Home » Modeling » UML2 » Re: Problem using UML Genmodel
Re: Problem using UML Genmodel [message #468510] |
Wed, 17 January 2007 10:53  |
------=_NextPart_000_000E_01C73A58.07A75B90
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi James
Thanks for your answer!
Fortunately the problem disappeared unexpectedly when I changed the =
Aggregation attribute of the memberEnd to "none". After switching back =
to 'composite' everything remained ok...
But after some experiences with the Genmodel there are some further =
questions:
- For every implementation class there is a getCacheAdapter() method =
generated (in the uml2.uml-impl-classes there is no such method) - this =
leads to a stack overflow using the generated editor plugin. Deleting =
the method manually resolves the problem. What am I doing wrong with the =
UML-Model/Genmodel?
- In the UML.merged.uml-model used as metamodel, what is the difference =
beween memberEnd Property with <eReference> Stereotype and the ones =
without Stereotype?
- Using an UML-model as metamodel is there a special behaviour in =
Genmodel when using ownedEnd's in associations (as in =
A_general_generalization)?
And finally a question which is maybe not just related with uml2:
Getting all the sources from CVS (emf: 200701110200 uml2: 200701111331) =
on 3.3M4 there are several errors in the UML2 projects even after =
updating the classpathes (org.eclipse.uml2, .uml2.importer.rose, . Is =
that just a strange behaviour of my environment?
Greets, Andreas
"James Bruck" <jbruck@ca.ibm.com> wrote in message =
news:eo93md$g96$2@utils.eclipse.org...
Hi Andreas,
I just tried this on my machine with a contrived example and it seemed =
to work fine ( If I understood this correctly ;) ).
Would it be possible for you to send more information or a snippet of =
your metamodel so I can inspect it.
What errors are you seeing in the impl class?
- James.
"Andreas Morf" <andreas_morf@bluewin.ch> wrote in message =
news:eo7rou$ob0$1@utils.eclipse.org...
Hi all
I'm trying to make a new language metamodel on the basis on UML.uml =
and using UML-Genmodel. In principle, the process is working but with =
the following aspect I get into trouble:
- In my metamodel I have two classes with an 1 -- 0..* association
- the creation of the genmodel works well
- after model-code generation, there are errors in the impl-class of =
the 0..* -side: in the following code-snipped the varable ownedrules is =
not declared in the class
- if I change the Multiplicity to 1, the resulting code works
public EList getOwnedrules() {
if (ownedrules =3D=3D null) {
ownedrules =3D new EObjectWithInverseResolvingEList(
MappingRule.class, this,
UMLTPackage.TRANSFORMATION_GROUP__OWNEDRULES,
UMLTPackage.MAPPING_RULE__TGROUP);
return ownedrules;
In the attachments there are some pictures of the .uml and .genmodel =
to get the context.
Anyone an idea
Regards, Andreas
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.5730.11" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi James</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your answer!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Fortunately the problem disappeared =
unexpectedly=20
when I changed the Aggregation attribute of the memberEnd to "none". =
After=20
switching back to 'composite' everything remained ok...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>But after some experiences with the =
Genmodel there=20
are some further questions:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- For every implementation class there =
is a <FONT=20
size=3D2>getCacheAdapter() method generated (in the =
uml2.uml-impl-classes there is=20
no such method) - this leads to a stack overflow using the generated =
editor=20
plugin. Deleting the method manually resolves the problem. What am I =
doing wrong=20
with the UML-Model/Genmodel?</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- In the UML.merged.uml-model used as =
metamodel,=20
what is the difference beween memberEnd Property with <eReference> =
Stereotype and the ones without Stereotype?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- Using an UML-model as metamodel is =
there a=20
special behaviour in Genmodel when using ownedEnd's in associations (as =
in=20
A_general_generalization)?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>And finally a question which is maybe =
not just=20
related with uml2:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Getting all the sources from CVS (emf: =
200701110200=20
uml2: 200701111331) on 3.3M4 there are several errors in the UML2 =
projects even=20
after updating the classpathes (org.eclipse.uml2, .uml2.importer.rose, . =
Is that=20
just a strange behaviour of my environment?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Greets, Andreas</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"James Bruck" <<A=20
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>> wrote in =
message <A=20
href=3D"news:eo93md$g96$2@utils.eclipse.org">news:eo93md$g96$2@utils.ecli=
pse.org</A>...</DIV>
<DIV><FONT face=3DArial size=3D2>Hi Andreas,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I just tried this on my machine with =
a contrived=20
