Home » Modeling » UML2 Tools » Profile Stereotypes in the Editor Palette
Profile Stereotypes in the Editor Palette [message #470877] Mon, 28 May 2007 05:41 Go to next message
Originally posted by: cokoso.gmail.com
Hi, i'm using UML2Tools M7... I was wondering if I could edit the Editor
Palette to place some metaclasses stereotyped. I mean, when I use profile
I hace to create the respective metaclass an then stereotype this. I wish
to use the class stereotyped with my profile directly form the palette. Is
it possible?
thanks a lot,
octavio
Re: Profile Stereotypes in the Editor Palette [message #470882 is a reply to message #470877] Mon, 28 May 2007 07:34 Go to previous messageGo to next message
Hi octavio glorio!
Nothing is impossible with GMF =)
Step 1. Create new palette entry.
Add new palette entry to *.gmftool file. Then map this tool with metaclass
in *.gmfmap file. Regenerate diagram. UMLPaletteFactory will be modified to
sutisfy your conditions.
Step 2. Apply stereotype.
Modify doDefaultElementCreation() method in the appropriate $$CreateCommand.
You will have to add such a code:
newElement.applyStereotype(stereotype);
Voila!
Best wishes,
Tatiana.
"octavio glorio" <cokoso@gmail.com> wrote in message
news:e8180d7714287888e404f6a70d370aa0$1@www.eclipse.org...
> it possible? thanks a lot,
> octavio
Re: Profile Stereotypes in the Editor Palette [message #471118 is a reply to message #470882] Thu, 07 June 2007 11:42 Go to previous messageGo to next message
Hi Tatiana,
I used the GMF dashboard and a UML metamodel (ecore version) to generate a
new editor. Then i duplicate the metaclases needed in order to apply
stereotypes in the doDefaultElementCreation() method. But is not possible
to apply elegantly a stereotype at this level cause we are not dealing
with real uml elements.
With the experience that now I got I tried to reedit the UML2 class editor
of the uml tools plugin... But I have no luck, I extend the palette but is
impossible to link this new elements with the new create comand files (in
order to stereotype them). So my question is if there is a formal way to
extend the palette with new elements, of course, in order to stereotype
them in a future doDefaultElementCreation method.
thanks a lot,
octavio
Eclipse NewsPortal
Answereclipse.modeling.mdt.uml2toolsNewsgroups
Subject: Re: Profile Stereotypes in the Editor Palette
From: tatiana.fesenko@xxxxxxxxxxxx (Tatiana Fesenko)
Newsgroups: eclipse.modeling.mdt.uml2tools
Organization: Borland
Date: May 28 2007 06:34:50
Hi octavio glorio!
to
$$CreateCommand.
Re: Profile Stereotypes in the Editor Palette [message #471120 is a reply to message #471118] Fri, 08 June 2007 08:06 Go to previous messageGo to next message
Hi Octavio!
As I understand you have the following situation:
You have some model written in UML (*.profile.uml file), there are some
stereotypes in it. You have Uml2Tools functionality. And you want to extend
this UML2Tools. You want it to have some additional palette entries, these
palette entries should create stereotyped elements.
Is it right?
If so, it is possible, but it is not very simple. It deserves separate
article.
Anyway, can you give us more information.
Best wishes,
Tatiana.
"octavio glroio" <cokoso@gmail.com> wrote in message
news:caadfd5f7c31f76854165f3956f069fc$1@www.eclipse.org...
> Hi Tatiana,
> with real uml elements. With the experience that now I got I tried to
> reedit the UML2 class editor of the uml tools plugin... But I have no
> luck, I extend the palette but is impossible to link this new elements
> with the new create comand files (in order to stereotype them). So my
> question is if there is a formal way to extend the palette with new
> elements, of course, in order to stereotype them in a future
> thanks a lot,
> octavio
> Eclipse NewsPortal
> Hi octavio glorio!
> to sutisfy your conditions.
