Home » Modeling » UML2 » State Machine - UML Editor & Programmatic
State Machine - UML Editor & Programmatic [message #468754] |
Mon, 22 January 2007 19:03  |
Originally posted by: psentosa.yahoo.com
I'd like to create a state machine both programmaticaly and by using the UML
editor, but I'm still confused on how to use them.
1. What are the differences between the usage of Packaged Element -,
Classifier Behaviour -, Nested Behaviour -, Owned Type-, and Do Actions
(Protocol) State Machine?
2. Can "State" exist only within "Region"? I read about "Region" only in the
context of concurrent region (thus, concurrent sub-state). But what about in
the non-concurrent environtment? Do we still need a region?
3. Is this the correct order to define a state charts:
- create (Owned Type/Packaged Element) State Machine
- Create Region
- Create State(s)
4. Is there any way to define the beginning state/black circle? (Just like
we can define "Final State"/bordered circle)
5. To define sub states of, say, state A, do I have to create a region as a
child of State A, and then create some states within the newly created
region?
Programmaticaly, how can I create a state machine? If I use the factory
method UMLFactory.eInstance.createStateMachine and I'd like to put this
under the Model element, how can this be done?
Thanks and would appreciate any hints
Paul
Re: State Machine - UML Editor & Programmatic [message #468760 is a reply to message #468754] |
Tue, 23 January 2007 09:30   |
Hi Paul,
UML can be a complicated puzzle ;) ... This is where a graphical tool comes
in handy.
Your best starting point is to look at the superstructure spec ..
http://www.omg.org/docs/ptc/06-04-02.pdf
some answers inline below ...
- James.
"Paul Sentosa" <psentosa@yahoo.com> wrote in message
news:ep3jd3$ilc$1@utils.eclipse.org...
> UML
A packageable element indicates a named element that may be owned directly
by a package.
Interfaces and classes can own nested classifiers ( ie nested classes ).
Packages can own "Types" ( ie. a class is a Type). Types are
PackageableElements.
Have a look at the UML superstructure spec for detailed explanations of all
these items ( I would simply be cutting and pasting definitions for these
items from the spec )
> the
> in
Yes in a non-concurent environment a statemachine would still own a region
in which you would have states.
> - Create Region
> - Create State(s)
Yes. ... a StateMachine is a Class. Packages own classess... The order
you have indicated is right.
Have a look at Pseudostates and the PseudostateKind enumeration. The
Pseudostate entry point is what you are interested in I believe.
> a
> region?
Yes.
BehavioredClassifiers own behaviors ... StateMachine's are Behaviors.
You can use the BehavioredClassifier.createOwnedBehavior() or
myBehavioredClassifier.getOwnedBehaviors().add(UMLFactory.eI nstance.createStateMachine());
> Paul
Re: State Machine - UML Editor & Programmatic [message #468907 is a reply to message #468760] |
Tue, 23 January 2007 10:52   |
Hi James,
many thanks for your kind explanation.
To my last question....I'm sorry if I'm missing something, but somehow I
still can't relate my Model element to a BehavioredClassifier.
Is using myModel.createOwnedType() also an alternative? (By casting Type
into StateMachine). What kind of EClass argument should then be used?
Could you please explain a bit more?
Thanks again.
Paul
"James Bruck" <jbruck@ca.ibm.com> schrieb im Newsbeitrag
news:ep5611$sft$1@utils.eclipse.org...
> Hi Paul,
comes
> in handy.
> - James.
> > Hi,
> > UML
> by a package.
all
> > the
about
> > in
> > - Create Region
> > - Create State(s)
like
as
> > a
> > region?
> Yes.
ateMachine());
> > Paul
Re: State Machine - UML Editor & Programmatic [message #468909 is a reply to message #468907] |
Tue, 23 January 2007 11:09   |
Hi Paul,
Ok ... let me back up a bit. Firstly, although Statemachines can be owned
direcly by a Package, by convention, they apply to a particular class.
So one would typically ( although not necessarily ) create a statemachine
under a class ( creating it directly under a Package is not wrong ).
So from your package you could do something like...
org.eclipse.uml2.uml.Class myClass =
(org.eclipse.uml2.uml.Class)myPackage.createOwnedType("myClass ",
ULPackage.Literals.CLASS);
// Note: Classes are Types
StateMachine myStateMachine =
(StateMachine)myClass.createOwnedBehavior("myStatemachine",
UMLPackage.Literals.STATE_MACHINE);
// Note: StateMachines are Behaviors, Behaviors are Classes.
Continue in this way to add a region and then a state etc.
The alternative is to manufacture these classes using the factory ie..
UMLFactory.eINSTANCE.createXXXX();
Then get the owning collection and add it in directly ( as mentioned
previously ).
Have a look at the "Getting started with UML" articles by Kenn Hussey for
better explanations.
- James.
"Paul" <psentosa@yahoo.com> wrote in message
news:ep5b0c$mpm$1@utils.eclipse.org...
> Hi James,
> Thanks again.
> Paul
> > Hi Paul,
> comes
> > in handy.
> > - James.
> > > Hi,
the
> > > UML
Actions
directly
> > by a package.
> all
these
in
> > > the
> about
> > > in
region
> > > - Create Region
> > > - Create State(s)
order
> like
> as
> > > a
> > > region?