example and it seemed to work fine ( If I understood this correctly =
;) =20
).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Would it be possible for you to send =
more=20
information or a snippet of your metamodel so I can inspect =
it.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>What errors are you seeing in the =
impl=20
class?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- James.</FONT></DIV>
<DIV>"Andreas Morf" <<A=20
href=3D"mailto:andreas_morf@bluewin.ch">andreas_morf@bluewin.ch</A>> =
wrote=20
in message <A=20
href=3D"news:eo7rou$ob0$1@utils.eclipse.org">news:eo7rou$ob0$1@utils.ecli=
<DIV>Hi all</DIV>
<DIV>I'm trying to make a new language metamodel on the basis on =
UML.uml and=20
the=20
following aspect I get into trouble:</DIV>
<DIV> </DIV>
<DIV>- In my metamodel I have two classes with an 1 -- 0..*=20
association</DIV>
<DIV>- the creation of the genmodel works well</DIV>
<DIV>- after model-code generation, there are errors in the =
impl-class of=20
the 0..* -side: in the following code-snipped the varable ownedrules =
is not=20
declared in the class</DIV>
<DIV>- if I change the Multiplicity to 1, the resulting code =
works</DIV>
<P align=3Dleft><B><FONT color=3D#7f0055 =
size=3D2>public</B></FONT><FONT size=3D2>=20
EList getOwnedrules() {</P>
<P align=3Dleft></FONT><B><FONT color=3D#7f0055 =
size=3D2>if</B></FONT><FONT=20
size=3D2> (ownedrules =3D=3D </FONT><B><FONT color=3D#7f0055=20
size=3D2>null</B></FONT><FONT size=3D2>) {</P>
<P align=3Dleft>ownedrules =3D </FONT><B><FONT color=3D#7f0055=20
size=3D2>new</B></FONT><FONT size=3D2> =
EObjectWithInverseResolvingEList(</P>
<P align=3Dleft>MappingRule.</FONT><B><FONT color=3D#7f0055=20
size=3D2>class</B></FONT><FONT size=3D2>, </FONT><B><FONT =
color=3D#7f0055=20
size=3D2>this</B></FONT><FONT size=3D2>,</P>
<P align=3Dleft>UMLTPackage.</FONT><I><FONT color=3D#0000c0=20
size=3D2>TRANSFORMATION_GROUP__OWNEDRULES</I></FONT><FONT =
size=3D2>,</P>
size=3D2>MAPPING_RULE__TGROUP</I></FONT><FONT size=3D2>);</P>
<P align=3Dleft>}</P>
size=3D2>return</B></FONT><FONT=20
size=3D2> ownedrules;</P>
<P align=3Dleft>}</FONT></FONT></P></DIV>
<DIV>In the attachments there are some pictures of the .uml and =
..genmodel to=20
get the context.</DIV>
<DIV> </DIV>
<DIV>Anyone an idea</DIV>
<DIV>Regards, Andreas</DIV>
<DIV><FONT face=3DArial=20
size=3D2></FONT> </DIV></BLOCKQUOTE></BLOCKQUOTE ></BODY></HTML>
------=_NextPart_000_000E_01C73A58.07A75B90--
Re: Problem using UML Genmodel [message #468524 is a reply to message #468510] |
Thu, 18 January 2007 21:34   |
------=_NextPart_000_0080_01C73B48.610BDD00
Hi Andreas,
some comments below ...
- James.
news:eolgq1$q5s$1@utils.eclipse.org...
Hi James
questions:
UML-Model/Genmodel?
+ Not sure about this one I'll have to investigate and get back to =
you. =20
- In the UML.merged.uml-model used as metamodel, what is the =
difference beween memberEnd Property with <eReference> Stereotype and =
+ In general the Ecore stereotype provides information when converting =
from UMLto Ecore. Specific code generation details might be necessary =
for those items with stereotypes applied. Sometimes information is =
provided in the stereotype to allow conversion from Ecore to UML and =
back to Ecore and preserve the integrity of the original .ecore model ( =
ie. round tripping ).
+ I'm not sure what you mean about "special behavior". I'm not aware =
of unique behavior for this. I'll discuss it with Kenn and get back to =
you if there is something unique here.
Getting all the sources from CVS (emf: 200701110200 uml2: =
200701111331) on 3.3M4 there are several errors in the UML2 projects =
even after updating the classpathes (org.eclipse.uml2, =
..uml2.importer.rose, . Is that just a strange behaviour of my =
environment?
+ I'm not seeing any build issues for the uml2 project. I do however =
have some issues with org.eclipse.emf.importer.rose. .. may not be the =
same issue you are having but these problems are a result of .jars =
needed for ant.
Sometimes there are .readme's that explain how to resolve these =
issues.
eg. Before running your build scripts or the examples provided here, =
make sure you have the 2 jar files required by this plugin =
("importer.rose.jar" and "importer.rose.tasks.jar") and also the 2 jar =
files required by the org.eclipse.emf.ant plugin ("emf.ant.jar" and =
"emf.ant.tasks.jar"). If necessary, Eclipse can generate them for you. =
All you need to do is to run the Ant script created by PDE when you =
right click on the manifest file and select "PDE Tools>Create Ant Build =
File".=20
but again, I don't see any issues with uml.
Greets, Andreas
Hi Andreas,
I just tried this on my machine with a contrived example and it =
seemed to work fine ( If I understood this correctly ;) ).
Would it be possible for you to send more information or a snippet =
of your metamodel so I can inspect it.
- James.
Hi all
UML.uml and using UML-Genmodel. In principle, the process is working but =
with the following aspect I get into trouble:
- after model-code generation, there are errors in the impl-class =
of the 0..* -side: in the following code-snipped the varable ownedrules =
is not declared in the class
return ownedrules;
..genmodel to get the context.
