Home » Archived » AMW » Programmatically launching a composition: java.lang.reflect.InvocationTargetException
Programmatically launching a composition: java.lang.reflect.InvocationTargetException [message #470301] |
Sat, 27 June 2009 18:47  |
--------------050706060507030606020403
Content-Type: multipart/alternative;
boundary="------------000103090702000907050506"
--------------000103090702000907050506
Hi everybody,
I'm trying to launch a composition programmatically,
but can't get it right.
The composition works fine with the same models in a launch configuration.
I use the same metamodels (I register them in a plugin, and use them as
"uri:..") both in the launch configuration and the java transf.
I only don't register weaving metamodel , I use it locally for the
launch, and an exact copy of it in the plugin (I'm telling just in case
this affects somehow).
I also use a piece of code that works fine with ATL transformations
(based on
http://wiki.eclipse.org/JWT_Transformations#How_to_call_an_A TL_transformation_in_java_.28e.g._in_a_transformation_plugin .29
), but a little tweaked for loading the AMW models.
Some excerpts of my code follow.
To get the handlers, I write:
emfModelHandler = (AtlEMFModelHandler)
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
amwModelHandler = new AmwModelHandler(); // --> I DIDN'T FIND A STATIC
METHOD TO GET THE HANDLER!!.
I load the weaving metamodel (I use to load the metamodel as
ASMEMFModel, but it wasn't working, so I tried it this way) and the
weaving model as ASMAMWModels:
ASMAMWModel weavingModel = (ASMAMWModel) amwModelHandler.loadModel(
"SOMENAME", amwModelHandler.getMof(), "SOMEPATH"); //
---> SHOULD IT BE getAtl() ?? Doesn't work either
The rest of the (meta)models, as ASMEMFModels:
(ASMEMFModel) emfModelHandler.loadModel(...
and then launch as:
AtlLauncher.getDefault().launch(this.transfoResource,
Collections.EMPTY_MAP, models,
Collections.EMPTY_LIST, Collections.EMPTY_MAP);
Regretfully, when running this code, I get the attached exception (after
some tranformation's "print-to-screen debugging" comments).
Any ideas on the probable cause?, I guess I'm doing something wrong with
the handlers and/or the loading, but can't find any example code to base
mine on.
Thanks in advance and best regards,
Juan Pedro
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Hi everybody, <br>
programmatically, but can't get it right.<br>
configuration.<br>
"uri:..") both in the launch configuration and the java transf.<br>
this affects somehow).<br>
(based on <br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/JWT_Transformations#How_to_call_an_A TL_transformation_in_java_.28e.g._in_a_transformation_plugin .29"> http://wiki.eclipse.org/JWT_Transformations#How_to_call_an_A TL_transformation_in_java_.28e.g._in_a_transformation_plugin .29</a><br>
), but a little tweaked for loading the AMW models.<br>
<br>
Some excerpts of my code follow.<br>
To get the handlers, I write:<br>
<font face="Courier New, Courier, monospace"><br>
<font color="#009900">emfModelHandler = (AtlEMFModelHandler)
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);&nbs p;
<br>
STATIC METHOD TO GET THE HANDLER!!.</font></font><font color="#009900"><br>
</font><br>
weaving model as ASMAMWModels:<br>
<br>
<font color="#009900" face="Courier New, Courier, monospace">ASMAMWModel
weavingModel = (ASMAMWModel) amwModelHandler.loadModel(<br>
---> SHOULD IT BE getAtl() ?? Doesn't work either<br>
</font><br>
The rest of the (meta)models, as ASMEMFModels: <br>
<br>
<font color="#009900" face="Courier New, Courier, monospace">(ASMEMFModel)
emfModelHandler.loadModel(...<br>
</font><br>
and then launch as:<br>
<br>
<font color="#009900">AtlLauncher.getDefault().launch(this.transfoResource, <br>
Collections.EMPTY_MAP,<br>
Collections.EMPTY_LIST, Collections.EMPTY_MAP);<br>
<br>
<font color="#000000">Regretfully, when running this code, I get the
attached exception </font></font><font color="#009900"><font
color="#000000">(after some tranformation's "print-to-screen
debugging" comments).</font></font><br>