> $$CreateCommand. You will have to add such a code:
Re: Profile Stereotypes in the Editor Palette [message #471176 is a reply to message #471120] Tue, 19 June 2007 09:03 Go to previous messageGo to next message
Hi Tatiana,
I have a very good aproach now. I was able to create a palette with the
metaclases needed, I add a parameter to de NodeToolEntry to save the
corresponding stereotype and used it in the doDefaultElementCreation.
For the uploasd of the profile and the application I edit the
createDiagram method.
My actual problem is when I stereotype a package I don't see the << >>
quotes. For example when I stereotype a class I get in the upper zone of
the icone <<My Stereotype>>. Is possible to use this notation for the
metaclasses that I use? (class,package,property,associationclass,
association).
Thank you very much for your help, we are in contact.
Octavio
Re: Profile Stereotypes in the Editor Palette [message #471179 is a reply to message #471176] Tue, 19 June 2007 09:37 Go to previous messageGo to next message
Hi Octavio,
Congratulations!
Unfortunately, stereotyped element notation is supported only for classes
yet. Packages, Enumeration etc decoration is a part of #171261 [ClassD]
Support appiled stereotypes notation, which is open now. We hope to fix it
in the release. Sorry for inconviniences.
Best wishes,
Tatiana.
news:ea3cedfe088b669643ce2fb6dd08da2f$1@www.eclipse.org...
> Hi Tatiana,
> association).
> Octavio
Re: Profile Stereotypes in the Editor Palette [message #471219 is a reply to message #471179] Wed, 04 July 2007 09:24 Go to previous messageGo to next message
Originally posted by: nickkirtley.gmail.com
I also want to add stereotypes that extend referenced metaclasses to the
palette. Is this possible using the existing (component) editor of
uml2tools or is it necessary to define a new editor in gmf?
I don't understand exactly how Octavio solved this problem.
regards,
nick
Re: Profile Stereotypes in the Editor Palette [message #471250 is a reply to message #471219] Wed, 11 July 2007 04:52 Go to previous messageGo to next message
I am in the same boat as nick - can we have more detail on how we can do
this?
Andrew
Re: Profile Stereotypes in the Editor Palette [message #471326 is a reply to message #471250] Thu, 19 July 2007 08:59 Go to previous messageGo to next message
For palette extension using stereotypes from a profile do the following:
Load profile resource and apply profile in the initDiagram method at the
plugin start.
Edit the NodeToolEntry in the palette factory, add a parameter to save the
streotype needed to apply.
Now you add some extra tools in the fillpalette method, simply your copy
the code of the metaclasses that you need and set the parameter
"stereoype" with the streotype that you want.
Then intercept in the createdcommand the real creation of the element and
streotpe it using the parameter that you add to the node entry.
sorry for the late answer, let me know if you have problems
Re: Profile Stereotypes in the Editor Palette [message #471327 is a reply to message #471326] Thu, 19 July 2007 10:04 Go to previous messageGo to next message
I extend the umltools palette and add my node entries with my streotypes.
Now I was trying to export this new org.eclipse.uml2.diagram.clazz plugin
and used it at the same time the original plugin.
I export with another id, change some names and I get the following
problem... when my plugin was starting it couldn't create the umltypes
because they were create by the org.eclipse.uml2.diagram.clazz plugin
first . I decide to create new umltypes but now I get this last
problem.... I couldn't throw my streotyped elements from the palette
because the "not allow icon pointer" appeared in the diagram panel and any
new element is allow.
I think that maybe I have to edit the constraints that allow, or not, to
put an element in the diagram but I can't find this constraints!
Maybe the question is silly but I have spended some days with this
problem, je.
thanks again.
Re: Profile Stereotypes in the Editor Palette [message #473359 is a reply to message #471326] Mon, 03 March 2008 04:11 Go to previous messageGo to next message
Hi Octavio,
I'm very interested in your solution. Since I'm quite new to GMF
customization, I have problems to follow your instructions. Could you
please show us some code snippets/screenshots?
I believe that the issue we talk about here is a very common use case.
That is, to write a profile and then to provide an enhanced UML editor
for the profile users.
Stevy
> plugin start. Edit the NodeToolEntry in the palette factory, add a
> parameter to save the streotype needed to apply. Now you add some extra
> tools in the fillpalette method, simply your copy the code of the
> metaclasses that you need and set the parameter "stereoype" with the
> and streotpe it using the parameter that you add to the node entry.