> > Yes.
factory
this
> ateMachine());
> > > Paul
Re: State Machine - UML Editor & Programmatic [message #468912 is a reply to message #468909] |
Tue, 23 January 2007 12:18   |
Thank you very much, James!
Best Regards
Paul
ps: Is it possible to have some more articles giving examples on how to use
the other APIs?
news:ep5bvn$p66$2@utils.eclipse.org...
> Hi Paul,
owned
> previously ).
> Regards,
> - James.
> > Hi James,
> > Thanks again.
> > Paul
> > > Hi Paul,
> > comes
> > > in handy.
> > > - James.
> > > > Hi,
> the
> > > > UML
> Actions
> directly
> > > by a package.
classes ).
of
> > all
> these
only
> in
> > > > the
> > about
> > > > in
> region
> > > > - Create Region
> > > > - Create State(s)
> order
(Just
> > like
region
> > as
> > > > a
created
> > > > region?
> > > Yes.
> factory
> this
> > ateMachine());
> > > > Paul
Re: State Machine - UML Editor & Programmatic [message #469704 is a reply to message #468912] |
Sat, 27 January 2007 23:02   |
Hi Paul,
The migration document points out some of the new API's.
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
You can add yourself to the notification list of this bugzilla to be the
first to get your hands on new articles.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=77413
Feel free to contribute articles yourself :)
- James.
news:ep5g1r$k6r$1@utils.eclipse.org...
> Best Regards
> Paul
> use
> the other APIs?
>> Hi Paul,
> owned
>> previously ).
>> Regards,
>> - James.
>> > Hi James,
>> > I
>> > Type
>> > Thanks again.
>> > Paul
>> > > Hi Paul,
>> > > tool
>> > comes
>> > > in handy.
>> > > - James.
>> > > > Hi,
>> > > > using
>> the
>> > > > UML
>> > > > Element -,
>> Actions
>> directly
>> > > by a package.
> classes ).
> of
>> > all
>> these
> only
>> in
>> > > > the
>> > about
>> > > > in
>> region
>> > > > - Create Region
>> > > > - Create State(s)
>> order
> (Just
>> > like
>> > > The
> region
>> > as
>> > > > a
> created
>> > > > region?
>> > > Yes.
>> factory
>> this
>> > ateMachine());
>> > > > Paul
Re: State Machine - UML Editor & Programmatic [message #573351 is a reply to message #468754] |
Hi Paul,
in handy.
- James.
> UML
by a package.
> the
> in
> - Create Region
> - Create State(s)
> a
> region?
Yes.
> Paul
Re: State Machine - UML Editor & Programmatic [message #573625 is a reply to message #468760] |
Hi James,
Thanks again.
Paul
> Hi Paul,
comes
> in handy.
> - James.
> > Hi,
> > UML
> by a package.
all
> > the
about
> > in
> > - Create Region
> > - Create State(s)
like
as
> > a
> > region?
> Yes.
ateMachine());
> > Paul
Re: State Machine - UML Editor & Programmatic [message #573641 is a reply to message #468907] |
Hi Paul,
previously ).
- James.
> Hi James,
> Thanks again.
> Paul
> > Hi Paul,
> comes
> > in handy.
> > - James.
> > > Hi,
the
> > > UML
Actions
directly
> > by a package.
> all
these
in
> > > the
> about
> > > in
region
> > > - Create Region
> > > - Create State(s)
order
> like
> as
> > > a
> > > region?
> > Yes.
factory
this
> ateMachine());
> > > Paul
Re: State Machine - UML Editor & Programmatic [message #573666 is a reply to message #468909] |
Best Regards
Paul
the other APIs?
> Hi Paul,
owned
> previously ).
> Regards,
> - James.
> > Hi James,
> > Thanks again.
> > Paul
> > > Hi Paul,
> > comes
> > > in handy.
> > > - James.
> > > > Hi,
> the
> > > > UML
> Actions
> directly
> > > by a package.
classes ).
of
> > all
> these
only
> in
> > > > the
> > about
> > > > in
> region
> > > > - Create Region
> > > > - Create State(s)
> order
(Just
> > like
region
> > as
> > > > a
created
> > > > region?
> > > Yes.
> factory
> this
> > ateMachine());
> > > > Paul
Re: State Machine - UML Editor & Programmatic [message #576357 is a reply to message #468912] |
Hi Paul,
- James.
> Best Regards
> Paul
> use
> the other APIs?
>> Hi Paul,
> owned
>> previously ).
>> Regards,
>> - James.
>> > Hi James,
>> > I
>> > Type
>> > Thanks again.
>> > Paul
>> > > Hi Paul,
>> > > tool
>> > comes
>> > > in handy.
>> > > - James.
>> > > > Hi,
>> > > > using
>> the
>> > > > UML
>> > > > Element -,
>> Actions
>> directly
>> > > by a package.
> classes ).
> of
>> > all
>> these
> only
>> in
>> > > > the
>> > about
>> > > > in
>> region
>> > > > - Create Region
>> > > > - Create State(s)
>> order
> (Just
>> > like
>> > > The
> region
>> > as
>> > > > a
> created
>> > > > region?
>> > > Yes.
>> factory
>> this
>> > ateMachine());
>> > > > Paul
Current Time: Wed Jul 23 07:48:27 EDT 2025
Powered by FUDForum. Page generated in 0.50556 seconds
