Home » Archived » AMW » The sources of AMW have been committed
The sources of AMW have been committed [message #468666] Wed, 19 November 2008 11:48 Go to next message
the sources of AMW have just been committed under SVN.
The web location is:
http://dev.eclipse.org/viewsvn/index.cgi/plugins/trunk/?root =Modeling_AMW
I have tested it using Eclipse Ganimede, and ATL branch "R2_1_0dev".
Marcos.
Re: The sources of AMW have been committed [message #468679 is a reply to message #468666] Wed, 19 November 2008 12:41 Go to previous messageGo to next message
Thanks a lot Marcos,
You're the best ;-)
Gabriel
Re: The sources of AMW have been committed [message #469081 is a reply to message #468666] Thu, 20 November 2008 07:14 Go to previous messageGo to next message
--------------030608050508010602080500
Great Marcos, thank you very much.
Just one question:
* org.eclipse.gmt.weaver has a dependency on
org.eclipse.gmt.am3.dsls.km3 which is no longer in the trunk but
in the deprecated folder of the AM3 repository.
* org.eclipse.gmt.am3.dsls.km3 has a dependency on
org.eclipse.gmt.tcs.dsls (I believe there are also some
unsatisfied dependencies on TCS also in AMW), but I don't know
where to get TCS as gmt repository is no longer online.
Sorry if I'm asking something silly, I'm new to deploying from sources.
I also want to thank you on the pointer to the use case in the other
thread. I'll take a look at it and get back to you if I have more questions.
Thank you again and best regards,
Juan Pedro
Marcos Didonet Del Fabro escribi
Re: The sources of AMW have been committed [message #469086 is a reply to message #469081] Thu, 20 November 2008 07:49 Go to previous messageGo to next message
yes, AMW still depends on this "old version" of AM3.
This dependency can be deleted.
Marcos.
> Juan Pedro
> Marcos Didonet Del Fabro escribió:
>> Hello,
>> Regards,
>> Marcos.
Re: The sources of AMW have been committed [message #469088 is a reply to message #469086] Thu, 20 November 2008 08:27 Go to previous messageGo to next message
Thank you very much for your help, Marcos.
> Hello,
> Marcos.
>> questions.
>> Juan Pedro
>>> Hello,
>>> Regards,
>>> Marcos.
Re: The sources of AMW have been committed [message #469092 is a reply to message #469088] Fri, 21 November 2008 06:29 Go to previous messageGo to next message
I hope I don't embarrass myself, but what is the SVN path ?
I tried 'http://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt'
and several others but they don't work.
I don't want to go to the trouble downloading all files via the
Webinterface "http://dev.eclipse.org/viewcvs/..."
Thanks in advance, Tim
Re: The sources of AMW have been committed [message #469096 is a reply to message #469092] Fri, 21 November 2008 07:04 Go to previous messageGo to next message
the SVN path for anonymous access is :
http://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.amw
Marcos.
PS.: I don't think it is possible to access the GMT root path directly
anymore.
Tim Brömme wrote:
Re: The sources of AMW have been committed [message #469099 is a reply to message #469096] Fri, 21 November 2008 07:10 Go to previous message
thanks a lot !
Previous Topic:SVN Repository.
Next Topic:AMW evolution wishes
Current Time: Sun Jul 27 13:54:02 EDT 2025
Powered by FUDForum. Page generated in 0.24746 seconds
