Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469126 is a reply to message #469122] |
Sat, 01 November 2008 09:20  |
The plugins edit/edtor/tests you mentioned are not mandadory. The SVN of
sourceforge is not useful. We have uploaded few files per commit, it takes a
lot of time to upload.
best regards
Yves YANG
"Remy Chi Jian Suen" <remy.suen@gmail.com> wrote in message
news:gegvh7$s1p$1@build.eclipse.org...
> Remy Chi Jian Suen wrote:
>> o.s.microsoft.msbuild.edit will not build properly. There appears to be
>> no MANIFEST.MF file and the plugin.xml has errors (as the plug-in is not
>> even defined properly in the old Eclipse 2.x format). This problem
>> indirectly affects the compilation of o.s.microsoft.msbuild.editor.
> o.s.microsoft.msbuild.edit is okay now as I see that the MANIFEST.MF file
> was committed in r78.
> Thanks.
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563347 is a reply to message #469119] |
Fri, 31 October 2008 03:48  |
Originally posted by: remy.suen.gmail.com
Hi Yves,
Yves Yang wrote:
> The soruce is updated in sourceforge.
I am having compilation problems.
o.s.csm.tests will not compile because o.s.csm.tools are nowhere to be
found.
Closing the erroneous projects is okay since I can still run SLDT
through PDE, I guess I will just miss some MSBuild features.
Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563369 is a reply to message #469120] |
Sat, 01 November 2008 03:14  |
file was committed in r78.
Thanks.
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563389 is a reply to message #469122] |
Sat, 01 November 2008 09:16  |
best regards
Yves YANG
> Thanks.
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563412 is a reply to message #469122] |
best regards
Yves YANG
> Thanks.
FUDForum. Page generated in 0.05415 seconds