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2995" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>some comments below ...</FONT></DIV>
wrote in=20
message <A=20
href=3D"news:eolgq1$q5s$1@utils.eclipse.org">news:eolgq1$q5s$1@utils.ecli=
unexpectedly=20
After=20
Genmodel=20
there are some further questions:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- For every implementation class =
there is a <FONT=20
uml2.uml-impl-classes there=20
is no such method) - this leads to a stack overflow using the =
generated editor=20
doing=20
wrong with the UML-Model/Genmodel?</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>+ Not sure about this one I'll =
have to=20
investigate and get back to you. </FONT></DIV>
metamodel,=20
what is the difference beween memberEnd Property with =
<eReference>=20
<DIV><FONT face=3DArial size=3D2>+ In general the Ecore stereotype =
provides=20
information when converting from UMLto Ecore. Specific code =
generation=20
details might be necessary for those items with stereotypes =
applied. =20
Sometimes information is provided in the stereotype to allow =
conversion from=20
Ecore to UML and back to Ecore and preserve the integrity of the =
original=20
.ecore model ( ie. round tripping ).</FONT></DIV>
there a=20
special behaviour in Genmodel when using ownedEnd's in associations =
(as in=20
<DIV><FONT face=3DArial size=3D2>+ I'm not sure what you mean about =
"special=20
behavior". I'm not aware of unique behavior for =
this. I'll=20
discuss it with Kenn and get back to you if there is something unique=20
here.</FONT></DIV>
not just=20
<DIV><FONT face=3DArial size=3D2>Getting all the sources from CVS =
(emf:=20
200701110200 uml2: 200701111331) on 3.3M4 there are several errors in =
the UML2=20
projects even after updating the classpathes (org.eclipse.uml2,=20
.uml2.importer.rose, . Is that just a strange behaviour of my=20
<DIV><FONT face=3DArial size=3D2>+ I'm not seeing any build issues for =
the uml2=20
project. I do however have some issues with=20
org.eclipse.emf.importer.rose. .. may not be the same =
issue you=20
are having but these problems are a result of .jars needed for=20
ant.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Sometimes there are .readme's that =
explain how to=20
resolve these issues.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>eg. <FONT size=3D3><FONT=20
face=3D"Times New Roman">Before running your build scripts or the =
examples=20
provided here, make sure you have the 2 jar files required by this =
plugin=20
files=20
required by the </FONT><TT>org.eclipse.emf.ant</TT><FONT=20
face=3D"Times New Roman"> plugin ("emf.ant.jar" and =
"emf.ant.tasks.jar"). If=20
necessary, Eclipse can generate them for you. All you need to do is to =
run the=20
Ant script created by PDE when you right click on the manifest file =
and select=20
"PDE Tools>Create Ant Build File". </FONT></FONT></FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>but again, I don't see any issues =
with=20
uml.</FONT></DIV>
message=20
<A=20
<DIV><FONT face=3DArial size=3D2>I just tried this on my machine =
with a=20
contrived example and it seemed to work fine ( If I understood this=20
correctly ;) ).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Would it be possible for you to =
send more=20
it.</FONT></DIV>
impl=20
class?</FONT></DIV>
href=3D"mailto:andreas_morf@bluewin.ch">andreas_morf@bluewin.ch</A>>=20
wrote in message <A=20
<DIV>Hi all</DIV>
UML.uml=20
with the=20
<DIV> </DIV>
association</DIV>
impl-class of=20
the 0..* -side: in the following code-snipped the varable =
ownedrules is=20
not declared in the class</DIV>
works</DIV>
color=3D#7f0055=20
size=3D2>,</P>
..genmodel=20
to get the context.</DIV>
<DIV> </DIV>
size=3D2></FONT> </DIV></BLOCKQUOTE></BLOCKQUOTE ></BLOCKQUOTE></BODY=
></HTML>
------=_NextPart_000_0080_01C73B48.610BDD00--
Re: Problem using UML Genmodel [message #468525 is a reply to message #468510] |
Thu, 18 January 2007 22:01   |
------=_NextPart_000_078A_01C73B4C.33147340
Andreas,
Regarding the errors, please ensure that you only have the following =
projects checked out (from HEAD):
org.eclipse.uml2-feature
org.eclipse.uml2-plugin
org.eclipse.uml2.codegen.ecore
org.eclipse.uml2.codegen.ecore.ui
org.eclipse.uml2.common
org.eclipse.uml2.common.edit
org.eclipse.uml2.doc-feature
org.eclipse.uml2.doc-plugin
org.eclipse.uml2.examples-feature
org.eclipse.uml2.examples-plugin
org.eclipse.uml2.examples.uml.ui
org.eclipse.uml2.sdk-feature
org.eclipse.uml2.tests-feature
org.eclipse.uml2.tests-plugin
org.eclipse.uml2.uml
org.eclipse.uml2.uml.ecore.exporter
org.eclipse.uml2.uml.ecore.importer
org.eclipse.uml2.uml.edit
org.eclipse.uml2.uml.editor
org.eclipse.uml2.uml.resources
org.eclipse.uml2.uml.tests
Kenn
Hi James
questions:
UML-Model/Genmodel?
environment?
Greets, Andreas
Hi Andreas,
- James.