Re: Profile Stereotypes in the Editor Palette [message #546851 is a reply to message #473359] Wed, 14 July 2010 08:53 Go to previous messageGo to next message
hi Octavio
I'm the same very interested in your solution
can you send me a toturiel of your solution because i'm new in gmf
this is my email: kamel_mbarek@hotmail.com
regards
Kamel
Re: Profile Stereotypes in the Editor Palette [message #553557 is a reply to message #546851] Tue, 17 August 2010 21:54 Go to previous messageGo to next message
Hi, we are students of computer engineering from Uruguay and we working in a project that consist in extending uml2tools, adding new diagrams, and tool palette, for a particular uml profile(with stereotypes,etc..).
We saw that you could do this.
Could you give us any orientation of how you achived this?
Our mails are:
apastorini@gmail.com
sofialc2@gmail.com
Thanks a lot!!!
Re: Profile Stereotypes in the Editor Palette [message #594842 is a reply to message #470877] Mon, 28 May 2007 07:34 Go to previous messageGo to next message
Hi octavio glorio!
Voila!
Best wishes,
Tatiana.
> octavio
Re: Profile Stereotypes in the Editor Palette [message #597594 is a reply to message #470882] Thu, 07 June 2007 11:42 Go to previous messageGo to next message
Hi Tatiana,
thanks a lot,
octavio
Eclipse NewsPortal
Hi octavio glorio!
to
$$CreateCommand.
Re: Profile Stereotypes in the Editor Palette [message #597599 is a reply to message #471118] Fri, 08 June 2007 08:06 Go to previous messageGo to next message
Hi Octavio!
Is it right?
article.
Best wishes,
Tatiana.
> Hi Tatiana,
> thanks a lot,
> octavio
> Eclipse NewsPortal
> Hi octavio glorio!
Re: Profile Stereotypes in the Editor Palette [message #600416 is a reply to message #471120] Tue, 19 June 2007 09:03 Go to previous messageGo to next message
Hi Tatiana,
association).
Octavio
Re: Profile Stereotypes in the Editor Palette [message #600428 is a reply to message #471176] Tue, 19 June 2007 09:37 Go to previous messageGo to next message
Hi Octavio,
Congratulations!
Best wishes,
Tatiana.
> Hi Tatiana,
> association).
> Octavio
Re: Profile Stereotypes in the Editor Palette [message #602136 is a reply to message #471179] Wed, 04 July 2007 09:24 Go to previous messageGo to next message
regards,
nick
Re: Profile Stereotypes in the Editor Palette [message #606402 is a reply to message #471219] Wed, 11 July 2007 04:52 Go to previous messageGo to next message
this?
Andrew
Re: Profile Stereotypes in the Editor Palette [message #606439 is a reply to message #471250] Thu, 19 July 2007 08:59 Go to previous messageGo to next message
plugin start.
Re: Profile Stereotypes in the Editor Palette [message #607457 is a reply to message #471326] Thu, 19 July 2007 10:04 Go to previous messageGo to next message
problem, je.
thanks again.
Re: Profile Stereotypes in the Editor Palette [message #618453 is a reply to message #471326] Mon, 03 March 2008 04:11 Go to previous messageGo to next message
Hi Octavio,
Stevy
Re: Profile Stereotypes in the Editor Palette [message #625830 is a reply to message #473359] Wed, 14 July 2010 08:53 Go to previous messageGo to next message
hi Octavio
this is my email: mailto:kamel_mbarek@hotmail.com
regards
Kamel
Re: Profile Stereotypes in the Editor Palette [message #625965 is a reply to message #625830] Tue, 17 August 2010 21:54 Go to previous message
Our mails are:
mailto:apastorini@gmail.com
mailto:sofialc2@gmail.com
Thanks a lot!!!
Previous Topic:Creating state machine, help please
Next Topic:Compile UML2TOOLS
Current Time: Tue Jul 22 23:59:32 EDT 2025
Powered by FUDForum. Page generated in 0.32556 seconds
