Home » Eclipse Projects » Platform - User Assistance (UA) » Asked on eclipse_tw group: any product customization way to disable display of bread crumbs?
Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #469640] Fri, 14 September 2007 08:46 Go to next message
Originally posted by: nospam_kowalskilee.gmail.com
This question was posted to the eclipse_tw Yahoo group:
How to Disable Breadcrumbs
Posted by: "nfoengineer" nfoengineer@yahoo.com
Thu Sep 13, 2007 12:06 pm (PST)
My development team just moved to Eclipse 3.3 for an RCP application
that we are developing. What has happened to my help project is that
Eclipse has somehow dynamically injected code in my help that makes
breadcrumbs appear at the top of each help topic. I am told by my
development team that breadcrumbs is now a standard feature with
Eclipse 3.3 BUT they do not know how to turn it off. Is there anyone
out there who can help me (and my developers) to disable breadcrumbs?
I did a search for "bread crumbs" in the online Eclipse 3.3 help docs
found just one topic "Eclipse Platform What's New in 3.3".
I also scanned the "Product customization" topic for help and did not
spot a product customization for disabling the bread crumbs.
I also have searched Bugzilla and don't see an existing request for a
way to disable them either.
(Note: I like the bread crumbs. I'm just trying to find out what an
accurate response to the eclipse_tw posting is. :-)
Thanks!
--Lee Anne
To email me, remove the "nospam_" portion.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #469642 is a reply to message #469640] Fri, 14 September 2007 17:35 Go to previous messageGo to next message
We don't have a preference for this but here is one way to do it.
Find the file org.eclipse.help.webapp\advanced\breadcrumbs.css and
replace its contents with.
..help_breadcrumbs {
display: none;
Thanks! (was Re: Asked on eclipse_tw group: any product customization way to disable display of brea [message #469643 is a reply to message #469642] Sat, 15 September 2007 11:35 Go to previous messageGo to next message
Thanks Chris! I'll relay this to the original questioner.
> .help_breadcrumbs {
> display: none;
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #469663 is a reply to message #469642] Fri, 12 October 2007 13:23 Go to previous messageGo to next message
I have the same problem and would like to remove the default
breadcrumbs. While I like the breadcrumb feature, our docs team has
their own design and set of breadcrumbs they use so it is important to
them to be able to turn the default breadcrumbs off. Is this feature
planned for a future release?
In the interim, I tried the suggested solution and it didn't work for
me. I have org.eclipse.help.webapp_3.3.0.v20070607.jar and replaced the
contents of breadcrumbs.css as described below however they still show
up. Any idea what I might be doing wrong?
Thanks!
Dave
> .help_breadcrumbs {
> display: none;
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #469894 is a reply to message #469663] Mon, 15 October 2007 15:51 Go to previous messageGo to next message
I'm not sure why that didn't work for you. What OS/Browser are you
running on? I tried this on Windows XP using the built in browser which
uses IE.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #469928 is a reply to message #469894] Thu, 18 October 2007 12:49 Go to previous messageGo to next message
I'm using Windows XP and I had "Use external browser" preference
unchecked. I take that to mean that I am the built in browser. Is that
correct? Does Eclipse decide to use IE or does it use your system's
default browser?
I also tried switching to external browser and tried making Firefox
(2.0.0.7) and IE (7.0.5730.11) as my default browsers. I had the same
results. I have one coworker that also has XP and Firefox (2.0.0.7) and
sees the breadcrumbs.
However, running on the Mac with Safari (2.0.4 (419.3)) the breadcrumbs
do in fact go away as you describe.
-Dave
> uses IE.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #469929 is a reply to message #469928] Thu, 18 October 2007 13:25 Go to previous messageGo to next message
I just tried that on Windows XP and it worked for me, although I am
doing this from a checked out version of the webapp project rather than
editing a css file within a jar file. The Eclipse Browser on Windows XP
is a thin wrapper on top of IE so it shares most of the behavior with
IE, and therefore will have no problem handling display:none.
One possibility is that the old css file file has been cached by the
browser. If you have Firebug installed you will be able to see exactly
what css is being pulled in and that will probably enable you to get
things working.
> default browser?
> -Dave
>> which uses IE.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #470141 is a reply to message #469929] Thu, 18 October 2007 17:43 Go to previous messageGo to next message
Chris,
First, thank you very much for your help. I really appreciate it!