Hi all
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3020" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Andreas,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regarding the errors, please ensure =
that you only=20
have the following projects checked out (from HEAD):</FONT></DIV>
<DIV>org.eclipse.uml2-feature<BR>org.eclipse.uml2-plugin<BR >org.eclipse.u=
ml2.codegen.ecore<BR>org.eclipse.uml2.codegen.ecore.ui<BR >org.eclipse.uml=
2.common<BR>org.eclipse.uml2.common.edit<BR>org.eclipse.uml2.doc-feature <=
BR>org.eclipse.uml2.doc-plugin<BR>org.eclipse.uml2.examples-feature <BR>or=
g.eclipse.uml2.examples-plugin<BR>org.eclipse.uml2.examples.uml.ui <BR>org=
..eclipse.uml2.sdk-feature<BR>org.eclipse.uml2.tests-feature <BR>org.eclips=
e.uml2.tests-plugin<BR>org.eclipse.uml2.uml<BR>org.eclipse.uml2.uml.ecore=
..exporter<BR>org.eclipse.uml2.uml.ecore.importer<BR>org.eclipse.uml2.uml.=
edit<BR>org.eclipse.uml2.uml.editor<BR>org.eclipse.uml2.uml.resources <BR>=
org.eclipse.uml2.uml.tests<BR></DIV>
<DIV><FONT face=3DArial size=3D2>Kenn</FONT></DIV>
wrote in=20
message <A=20
unexpectedly=20
After=20
Genmodel=20
there is a <FONT=20
generated editor=20
doing=20
metamodel,=20
<eReference>=20
there a=20
(as in=20
not just=20
(emf:=20
the UML2=20
message=20
<A=20
with a=20
send more=20
it.</FONT></DIV>
impl=20
class?</FONT></DIV>
<DIV>Hi all</DIV>
UML.uml=20
with the=20
<DIV> </DIV>
association</DIV>
impl-class of=20
ownedrules is=20
works</DIV>
color=3D#7f0055=20
size=3D2>,</P>
..genmodel=20
<DIV> </DIV>
></HTML>
------=_NextPart_000_078A_01C73B4C.33147340--
Re: Problem using UML Genmodel [message #468526 is a reply to message #468524] |
Thu, 18 January 2007 22:10   |
------=_NextPart_000_079D_01C73B4D.6CDA39B0
- Could you provide more details on the stack overflow you are seeing? =
Every "model root" class will have this method in it, but it's not clear =
to me why this would result in a stack overflow...
- Association ends that are owned by the assocation are ignored when =
converting UML models to Ecore.
Kenn
news:eopai8$174$1@utils.eclipse.org...
Hi Andreas,
- James.
Hi James
questions:
UML-Model/Genmodel?
you. =20
+ In general the Ecore stereotype provides information when =
converting from UMLto Ecore. Specific code generation details might be =
necessary for those items with stereotypes applied. Sometimes =
information is provided in the stereotype to allow conversion from Ecore =
to UML and back to Ecore and preserve the integrity of the original =
..ecore model ( ie. round tripping ).
+ I'm not sure what you mean about "special behavior". I'm not =
aware of unique behavior for this. I'll discuss it with Kenn and get =
back to you if there is something unique here.
environment?
+ I'm not seeing any build issues for the uml2 project. I do =
however have some issues with org.eclipse.emf.importer.rose. .. may =
not be the same issue you are having but these problems are a result of =
..jars needed for ant.
issues.
eg. Before running your build scripts or the examples provided =
here, make sure you have the 2 jar files required by this plugin =
File".=20
Greets, Andreas
Hi Andreas,
- James.
Hi all
- In my metamodel I have two classes with an 1 -- 0..* =
association
impl-class of the 0..* -side: in the following code-snipped the varable =
ownedrules is not declared in the class
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>- Could you provide more details on the =
stack=20
overflow you are seeing? Every "model root" class will have this method =
in it,=20
but it's not clear to me why this would result in a stack=20
overflow...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- Association ends that are owned by =
the assocation=20
are ignored when converting UML models to Ecore.</FONT></DIV>
message <A=20
href=3D"news:eopai8$174$1@utils.eclipse.org">news:eopai8$174$1@utils.ecli=
wrote=20
in message <A=20
<DIV><FONT face=3DArial size=3D2>Thanks for your =
unexpectedly when I changed the Aggregation attribute of the =
memberEnd to=20
"none". After switching back to 'composite' everything remained=20
ok...</FONT></DIV>
Genmodel=20
there is a=20
<FONT size=3D2>getCacheAdapter() method generated (in the=20
uml2.uml-impl-classes there is no such method) - this leads to a =
stack=20
overflow using the generated editor plugin. Deleting the method =
manually=20
resolves the problem. What am I doing wrong with the=20
<DIV><FONT face=3DArial size=3D2>+ Not sure about this one =
I'll have to=20
<DIV><FONT face=3DArial size=3D2>- In the UML.merged.uml-model used =
as=20
metamodel, what is the difference beween memberEnd Property with=20
<eReference> Stereotype and the ones without =
provides=20
generation=20
applied. =20
conversion from=20
original=20
<DIV><FONT face=3DArial size=3D2>- Using an UML-model as metamodel =
is there a=20
(as in=20
"special=20
this. I'll=20
discuss it with Kenn and get back to you if there is something =
unique=20
here.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>And finally a question which is =
