Home » Modeling » UML2 Tools » Changing Association End multiplicity
Re: Changing Association End multiplicity [message #469941 is a reply to message #469939] |
Sun, 25 March 2007 07:26   |
Hi Michael,
Thanks. The problem I'm having is selecting the multiplicity editor in the
first
place, as when you create the association they aren't there. Maybe this is
a bug as I guess it should show [0..1] by default? To get around this I am
having
to edit the property end's multiplicity in the browser and it is then
displaying in
the diagram.
How did you edit the multiplicity in your picture?
Andy
"Michael Golubev" <michael.golubev@borland.com> wrote in message
news:80ef434062a08c93b3cb87727e4@news.eclipse.org...
Hello ase,
There should be inplace editor at the both ends of the link (see
screenshot).
Complete notation from Spec v06-04-02 is supported, so there may be up to 3
labels at each side of the link.
However, text of any inplace editor should be the same, code should split
the entered text into different labels automatically.
Michael
> Is there a way to change the multiplicity of an association in the
> Class diagram editor. I can't seem to find one.
> Andy
Re: Changing Association End multiplicity [message #469942 is a reply to message #469941] |
Sun, 25 March 2007 07:43   |
Hello ase,
When association is created, it has at least 3 labels -- the centered one
with assoication name,
and pair of the roles labels at the both sides. By default, the roles are
set to "src" and "dst".
Try to invoke inplace for "src" label and enter text "src [2..*]" here.
It is expected that 2 labels will be created at this side of the link
-- one that shows "src" and another that shows just entered multiplicity
[2..*]
Note, that both of new labels share the same inplace, so would you select
"[2..*]" label and press F2 now,
the text in the editor should be "src [2..*]" -- the same as inplace for
"scr" label.
Just in case, try to invoke this inplace and enter "scr [2..*] {union}" --
there will be 3 labels (role, multiplicity and properties) at this side.
Again, all of them should share the same inplace editor, initialized with
complete association notation from 06-04-02.
Michael
> Hi Michael,
> the
> first
> this is
> I am
> having
> displaying in
> the diagram.
> Cheers,
> Andy
> Hello ase,
> screenshot).
> to 3
> split
> Regards,
> Michael
>> Thanks,
>> Andy
Re: Changing Association End multiplicity [message #469944 is a reply to message #469942] |
Mon, 26 March 2007 07:22  |
Thanks - that works very nicely.
Andy
news:80ef43406b188c93cfab395b00c@news.eclipse.org...
> Hello ase,
> with assoication name, and pair of the roles labels at the both sides. By
> default, the roles are set to "src" and "dst".
> Try to invoke inplace for "src" label and enter text "src [2..*]" here. It
> is expected that 2 labels will be created at this side of the link -- one
> that shows "src" and another that shows just entered multiplicity [2..*]
> "[2..*]" label and press F2 now, the text in the editor should be "src
> [2..*]" -- the same as inplace for "scr" label.
> Regards, Michael
>> Hi Michael,
>> the
>> first
>> this is
>> I am
>> having
>> displaying in
>> the diagram.
>> Cheers,
>> Andy
>> Hello ase,
>> screenshot).
>> to 3
>> split
>> Regards,
>> Michael
>>> Thanks,
>>> Andy
Re: Changing Association End multiplicity [message #584816 is a reply to message #469936] |
Fri, 23 March 2007 03:31  |
----++Omea_Parts_Splitter.523516766970752
Content-Type: text/plain; charset=koi8-r
Content-Transfer-Encoding: quoted-printable
Hello=20ase,
There=20should=20be=20inplace=20editor=20at=20the=20both=20e nds=20of=20the=20link=20(see=20screenshot)=2e
Complete=20notation=20from=20Spec=20v06-04-02=20is=20support ed,=20so=20there=20may=20be=20up=20to=203=20labels=20at=20ea ch=20side=20of=20the=20link=2e=20
However,=20text=20of=20any=20inplace=20editor=20should=20be= 20the=20same,=20code=20should=20split=20the=20entered=20text =20into=20different=20labels=20automatically=2e
Regards,=20
Michael
> =20Is=20there=20a=20way=20to=20change=20the=20multiplicity=2 0of=20an=20association=20in=20the
> =20Class=20diagram=20editor=2e=20I=20can't=20seem=20to=20fin d=20one=2e
>=20
>=20Thanks,
>=20
>=20Andy
>=20
Content-Type: image/x-png; name="mdt-classd-association.PNG"
Content-Disposition: attachment; filename="mdt-classd-association.PNG"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----++Omea_Parts_Splitter.523516766970752--
Re: Changing Association End multiplicity [message #584833 is a reply to message #469939] |
Hi Michael,
first
having
displaying in
the diagram.
Andy
Hello ase,
screenshot).
Michael
> Andy
Re: Changing Association End multiplicity [message #587245 is a reply to message #469941] |
Hello ase,
[2..*]
"scr" label.
Michael
> Hi Michael,
> the
> first
> this is
> I am
> having
> displaying in
> the diagram.
> Cheers,
> Andy
> Hello ase,
> screenshot).
> to 3
> split
> Regards,
> Michael
>> Thanks,
>> Andy
Re: Changing Association End multiplicity [message #587248 is a reply to message #469942] |
Andy
> Hello ase,
> Regards, Michael
>> Hi Michael,
>> the
>> first
>> this is
>> I am
>> having
>> displaying in
>> the diagram.
>> Cheers,
>> Andy
>> Hello ase,
>> screenshot).
>> to 3
>> split
>> Regards,
>> Michael
>>> Thanks,
>>> Andy
Current Time: Mon Jul 21 13:57:25 EDT 2025
Powered by FUDForum. Page generated in 0.04724 seconds
