Home » Eclipse Projects » JavaServer Faces » Milestone 1 build + Tutorial posted..
Milestone 1 build + Tutorial posted.. [message #470667] Tue, 20 December 2005 01:45 Go to next message
The milestone build of the JSF Tools project is now available for download.
There is also a tutorial that will help you exercise the features in this build.
Both are available from the following link:
http://eclipse.org/webtools/jsf/dev_resource/index.html
Please review and post your feedback.
Raghu
Re: Milestone 1 build + Tutorial posted.. [message #470670 is a reply to message #470667] Tue, 20 December 2005 04:15 Go to previous messageGo to next message
Hi Raghu,
All images are missing...
Broken Images -
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/JSF Tools_milestone1_tutorial.html
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/new-dynamic-web-project.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/select-project-facets.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/jsf-capabilities.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/jsf-implementation-library.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/jsf-capabilities-library.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/project-explorer.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/new-jsp-page.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/jsp-page.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/run-jsf.png
http://eclipse.org/webtools/jsf/dev_resource/JSFTutorial/ima ges/jsf-app.png
Mvgr,
Martin
Raghu Srinivasan wrote:
> this build.
> Thanks
> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #470673 is a reply to message #470667] Tue, 20 December 2005 11:02 Go to previous messageGo to next message
I used the tutorial as best as I could, but ran into some problems.
First, I'm using MyFaces instead of the Sun RI JSF libraries. When tried
to run example, I get an exception stating that "Document is invalid: no
grammar found." I also get the same error, if I try to look at
faces-config.xml using faces console.
When I switched back to 1.1 DTD it worked fine.
I'm new to JSF, so I'm not sure, if this is an JSF Eclipse plug-in error
or Myfaces and Faces console problem.
Jeff Duska
> this build.
> Thanks
> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #470809 is a reply to message #470673] Tue, 20 December 2005 12:49 Go to previous messageGo to next message
Hi Jeff,
Can you please supply more details? Which JSF version did you choose (1.1
or 1.2)? Also, please list which jars did you included in your library.
Thanks for trying out M1!
Gerry Kessler
WTP JSF Tools Team
"Jeff Duska" <jduska@numbersix.com> wrote in message
news:do99uv$ah8$1@utils.eclipse.org...
> Regards,
> Jeff Duska
>> Hi,
>> download.
>> build.
>> Thanks
>> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #470811 is a reply to message #470809] Tue, 20 December 2005 14:35 Go to previous messageGo to next message
I successfully ran the tutorial's login.jsp page using MyFaces1.1.1 in a JSF
1.2 project with the following jars in the the JSF Library:
myfaces-all.jar
commons-collections-3.1.jar
commons-beanutils.jar
commons-beanutils-beans.jar
commons-beanutils-core.jar
commons-digester-1.7.jar
I was using Tomcat 5.5 with nothing in the shared libs folder.
Gerry Kessler
"Gerry Kessler" <gerry.kessler@oracle.com> wrote in message
news:do9g7p$jta$1@utils.eclipse.org...
> Hi Jeff,
> (1.1 or 1.2)? Also, please list which jars did you included in your
> library.
> Regards,
> Gerry Kessler
> WTP JSF Tools Team
>> Regards,
>> Jeff Duska
>>> Hi,
>>> download.
>>> this build.
>>> Thanks
>>> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #470813 is a reply to message #470670] Tue, 20 December 2005 14:52 Go to previous messageGo to next message
Sorry for the problem. The images have been repaired.
Gerry Kessler
WTP JSF Tools Team
"Martin van den Bemt" <mvdb@ibl-software.nl> wrote in message
news:do8i49$7ri$1@utils.eclipse.org...
> Hi Raghu,
> Broken Images -
> Mvgr,
> Martin
>> Hi,
>> download.
>> build.
>> Thanks
>> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #470814 is a reply to message #470673] Tue, 20 December 2005 15:44 Go to previous messageGo to next message
For now at least, until there are any JSF 1.2 implementations that we can
extensively test with, I'd suggest specifying v1.1 for your JSF version.
Since there are no JSF 1.2 implementations yet, I don't think this is going
to negatively impact anyone (am I wrong?). We'll be looking into this issue
further as we progress past our first milestone and as J2EE 5 and JSF 1.2
mature.