maybe not just=20
(emf:=20
200701110200 uml2: 200701111331) on 3.3M4 there are several errors =
in the=20
UML2 projects even after updating the classpathes (org.eclipse.uml2, =
<DIV><FONT face=3DArial size=3D2>+ I'm not seeing any build issues =
for the uml2=20
issue you=20
ant.</FONT></DIV>
explain how=20
to resolve these issues.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>eg. <FONT =
size=3D3><FONT=20
examples=20
plugin=20
("importer.rose.jar" and "importer.rose.tasks.jar") and also the 2 =
jar files=20
necessary, Eclipse can generate them for you. All you need to do is =
to run=20
the Ant script created by PDE when you right click on the manifest =
file and=20
select "PDE Tools>Create Ant Build File". =
<DIV> </DIV>
with=20
uml.</FONT></DIV>
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>> wrote =
in message=20
<A=20
with a=20
contrived example and it seemed to work fine ( If I understood =
this=20
send more=20
information or a snippet of your metamodel so I can inspect=20
it.</FONT></DIV>
impl=20
class?</FONT></DIV>
<DIV>Hi all</DIV>
UML.uml=20
with=20
the following aspect I get into trouble:</DIV>
<DIV> </DIV>
association</DIV>
impl-class=20
ownedrules=20
is not declared in the class</DIV>
works</DIV>
size=3D2>public</B></FONT><FONT=20
size=3D2> EList getOwnedrules() {</P>
color=3D#7f0055=20
size=3D2>,</P>
<P align=3Dleft></FONT><B><FONT color=3D#7f0055=20
size=3D2>return</B></FONT><FONT size=3D2> ownedrules;</P>
<DIV>In the attachments there are some pictures of the .uml and=20
.genmodel to get the context.</DIV>
<DIV> </DIV>
size=3D2></FONT> </DIV></BLOCKQUOTE></BLOCKQUOTE ></BLOCKQUOTE></BLOC=
KQUOTE></BODY></HTML>
------=_NextPart_000_079D_01C73B4D.6CDA39B0--
Re: Problem using UML Genmodel [message #468690 is a reply to message #468526] |
Fri, 19 January 2007 11:49   |
------=_NextPart_000_0036_01C73BF2.2DD55AB0
Kenn,
I don't know how and why it comes, but now, there is no such method =
anymore when generating the model code - strange!
I will send you the details as soon as the problem occurs again...
So, how do you markup a class as a "model root" class in the genmodel?
Andreas
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message =
news:eopcql$mcq$1@utils.eclipse.org...
Kenn
Hi Andreas,
- James.
Hi James
Fortunately the problem disappeared unexpectedly when I changed =
the Aggregation attribute of the memberEnd to "none". After switching =
But after some experiences with the Genmodel there are some =
further questions:
- For every implementation class there is a getCacheAdapter() =
method generated (in the uml2.uml-impl-classes there is no such method) =
- this leads to a stack overflow using the generated editor plugin. =
Deleting the method manually resolves the problem. What am I doing wrong =
+ Not sure about this one I'll have to investigate and get back =
to you. =20
environment?
issues.
File".=20
Greets, Andreas
Hi Andreas,
Would it be possible for you to send more information or a =
snippet of your metamodel so I can inspect it.
- James.
Hi all
association
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Kenn,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I don't know how and why it comes, but =
now, there=20
is no such method anymore when generating the model code - =
strange!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I will send you the details as soon as =
the problem=20
occurs again...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>So, how do you markup a class as a =
"model root"=20
class in the genmodel?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Andreas</FONT></DIV>
<DIV>"Kenn Hussey" <<A=20
href=3D"mailto:khussey@ca.ibm.com">khussey@ca.ibm.com</A>> wrote in =
message=20
<A=20
href=3D"news:eopcql$mcq$1@utils.eclipse.org">news:eopcql$mcq$1@utils.ecli=
<DIV><FONT face=3DArial size=3D2>- Could you provide more details on =
the stack=20
overflow you are seeing? Every "model root" class will have this =
method in it,=20
the=20
assocation are ignored when converting UML models to =
Ecore.</FONT></DIV>
message=20
<A=20
<DIV><FONT face=3DArial size=3D2>some comments below =
....</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Fortunately the problem =
disappeared=20
memberEnd to=20
ok...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>But after some experiences with =
the Genmodel=20
there is a=20
stack=20
manually=20
I'll have to=20
<DIV><FONT face=3DArial size=3D2>- In the UML.merged.uml-model =
used as=20
<eReference> Stereotype and the ones without=20
provides=20
information when converting from UMLto Ecore. Specific code=20
generation details might be necessary for those items with =
stereotypes=20
applied. Sometimes information is provided in the stereotype =
to=20
allow conversion from Ecore to UML and back to Ecore and preserve =
the=20
integrity of the original .ecore model ( ie. round tripping=20
).</FONT></DIV>
is there a=20
special behaviour in Genmodel when using ownedEnd's in =
associations (as in=20
<DIV><FONT face=3DArial size=3D2>+ I'm not sure what you mean =