I'm a newbie to CSS and Firebug so I wasn't quite sure what to look for.
However, I was able to load breadcrumbs.css file in the browser with a
url: http://127.0.0.1:59634/help/advanced/breadcrumbs.css
It shows the expected contents, yet I still see the breadcrumbs in the
help docs.
> .help_breadcrumbs {
> display: none;
So it seems to my newbie mind :) that the proper css file is being used
by my browser.
-Dave
> things working.
>> default browser?
>> and sees the breadcrumbs.
>> -Dave
>>> which uses IE.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #470142 is a reply to message #470141] Thu, 18 October 2007 19:18 Go to previous messageGo to next message
Firebug is an extension to Firefox which enables you to debug the HTML
and CSS among other things. If you have Firefox installed Tools/Add
ons/Get Extensions will take you to a page where you can search for
FireBug. Once there you can expand the frames till you can see what file
is getting loaded. I believe that for some the modified version of
breadcrumbs.css is not getting loaded but I have no idea why.
Dave Pace wrote:
> Chris,
> help docs.
> > .help_breadcrumbs {
> > display: none;
> by my browser.
> -Dave
Re: Asked on eclipse_tw group: any product customization way to disable display [message #472433 is a reply to message #469642] Fri, 04 April 2008 05:52 Go to previous messageGo to next message
Chris
I've tried turning off breadcrumbs using your suggestion below.
Oddly, this successfully hides breadcrumbs for the Eclipse Workbench User
Guide and the JDT User Guide. But it does not hide them for my own doc
plug-ins.
Have you any idea why this might be?
> Find the file org.eclipse.help.webappadvancedbreadcrumbs.css and
> display: none;
Re: Asked on eclipse_tw group: any product customization way to disable display [message #472518 is a reply to message #472433] Mon, 07 April 2008 15:07 Go to previous message
I'm not sure why that would be, you may need to open help in an external
browser and save the html for your page and then inspect the html to see
if there is some reason why the CSS does not seem to be taking effect.
David Porter wrote:
> Chris
> User Guide and the JDT User Guide. But it does not hide them for my own
> doc plug-ins.
> Thanks
>> display: none;
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #576810 is a reply to message #469640] Fri, 14 September 2007 17:35 Go to previous message
display: none;
Thanks! (was Re: Asked on eclipse_tw group: any product customization way to disable display of brea [message #576854 is a reply to message #469642] Sat, 15 September 2007 11:35 Go to previous message
> .help_breadcrumbs {
> display: none;
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #586283 is a reply to message #469642] Fri, 12 October 2007 13:23 Go to previous message
Thanks!
Dave
> .help_breadcrumbs {
> display: none;
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #588625 is a reply to message #469663] Mon, 15 October 2007 15:51 Go to previous message
uses IE.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #588757 is a reply to message #469894] Thu, 18 October 2007 12:49 Go to previous message
default browser?
-Dave
> uses IE.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #588761 is a reply to message #469928] Thu, 18 October 2007 13:25 Go to previous message
things working.
> default browser?
> -Dave
>> which uses IE.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #588949 is a reply to message #469929] Thu, 18 October 2007 17:43 Go to previous message
Chris,
help docs.
> .help_breadcrumbs {
> display: none;
by my browser.
-Dave
> things working.
>> default browser?
>> -Dave
>>> which uses IE.
Re: Asked on eclipse_tw group: any product customization way to disable display of bread crumbs? [message #588958 is a reply to message #470141] Thu, 18 October 2007 19:18 Go to previous message
Dave Pace wrote:
> Chris,
> help docs.
> > .help_breadcrumbs {
> > display: none;
> by my browser.
> -Dave
Re: Asked on eclipse_tw group: any product customization way to disable display [message #611106 is a reply to message #469642] Fri, 04 April 2008 05:52 Go to previous message
Chris
plug-ins.
> display: none;
Re: Asked on eclipse_tw group: any product customization way to disable display [message #611136 is a reply to message #472433] Mon, 07 April 2008 15:07 Go to previous message
David Porter wrote:
> Chris
> doc plug-ins.
> Thanks
>> display: none;
Previous Topic:Replace Eclipse help with something else?
Next Topic:Stop help server when standalone help exits
Current Time: Sun Jul 27 04:03:13 EDT 2025
Powered by FUDForum. Page generated in 0.05715 seconds
