Home » Eclipse Projects » Platform - User Assistance (UA) » Disable cheat sheet in dialog tray?
Disable cheat sheet in dialog tray? [message #470139] Thu, 18 October 2007 14:15 Go to next message
Is there a way to *disable* the feature whereby a cheat sheet is moved to
the dialog tray when part of the cheat sheet involves opening a dialog?
Preferably within the cheat sheet XML itself? (Even more preferably, only
on specified platforms?)
We're trying to work around a bug on the Macintosh
(bugs.eclipse.org/bugs/show_bug.cgi?id=202534) in which the workbench gets
very confused when help is displayed in the dialog tray.
Any ideas would be welcome.
Doug Dirks
Re: Disable cheat sheet in dialog tray? [message #470158 is a reply to message #470139] Wed, 24 October 2007 12:05 Go to previous message
There is an attribute on an item called "dialog" which can be used to
turn off this behavior. The cheat sheet editor doesn't expose this so
you would have to edit the xml directly.
See
http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/reference/extension-points/cheatSheetContentFileSpec.h tml
Re: Disable cheat sheet in dialog tray? [message #589044 is a reply to message #470139] Wed, 24 October 2007 12:05 Go to previous message
See
Previous Topic:NLS Type
Next Topic:RCP application with remote help content only - can it avoid including jetty/jasper ?
Current Time: Fri Jul 25 21:29:42 EDT 2025
Powered by FUDForum. Page generated in 0.14300 seconds