about "special=20
this. =20
I'll discuss it with Kenn and get back to you if there is =
something unique=20
here.</FONT></DIV>
maybe not=20
just related with uml2:</FONT></DIV>
(emf:=20
in the=20
UML2 projects even after updating the classpathes =
for the=20
uml2 project. I do however have some issues with=20
issue=20
you are having but these problems are a result of .jars needed for =
ant.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Sometimes there are .readme's =
that explain=20
how to resolve these issues.</FONT></DIV>
size=3D3><FONT=20
examples=20
plugin=20
jar=20
files required by the </FONT><TT>org.eclipse.emf.ant</TT><FONT=20
necessary, Eclipse can generate them for you. All you need to do =
is to run=20
file=20
and select "PDE Tools>Create Ant Build File".=20
<DIV> </DIV>
with=20
uml.</FONT></DIV>
href=3D"mailto:jbruck@ca.ibm.com">jbruck@ca.ibm.com</A>> =
wrote in=20
message <A=20
with a=20
this=20
send more=20
it.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>What errors are you seeing in =
the impl=20
class?</FONT></DIV>
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>Hi all</DIV>
<DIV>I'm trying to make a new language metamodel on the basis =
on=20
UML.uml and using UML-Genmodel. In principle, the process is =
working=20
but with the following aspect I get into trouble:</DIV>
<DIV> </DIV>
association</DIV>
impl-class=20
of the 0..* -side: in the following code-snipped the varable=20
ownedrules is not declared in the class</DIV>
<DIV>- if I change the Multiplicity to 1, the resulting code=20
works</DIV>
<P align=3Dleft>ownedrules =3D </FONT><B><FONT color=3D#7f0055 =
size=3D2>new</B></FONT><FONT size=3D2>=20
color=3D#7f0055=20
size=3D2>,</P>
<DIV>In the attachments there are some pictures of the .uml =
and=20
<DIV> </DIV>
KQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0036_01C73BF2.2DD55AB0--
Re: Problem using UML Genmodel [message #468693 is a reply to message #468690] |
Fri, 19 January 2007 13:05   |
------=_NextPart_000_07E8_01C73BCA.837935E0
Andreas,
Whether a class is considered a model root is determined in EMF like =
this:
public boolean isModelRoot()
return getClassExtendsGenClass() =3D=3D null || =
getClassExtendsGenClass().getGenModel() !=3D getGenModel();
Kenn
news:eoqsqu$i5o$1@utils.eclipse.org...
Kenn,
Andreas
- Could you provide more details on the stack overflow you are =
seeing? Every "model root" class will have this method in it, but it's =
not clear to me why this would result in a stack overflow...
Kenn
Hi Andreas,
- James.
Hi James
further questions:
to you. =20
- Using an UML-model as metamodel is there a special behaviour =
in Genmodel when using ownedEnd's in associations (as in =
And finally a question which is maybe not just related with =
uml2:
environment?
issues.
File".=20
Greets, Andreas
Hi Andreas,
I just tried this on my machine with a contrived example and =
it seemed to work fine ( If I understood this correctly ;) ).
- James.
Hi all
association
works
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Whether a class is considered a model =
root is=20
determined in EMF like this:</FONT></DIV>
<DIV><B><FONT color=3D#7f0055 size=3D2></FONT></B> </DIV>
<DIV><B><FONT color=3D#7f0055 size=3D2>public</B></FONT><FONT size=3D2>=20
</FONT><B><FONT color=3D#7f0055 size=3D2>boolean</B></FONT><FONT =
size=3D2>=20
isModelRoot()</FONT></DIV>
<DIV><FONT size=3D2>{</FONT></DIV>
<DIV><B><FONT color=3D#7f0055 size=3D2> =
size=3D2> getClassExtendsGenClass() =3D=3D </FONT><B><FONT =
color=3D#7f0055=20
size=3D2>null</B></FONT><FONT size=3D2> || =
getClassExtendsGenClass().getGenModel()=20
!=3D getGenModel();</FONT></DIV>
<DIV><FONT size=3D2>}</DIV></FONT>
wrote in=20
message <A=20
href=3D"news:eoqsqu$i5o$1@utils.eclipse.org">news:eoqsqu$i5o$1@utils.ecli=
<DIV><FONT face=3DArial size=3D2>I don't know how and why it comes, =
but now, there=20
is no such method anymore when generating the model code -=20
<DIV><FONT face=3DArial size=3D2>I will send you the details as soon =
as the=20
problem occurs again...</FONT></DIV>
"model root"=20
href=3D"mailto:khussey@ca.ibm.com">khussey@ca.ibm.com</A>> wrote =
in message=20
<A=20
the stack=20
method in=20
it, but it's not clear to me why this would result in a stack=20
<DIV><FONT face=3DArial size=3D2>- Association ends that are owned =
by the=20
Ecore.</FONT></DIV>
in message=20
<A=20
....</FONT></DIV>
disappeared=20
memberEnd=20
to "none". After switching back to 'composite' everything =
remained=20
ok...</FONT></DIV>
the=20
Genmodel there are some further questions:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- For every implementation =
class there is a=20
stack=20
manually=20
I'll have=20
to investigate and get back to you. </FONT></DIV>
used as=20
metamodel, what is the difference beween memberEnd Property with =
<DIV><FONT face=3DArial size=3D2>+ In general the Ecore =
stereotype provides=20
information when converting from UMLto Ecore. Specific =
code=20
stereotypes=20
applied. Sometimes information is provided in the =