<font color="#009900"><font color="#000000">Any ideas on the probable
cause?, I guess I'm doing something wrong with the handlers and/or the
loading, but can't find any example code to base mine on.<br>
Thanks in advance and best regards,<br>
Juan Pedro<br>
<br>
</font></font><br>
</body>
</html>
--------------000103090702000907050506--
name="ProgrammAMWException.txt"
Content-Disposition: inline;
filename="ProgrammAMWException.txt"
GRAVE: ****** BEGIN Stack Trace
GRAVE: exception:
GRAVE: null
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:69)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.invok e(ASMEMFModelElement.java:683)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
at itecban.stras.sips.utils.AMWTransformationLauncher.iBuilderC ompSecureUML(AMWTransformationLauncher.java:205)
at itecban.stras.cheatsheets.sips.handlers.UML2iBuilderCommandH andler.execute(UML2iBuilderCommandHandler.java:53)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:619)
at org.eclipse.ui.menus.CommandContributionItem.access$10(Comma ndContributionItem.java:605)
at org.eclipse.ui.menus.CommandContributionItem$4.handleEvent(C ommandContributionItem.java:595)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getWovenAS MModel(ASMAMWModelElement.java:117)
at org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getReferre dElement(ASMAMWModelElement.java:192)
... 57 more
GRAVE: A.main() : ??#66 null
GRAVE: local variables = {self=weaving_tranfo_iBSecUML : ASMModule}
GRAVE: local stack = []
GRAVE: A.__matcher__() : ??#1 null
GRAVE: A.__matchnewAction() : ??#8 24:22-24:47
GRAVE: local variables = {attr=IN!FinancialDataDelete, self=weaving_tranfo_iBSecUML : ASMModule}
GRAVE: NativeOperation public static org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getReferre dElement(org.eclipse.m2m.atl.engine.vm.StackFrame,org.eclips e.m2m.atl.drivers.emf4atl.ASMEMFModelElement)
GRAVE: args = [IN!FinancialDataDelete]
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow continuation after errors).
GRAVE: null
java.lang.RuntimeException
at org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:87)
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:77)
Caused by: java.lang.reflect.InvocationTargetException
... 52 more
... 57 more
at itecban.stras.sips.utils.AMWTransformationLauncher.dispose(A MWTransformationLauncher.java:221)
at itecban.stras.sips.utils.AMWTransformationLauncher.iBuilderC ompSecureUML(AMWTransformationLauncher.java:211)
--------------050706060507030606020403--
Re: Programmatically launching a composition: java.lang.reflect.InvocationTargetException [message #470309 is a reply to message #470305] |
Fri, 03 July 2009 11:35   |
Thanks Marcos.
I won't be able to try just yet, because I may need to recompile my AMW
(my current version doesn't export the "transformation" package,
although I'm trying with just replacing the manifest file).
I was going to try to compile it for Galileo, but once again I face the
problem of the TCS dependency, and as ATL version changes quite a lot,
this time is not enough with the binary version you provided last time.
Juan Pedro
Marcos Didonet Del Fabro escribió:
> Hello,
> It is probably that the handler is not been registered correctly, so
> it cannot find methods such as "getReferredElement", which are part of
> the AMWModelHandler. If you do not call handler-specific methods, you
> may even use only the standard EMFModelHandler.
> You should get the handle this way:
> AtlModelHandler modelHandler =
> AtlModelHandler.getDefault(TransformationConstant.AMWModelHa ndler);
> Check the code of package org.eclipse.gmt.weaver.transformation.util.
> It has an example of transformations that are launched
> programmatically and that have weaving models as input and as output.
> http://dev.eclipse.org/viewsvn/index.cgi/plugins/trunk/org.e clipse.gmt.weaver.transformation/src/org/eclipse/gmt/weaver/ transformation/util/TransformationUtil.java?revision=12& root=Modeling_AMW&view=markup
> Regards,
> Marcos.
Current Time: Sun Jul 27 09:29:00 EDT 2025
Powered by FUDForum. Page generated in 0.04150 seconds
