Home » Modeling » UML2 » Complete Delete
Complete Delete [message #470956] Tue, 20 February 2007 11:56 Go to next message
I have created my own uml2 editor. When I delete an element from a model
it deletes everything under it accordingly. However, there are somethings
that get orphaned:
- applied stereotypes are not unapplied
- associations are not deleted
- when deleting an associations navigable properties are not deleted from
class elements
Is there already some utility code for handling this? I have started to
write code for doing this, but it is very verbose and I thought there
might be a better way.
Thanks!
Re: Complete Delete [message #470957 is a reply to message #470956] Tue, 20 February 2007 13:07 Go to previous messageGo to next message
John,
Element#destroy() will destroy the stereotype applications (and all
incoming/outgoing references). However, destruction of "indirectly" related
elements like associations of which navigable members end are part is
application-specific and thus something you'll need to provide your own
mechanism for...
Kenn
"John Gilbert" <jgilbert01@yahoo.com> wrote in message
news:9c3664a852dc982cd25f2652f04a0e5a$1@www.eclipse.org...
>I have created my own uml2 editor. When I delete an element from a model it
>deletes everything under it accordingly. However, there are somethings that
>get orphaned:
> class elements
> Thanks!
Re: Complete Delete [message #470958 is a reply to message #470957] Tue, 20 February 2007 14:15 Go to previous messageGo to next message
Hmmm. Even with the out of the box uml tree editor the stereotypes are not
unapplied on delete. They still show up at the bottom of the file when
opened with a text editor.
Any suggestions on a graceful way to handle the associations?
Re: Complete Delete [message #470959 is a reply to message #470958] Tue, 20 February 2007 22:53 Go to previous messageGo to next message
John,
Are you using the 'Element > Destroy' action? It should unapply the
stereotypes as well.
With respect to the associations, and other similar semantic relationships,
you could consider using the transaction functionality provided by EMFT and
register a post-commit listener that does this kind of clean-up when
transactions are closed...
Kenn
news:de67f9b6ba248edacd4b701f3504277e$1@www.eclipse.org...
Re: Complete Delete [message #470963 is a reply to message #470959] Wed, 21 February 2007 11:39 Go to previous messageGo to next message
Yes, Element/Destroy does do more than a simple right-click delete.
I will look into the transaction listeners.
Thanks.
Re: Complete Delete [message #470964 is a reply to message #470959] Wed, 21 February 2007 15:20 Go to previous message
Hi, Kenn, John,
Actually, that would be a pre-commit listener :-)
Post-commit listeners are not permitted to make changes to the model (though
they may read; they are invoked within read-only transactions).
Pre-commit listeners provide commands that will be executed before the
transaction commit completes. This is important, because these changes
also need to be validated by the transaction, and if necessary rolled back.
Christian
Kenn Hussey wrote:
> John,
> relationships, you could consider using the transaction functionality
> provided by EMFT and register a post-commit listener that does this kind
> of clean-up when transactions are closed...
<snip>
Re: Complete Delete [message #588947 is a reply to message #470956] Tue, 20 February 2007 13:07 Go to previous message
John,
mechanism for...
Kenn
>get orphaned:
> class elements
> Thanks!
Re: Complete Delete [message #588959 is a reply to message #470957] Tue, 20 February 2007 14:15 Go to previous message
Re: Complete Delete [message #588971 is a reply to message #470958] Tue, 20 February 2007 22:53 Go to previous message
John,
Kenn
Re: Complete Delete [message #589033 is a reply to message #470959] Wed, 21 February 2007 11:39 Go to previous message
Thanks.
Re: Complete Delete [message #589052 is a reply to message #470959] Wed, 21 February 2007 15:20 Go to previous message
Hi, Kenn, John,
Christian
Kenn Hussey wrote:
> John,
<snip>
Previous Topic:Inputs to StructuredActivityNode
Next Topic:GettingStartedWithUML source code
Current Time: Fri Jul 25 23:01:15 EDT 2025
Powered by FUDForum. Page generated in 0.19921 seconds