stereotype to=20
allow conversion from Ecore to UML and back to Ecore and =
preserve the=20
).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- Using an UML-model as =
metamodel is there=20
a special behaviour in Genmodel when using ownedEnd's in =
associations=20
(as in A_general_generalization)?</FONT></DIV>
about "special=20
this. =20
something=20
unique here.</FONT></DIV>
maybe not=20
<DIV><FONT face=3DArial size=3D2>Getting all the sources from =
CVS (emf:=20
200701110200 uml2: 200701111331) on 3.3M4 there are several =
errors in=20
the UML2 projects even after updating the classpathes =
<DIV><FONT face=3DArial size=3D2>+ I'm not seeing any build =
issues for the=20
same issue=20
you are having but these problems are a result of .jars needed =
for=20
ant.</FONT></DIV>
that explain=20
size=3D3><FONT=20
face=3D"Times New Roman">Before running your build scripts or =
the examples=20
provided here, make sure you have the 2 jar files required by =
this=20
plugin ("importer.rose.jar" and "importer.rose.tasks.jar") and =
also the=20
2 jar files required by the =
"emf.ant.tasks.jar").=20
If necessary, Eclipse can generate them for you. All you need to =
do is=20
to run the Ant script created by PDE when you right click on the =
manifest file and select "PDE Tools>Create Ant Build File".=20
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>but again, I don't see any =
issues with=20
uml.</FONT></DIV>
wrote in=20
message <A=20
<DIV><FONT face=3DArial size=3D2>I just tried this on my =
machine with a=20
this=20
<DIV><FONT face=3DArial size=3D2>Would it be possible for you =
to send more=20
it.</FONT></DIV>
the impl=20
class?</FONT></DIV>
<DIV>Hi all</DIV>
<DIV>I'm trying to make a new language metamodel on the =
basis on=20
working=20
<DIV> </DIV>
association</DIV>
<DIV>- after model-code generation, there are errors in the=20
impl-class of the 0..* -side: in the following code-snipped =
the=20
varable ownedrules is not declared in the class</DIV>
works</DIV>
size=3D2>if</B></FONT><FONT size=3D2> (ownedrules =3D=3D =
</FONT><B><FONT=20
color=3D#7f0055 size=3D2>null</B></FONT><FONT size=3D2>) =
{</P>
<P align=3Dleft>ownedrules =3D </FONT><B><FONT =
color=3D#7f0055=20
color=3D#7f0055=20
size=3D2>,</P>
size=3D2>MAPPING_RULE__TGROUP</I></FONT><FONT =
size=3D2>);</P>
and=20
<DIV> </DIV>
KQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_07E8_01C73BCA.837935E0--
Re: Problem using UML Genmodel [message #468955 is a reply to message #468946] |
Fri, 26 January 2007 14:46  |
Andreas,
This is a problem only because you are extending UML2. If you are extending
UML2 and want to use the same cache adapter, overriding the method as you
have is the right choice (the other alternative is to disable cache adapter
support for your generator model). However, we should certainly avoid the
stack overflow for cases where a different cache adapter is used (the
default) - please open a Bugzilla report and we'll have this fixed.
Kenn
news:epckbf$pal$1@utils.eclipse.org...
> After refactoring my metamodel and deleting all of the generated code, the
> same problem with the getCacheAdapter appears again:
> My metaclass inherits from uml2.uml.Model and therefore the root class
> should be ElementImpl but somehow the generator isn't aware of that and
> gerates the following method leading to the StackOverflow (pingpong):
> protected CacheAdapter getCacheAdapter() {
> return CacheAdapter.getCacheAdapter(this);
> So changing this method to the following, the code works - but in my
> opinion, this should not be the preferred way:
> return super.getCacheAdapter();
> Why is this generated method different from that in the ElementImpl-Class
> Also, there is to say that I Model/genmodel importing/extending
> Metaclasses from UML.merged.uml
> Any ideas out there?
> Greetings, Andreas
Re: Problem using UML Genmodel [message #572451 is a reply to message #468510] |
Hi Andreas,
- James.
Hi James
questions:
UML-Model/Genmodel?
you. =20
environment?
needed for ant.
issues.
File".=20
Greets, Andreas
Hi Andreas,
- James.
Hi all
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
wrote in=20
message <A=20
unexpectedly=20
After=20
Genmodel=20
there is a <FONT=20
generated editor=20
doing=20
have to=20
metamodel,=20
<eReference>=20
provides=20
generation=20
applied. =20
conversion from=20
original=20
there a=20
(as in=20
"special=20
this. I'll=20
here.</FONT></DIV>
not just=20
(emf:=20
the UML2=20
the uml2=20
issue you=20
ant.</FONT></DIV>
explain how to=20
examples=20
plugin=20
files=20
run the=20
and select=20
<DIV> </DIV>
with=20
uml.</FONT></DIV>
message=20
<A=20
with a=20
send more=20
it.</FONT></DIV>
impl=20
class?</FONT></DIV>
<DIV>Hi all</DIV>
UML.uml=20
with the=20
<DIV> </DIV>
association</DIV>
impl-class of=20
ownedrules is=20
works</DIV>
color=3D#7f0055=20
size=3D2>,</P>
..genmodel=20
<DIV> </DIV>
></HTML>
Re: Problem using UML Genmodel [message #572487 is a reply to message #468510] |
Andreas,
Kenn
Hi James
questions:
UML-Model/Genmodel?
environment?
