UMLResource.Factory.I NSTANCE);
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
URI uri =
URI.createURI(" jar:file://Users/bertvh/Temp/eclipse/plugins/org.eclipse.uml 2.uml.resources_2.0.3.v200707131442.jar!/");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP),
uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP),
uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP),
uri.appendSegment("profiles").appendSegment(""));
Resource resource = resourceSet.getResource(URI.createFileURI(fileName),
true);
profile = (Profile) EcoreUtil.getObjectByType(resource.getContents(),
UMLPackage.Literals.PROFILE);
When I inspect the loaded resource (and toString() it) I see the
following (AnyTypeImpl !?);
org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@5a02ef (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@76b9ea (name: Profile)
(instanceClassName: null) etc...
The profile I try to load had been validated and applies to a model
succesfully. The first lines of the file are:
<uml:Profile xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_PXi8QJK5EdybSc66Lg43Vg" name="SimpleDistribution"
metaclassReference="_8PuhYJK5EdybSc66Lg43Vg">
<eAnnotations xmi:id="_EKkUMJK-EdyRQJafRUw19Q"
source="http://www.eclipse.org/uml2/2.0.0/UML">
etc..
Any ideas on what I'm doing wrong?
Many thanks,
Bert.
Kenn Hussey wrote:
> Paul,
> at
> Kenn
>> manner:
Re: Unable to read profile or model file programatically [message #476727 is a reply to message #476704] |
Mon, 10 December 2007 11:32  |
Hi Bert,
Have a look at the code in the
following..http://www.eclipse.org/modeling/mdt/uml2/docs/gui des/UML2_2.0_Migration_Guide/guide.html
in the section entitled: 'Programmatic Migration'. That should provide all
the details.
If that still doesn't work, please ask again.
- James.
"Bert Vanhooff" <bert.vanhooff@cs.kuleuven.be> wrote in message
news:4756B88A.40208@cs.kuleuven.be...
> URI uri =
> true);
> When I inspect the loaded resource (and toString() it) I see the following
> (AnyTypeImpl !?);
> etc..
> Many thanks,
> Bert.
> Kenn Hussey wrote:
>> Paul,
>> registered. This source for the profiles article
>> FAQ at
>> Kenn
>>> to solve this problem as follows (although I'm not convinced it's the
>>> correct approach). The resourceSet object must be initialised in the
>>> following manner:
Re: Unable to read profile or model file programatically [message #594039 is a reply to message #471180] |
Thu, 01 March 2007 03:57  |
manner:
Re: Unable to read profile or model file programatically [message #594105 is a reply to message #471184] |
Paul,
at
Kenn
> manner:
Re: Unable to read profile or model file programatically [message #625676 is a reply to message #471345] |
URI uri =
true);
etc..
Many thanks,
Bert.
Kenn Hussey wrote:
> Paul,
> at
> Kenn
>> manner:
Re: Unable to read profile or model file programatically [message #625700 is a reply to message #476704] |
Hi Bert,
the details.
- James.
> URI uri =
> true);
> (AnyTypeImpl !?);
> etc..
> Many thanks,
> Bert.
> Kenn Hussey wrote:
>> Paul,
>> FAQ at
>> Kenn
>>> following manner:
Current Time: Sun Aug 31 23:12:08 EDT 2025
Powered by FUDForum. Page generated in 0.06573 seconds
