Home » Modeling » Papyrus » Can EMFText be used inside Papyrus?
Can EMFText be used inside Papyrus? [message #470246] Wed, 03 June 2009 10:39 Go to next message
I know that in Papyrus it is possible to define certain "Effects" for a
given transition as an "OpaqueBehavior". When I define the body of this
"OpaqueBehavior", it can be added as a "Natural language".
I would like to know if it is possible to associate another type of
"Body" (defined by the user), e.g. an xUML-based action language, to the
list of possible bodies (besides "Natural language"). Moreover, would it
be possible to associate another Eclipse plugin, like EMFText
(http://st.inf.tu-dresden.de/reuseware/index.php/EMFText), to the box
containing the language "Body"? So that some automatic analysis of the
code being inserted can be done on the fly.
In other words, is it possible to extend the Papyrus tool this way? If
yes, what steps should I follow. Otherwise, can the tool be modified to
allow these extensions?
I think this approach would be very interesting because: (a) it allows
anyone to define a grammar for their desired (action) language; (b)
checking errors in this language would be detected on the fly (by
EMFText); (c) it would easily parse the language, generating the model for
the language (based on the meta-model of the language), making later
transformations easier.
Thanks in advance,
Osmar
Re: Can EMFText be used inside Papyrus? [message #470256 is a reply to message #470246] Wed, 24 June 2009 12:47 Go to previous messageGo to next message
Originally posted by: jendrik.johannes.tu-dresden.de
Hi Osmar,
I did some experimental integration of UML and Java using the EMFText
Java metamodel and syntax (JaMoPP). I never tested it in Papyrus, but
it's implemented in a generic way depending only on the UML and Java
metamodel. So it should work fine from Papyrus as well.
You can find it here:
http://emftext.org/index.php/EMFText_JaMoPP_Applications_jav aBehavior4UML
What I basically did was to define a new metamodel that imports UML and
the other language's metamodel (in my case Java). The metamodel contains
a class JavaMethodBehavior that inherits from UML Behavior. This way I
added a new behavior type.
I think what you want to achieve is similar. Only that you would use
another language instead of Java.
Jendrik
Osmar Marchi dos Santos wrote:
> for the language (based on the meta-model of the language), making later
> Thanks in advance,
> Osmar
Re: Can EMFText be used inside Papyrus? [message #470261 is a reply to message #470256] Wed, 15 July 2009 10:41 Go to previous messageGo to next message
Hi Jendrik,
Thanks a lot for your answer. It did help, specially in understanding
how I could possibly integrate Papyrus with EMFText.
But, maybe you can help me with another question. Specifically in
Papyrus, the "OpaqueBehavior" is edited using a "SourceViewer". By any
chance, would it be possible to associate an EMFText generated grammar
and its corresponding file to a SourceViewer, instead of a Workbench
Editor? That would certainly make things a lot easier.
Otherwise, I suppose, in order to integrate EMFText with Papyrus, one
would have to follow your idea. Nevertheless, Papyrus is built as a
MultiPage Editor. Therefore, by following what you said in the previous
post creates a new editor outside the Papyrus environment. In this case,
perhaps the Papyrus team could describe the possible steps needed to
create a new editing environment in Papyrus? This would then be
triggered by the user when one would like to edit an OpaqueBehavior.
Unfortunately, I haven't found any documentation about Papyrus'
source-code structure.
Best,
Osmar
Jendrik Johannes wrote:
> Hi Osmar,
> Cheers,
> Jendrik
>> Hi,
>> a given transition as an "OpaqueBehavior". When I define the body of
>> this "OpaqueBehavior", it can be added as a "Natural language".
>> the list of possible bodies (besides "Natural language"). Moreover,
>> would it be possible to associate another Eclipse plugin, like EMFText
>> If yes, what steps should I follow. Otherwise, can the tool be
>> modified to allow these extensions?
>> allows anyone to define a grammar for their desired (action) language;
>> (b) checking errors in this language would be detected on the fly (by
>> later transformations easier.
>> Thanks in advance,
>> Osmar
Re: Can EMFText be used inside Papyrus? [message #470263 is a reply to message #470261] Mon, 20 July 2009 09:03 Go to previous message
Hi Osmar,
The code that is generated by EMFText is independent of the UI tooling.
The EMFText editor is currently generic and not generated independently
for each language. I think a SourceViewer or a tab for a multi-page
editor could be implemented in a similar fashion. Although you might
loose some funktionality we currently inherit from Eclipse's TextEditor
implementation.
If you want to give it a try you should have a look at the Editor src:
http://svn-st.inf.tu-dresden.de/svn/reuseware/branches/emfte xt-1.1-jamopp-1.0-reuseware-0.9/EMFText/org.emftext.runtime. ui/src/org/emftext/runtime/ui/editor/EMFTextEditor.java
Jendrik
> Hi Jendrik,
> Best,
> Osmar
>> Hi Osmar,
>> and the other language's metamodel (in my case Java). The metamodel
>> contains a class JavaMethodBehavior that inherits from UML Behavior.
>> This way I added a new behavior type.
>> Cheers,
>> Jendrik
>>> Hi,
>>> for a given transition as an "OpaqueBehavior". When I define the body
>>> of this "OpaqueBehavior", it can be added as a "Natural language".
>>> EMFText (http://st.inf.tu-dresden.de/reuseware/index.php/EMFText), to
>>> the box containing the language "Body"? So that some automatic
>>> analysis of the code being inserted can be done on the fly.
>>> language; (b) checking errors in this language would be detected on
>>> the fly (by EMFText); (c) it would easily parse the language,
>>> generating the model for the language (based on the meta-model of the
>>> language), making later transformations easier.
>>> Thanks in advance,
>>> Osmar
Re: Can EMFText be used inside Papyrus? [message #586447 is a reply to message #470246] Wed, 24 June 2009 12:47 Go to previous message
Hi Osmar,
Jendrik
> Thanks in advance,
> Osmar
Re: Can EMFText be used inside Papyrus? [message #586513 is a reply to message #470256] Wed, 15 July 2009 10:41 Go to previous message
Hi Jendrik,
Best,
Osmar
> Hi Osmar,
> Cheers,
> Jendrik
>> Hi,
>> Thanks in advance,
>> Osmar
Re: Can EMFText be used inside Papyrus? [message #586555 is a reply to message #470261] Mon, 20 July 2009 09:03 Go to previous message
Hi Osmar,
implementation.
Jendrik
> Hi Jendrik,
> Best,
> Osmar
>> Hi Osmar,
>> Cheers,
>> Jendrik
>>> Hi,
>>> Thanks in advance,
>>> Osmar
Previous Topic:How to evaluate Eclipse Papyrus?
Next Topic:How to set the 'object' field of AddStructuralFeatureValueAction
Current Time: Sun Jul 27 11:54:11 EDT 2025
Powered by FUDForum. Page generated in 0.04524 seconds