Ian Trimble (Oracle)
> Regards,
> Jeff Duska
>> Hi,
>> download.
>> this build.
>> Thanks
>> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #470822 is a reply to message #470813] Wed, 21 December 2005 03:35 Go to previous messageGo to next message
Thanx for fixing.. Apologies are not need though..
Mvgr,
Martin
> Regards,
> Gerry Kessler
> WTP JSF Tools Team
Re: Milestone 1 build + Tutorial posted.. [message #470823 is a reply to message #470811] Wed, 21 December 2005 03:37 Go to previous messageGo to next message
Try myfaces without the myfaces-all.jar and use the 3 seperate jars that
come with myfaces.. I thought there was an issue with the myfaces-all.jar
Mvgr,
Martin
> myfaces-all.jar
> Regards,
> Gerry Kessler
>>Hi Jeff,
>>library.
>>Regards,
>>Gerry Kessler
>>WTP JSF Tools Team
>>>Regards,
>>>Jeff Duska
>>>>Hi,
>>>>download.
>>>>this build.
>>>>Thanks
>>>>Raghu
Re: Milestone 1 build + Tutorial posted.. [message #470825 is a reply to message #470823] Wed, 21 December 2005 04:40 Go to previous message
Only in 1.1.0, there were some component related showstoppers in 1.1.0
all of them have been fixed in 1.1.1.
To my knowledge it wont make a difference.
Re: Milestone 1 build + Tutorial posted.. [message #578890 is a reply to message #470667] Tue, 20 December 2005 04:15 Go to previous message
Hi Raghu,
Broken Images -
Mvgr,
Martin
> this build.
> Thanks
> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #578926 is a reply to message #470667] Tue, 20 December 2005 11:02 Go to previous message
Jeff Duska
> this build.
> Thanks
> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #580246 is a reply to message #470673] Tue, 20 December 2005 12:49 Go to previous message
Hi Jeff,
Gerry Kessler
WTP JSF Tools Team
> Regards,
> Jeff Duska
>> Hi,
>> download.
>> build.
>> Thanks
>> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #580265 is a reply to message #470809] Tue, 20 December 2005 14:35 Go to previous message
myfaces-all.jar
Gerry Kessler
> Hi Jeff,
> library.
> Regards,
> Gerry Kessler
> WTP JSF Tools Team
>> Regards,
>> Jeff Duska
>>> Hi,
>>> download.
>>> this build.
>>> Thanks
>>> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #580288 is a reply to message #470670] Tue, 20 December 2005 14:52 Go to previous message
Gerry Kessler
WTP JSF Tools Team
> Hi Raghu,
> Broken Images -
> Mvgr,
> Martin
>> Hi,
>> download.
>> build.
>> Thanks
>> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #580300 is a reply to message #470673] Tue, 20 December 2005 15:44 Go to previous message
mature.
> Regards,
> Jeff Duska
>> Hi,
>> download.
>> this build.
>> Thanks
>> Raghu
Re: Milestone 1 build + Tutorial posted.. [message #580384 is a reply to message #470813] Wed, 21 December 2005 03:35 Go to previous message
Mvgr,
Martin
> Regards,
> Gerry Kessler
> WTP JSF Tools Team
Re: Milestone 1 build + Tutorial posted.. [message #580426 is a reply to message #470811] Wed, 21 December 2005 03:37 Go to previous message
Mvgr,
Martin
> myfaces-all.jar
> Regards,
> Gerry Kessler
>>Hi Jeff,
>>library.
>>Regards,
>>Gerry Kessler
>>WTP JSF Tools Team
>>>Regards,
>>>Jeff Duska
>>>>Hi,
>>>>download.
>>>>this build.
>>>>Thanks
>>>>Raghu
Re: Milestone 1 build + Tutorial posted.. [message #580446 is a reply to message #470823] Wed, 21 December 2005 04:40 Go to previous message
Previous Topic:run "WTP JSF Tools Tutorial" with requested resource is not available
Next Topic:run "WTP JSF Tools Tutorial" with requested resource is not available
Current Time: Wed Jul 23 00:43:12 EDT 2025
Powered by FUDForum. Page generated in 0.05914 seconds
