Home » Modeling » Papyrus » Package merge
Package merge [message #469008] Mon, 24 November 2008 00:54 Go to next message
Is package merging supported by papyrus ? If not can anyone point me to
how that can be done under eclipse ? I would like to do an heavyweight
type of extension.
Stéphane
Re: Package merge [message #469013 is a reply to message #469008] Mon, 24 November 2008 09:45 Go to previous messageGo to next message
St
Re: Package merge [message #469014 is a reply to message #469013] Mon, 24 November 2008 13:31 Go to previous messageGo to next message
On Mon, 24 Nov 2008 09:45:01 -0500, Kenn Hussey wrote:
> Stéphane,
> Package merge is currently supported via the tree editor provided by the
> UML2 component of MDT. I expect that support will be included in Papyrus
> over time...
Hi Kenn,
I meant to ask for a graphical approach, but the tree editor will do for
now. I also hope support will be included in Papyrus.
Stéphane
> Kenn
> "Stéphane S. Somé" <stephanesome@googlemail.com> wrote in message
> news:ggdfjc$dk6$1@build.eclipse.org...
>> Hi,
>> type of extension.
>> Thanks,
>> Stéphane
Re: Package merge [message #469016 is a reply to message #469014] Wed, 26 November 2008 04:23 Go to previous messageGo to next message
Hi St
Re: Package merge [message #469017 is a reply to message #469016] Wed, 26 November 2008 11:05 Go to previous messageGo to next message
There are there two issues:
1 - first issue consist in proposing to draw a merge link between
severalpackages. I think (hope) it is alreday available.
2 - the second issue is to do the merge effectively in the final merged
package. that is not done yet, but that has to be done. St
Re: Package merge [message #469032 is a reply to message #469017] Fri, 05 December 2008 15:48 Go to previous messageGo to next message
Sorry for the late reply. I haven't checked this newsgroup for a while.
I am not sure if even that is possible. I haven't seen such a link.
2 - the second
> issue is to do the merge effectively in the final merged package. that
> is not done yet, but that has to be done. Stéphane, would you like to be
> volonteer to do that? Patrick can support you in this action of course.
I don't mind volunteering but could you clarify what is asked ? Formally
proposing the feature or implementing it. The second scenario would be
quite a challenge for me :-)
Stéphane
> Cheers... Sébastien.
> "Patrick Tessier" <Patrick.Tessier@cea.fr> a écrit dans le message de
> news: ggj4io$ot5$1@build.eclipse.org...
>> Hi Stéphane,
>> The purpose is to support graphically all functionnalities described in
>> the superstructure of UML.
>> So to respond to your question : yes.
>> If this representation is no included in the tool, this lack will be
>> considered as a bug.
>> Patrick
>> "Stéphane S. Somé" <stephanesome@googlemail.com> a écrit dans le
>> message de news: ggerup$crc$1@build.eclipse.org...
>>>> Stéphane,
>>>> the UML2 component of MDT. I expect that support will be included in
>>>> Papyrus over time...
>>> Hi Kenn,
>>> for now. I also hope support will be included in Papyrus.
>>> Thanks,
>>> Stéphane
>>>> Kenn
>>>>> Hi,
>>>>> to how that can be done under eclipse ? I would like to do an
>>>>> heavyweight type of extension.
>>>>> Thanks,
>>>>> Stéphane
Re: Package merge [message #469034 is a reply to message #469008] Tue, 16 December 2008 10:58 Go to previous messageGo to next message
Papyrus does support merge concept but only at modeling level, that means
you can model a merge relationship between two pakages, but it does not
include a support for merging actually the packages themseves.
Indeed, the UML2 componenent of MDT implements this facility and it would be
great if you could integrate that facility inside Papyrus in addition to its
current facilties for modeling the merge relationship.
"St
Re: Package merge [message #469038 is a reply to message #469032] Fri, 19 December 2008 08:25 Go to previous message
The tool is available but there is currently a bug to fix. Patrick will deal
with that early January when back from vacation.
For the second point, yes I was meaing "implementing" it of course. ;-)
"St
Re: Package merge [message #573277 is a reply to message #469008] Mon, 24 November 2008 09:45 Go to previous message
St
Re: Package merge [message #573296 is a reply to message #469013] Mon, 24 November 2008 13:31 Go to previous message
> Stéphane,
> over time...
Hi Kenn,
Stéphane
> Kenn
>> Hi,
>> type of extension.
>> Thanks,
>> Stéphane
Re: Package merge [message #573319 is a reply to message #469014] Wed, 26 November 2008 04:23 Go to previous message
Hi St
Re: Package merge [message #573324 is a reply to message #469016] Wed, 26 November 2008 11:05 Go to previous message
Re: Package merge [message #575332 is a reply to message #469017] Fri, 05 December 2008 15:48 Go to previous message
2 - the second
Stéphane
>> Hi Stéphane,
>> Patrick
>>>> Stéphane,
>>> Hi Kenn,
>>> Thanks,
>>> Stéphane
>>>> Kenn
>>>>> Hi,
>>>>> Thanks,
>>>>> Stéphane
Re: Package merge [message #575344 is a reply to message #469008] Tue, 16 December 2008 10:58 Go to previous message
"St
Re: Package merge [message #575394 is a reply to message #469032] Fri, 19 December 2008 08:25 Go to previous message
"St
Previous Topic:Re: Is there anybody who use Papyrus UML?
Next Topic:Re: Is there anybody who use Papyrus UML?
Current Time: Sun Jul 27 14:11:45 EDT 2025
Powered by FUDForum. Page generated in 0.05045 seconds