Greets, Andreas
Hi Andreas,
- James.
Hi all
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
that you only=20
wrote in=20
message <A=20
unexpectedly=20
After=20
Genmodel=20
there is a <FONT=20
generated editor=20
doing=20
metamodel,=20
<eReference>=20
there a=20
(as in=20
not just=20
(emf:=20
the UML2=20
message=20
<A=20
with a=20
send more=20
it.</FONT></DIV>
impl=20
class?</FONT></DIV>
<DIV>Hi all</DIV>
UML.uml=20
with the=20
<DIV> </DIV>
association</DIV>
impl-class of=20
ownedrules is=20
works</DIV>
color=3D#7f0055=20
size=3D2>,</P>
..genmodel=20
<DIV> </DIV>
></HTML>
Re: Problem using UML Genmodel [message #572540 is a reply to message #468524] |
Kenn
Hi Andreas,
- James.
Hi James
questions:
UML-Model/Genmodel?
you. =20
environment?
issues.
File".=20
Greets, Andreas
Hi Andreas,
- James.
Hi all
association
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
stack=20
in it,=20
the assocation=20
message <A=20
wrote=20
in message <A=20
memberEnd to=20
ok...</FONT></DIV>
Genmodel=20
there is a=20
stack=20
manually=20
I'll have to=20
as=20
provides=20
generation=20
applied. =20
conversion from=20
original=20
is there a=20
(as in=20
"special=20
this. I'll=20
unique=20
here.</FONT></DIV>
maybe not just=20
(emf:=20
in the=20
for the uml2=20
issue you=20
ant.</FONT></DIV>
explain how=20
size=3D3><FONT=20
examples=20
plugin=20
jar files=20
to run=20
file and=20
<DIV> </DIV>
with=20
uml.</FONT></DIV>
in message=20
<A=20
with a=20
this=20
send more=20
it.</FONT></DIV>
impl=20
class?</FONT></DIV>
<DIV>Hi all</DIV>
UML.uml=20
with=20
<DIV> </DIV>
association</DIV>
impl-class=20
ownedrules=20
works</DIV>
color=3D#7f0055=20
size=3D2>,</P>
<DIV> </DIV>
Re: Problem using UML Genmodel [message #572722 is a reply to message #468526] |
Kenn,
Andreas
Kenn
Hi Andreas,
- James.
Hi James
further questions:
to you. =20
environment?
issues.
File".=20
Greets, Andreas
Hi Andreas,
- James.
Hi all
association
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
now, there=20
the problem=20
"model root"=20
message=20
<A=20
the stack=20
method in it,=20
the=20
Ecore.</FONT></DIV>
message=20
<A=20
....</FONT></DIV>
disappeared=20
memberEnd to=20
ok...</FONT></DIV>
the Genmodel=20
there is a=20
stack=20
manually=20
I'll have to=20
used as=20
provides=20
stereotypes=20
to=20
the=20
).</FONT></DIV>
is there a=20
about "special=20
this. =20
something unique=20
here.</FONT></DIV>
maybe not=20
(emf:=20
in the=20
for the=20
issue=20
ant.</FONT></DIV>
that explain=20
size=3D3><FONT=20
examples=20
plugin=20
jar=20
is to run=20
file=20
<DIV> </DIV>
with=20
uml.</FONT></DIV>
wrote in=20
message <A=20
with a=20
this=20
send more=20
it.</FONT></DIV>
the impl=20
class?</FONT></DIV>
<DIV>Hi all</DIV>
on=20
working=20
<DIV> </DIV>
association</DIV>
impl-class=20
works</DIV>
color=3D#7f0055=20
size=3D2>,</P>
and=20
<DIV> </DIV>
Re: Problem using UML Genmodel [message #572776 is a reply to message #468690] |
Andreas,
this:
Kenn
Kenn,
Andreas
Kenn
Hi Andreas,
- James.
Hi James
further questions:
to you. =20
uml2:
environment?
issues.
File".=20
Greets, Andreas
Hi Andreas,
- James.
Hi all
association
works
return ownedrules;
Anyone an idea
Regards, Andreas
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
root is=20
size=3D2>=20
color=3D#7f0055=20
wrote in=20
message <A=20
but now, there=20
as the=20
"model root"=20
in message=20
<A=20
the stack=20
method in=20
by the=20
Ecore.</FONT></DIV>
in message=20
<A=20
....</FONT></DIV>
disappeared=20
memberEnd=20
remained=20
ok...</FONT></DIV>
the=20
class there is a=20
stack=20
manually=20
I'll have=20
used as=20
code=20
stereotypes=20
stereotype to=20
preserve the=20
).</FONT></DIV>
associations=20
about "special=20
this. =20
something=20
maybe not=20
CVS (emf:=20
errors in=20
issues for the=20
same issue=20
for=20
ant.</FONT></DIV>
that explain=20
size=3D3><FONT=20
the examples=20
this=20
also the=20
do is=20
<DIV> </DIV>
issues with=20
uml.</FONT></DIV>
wrote in=20
message <A=20
machine with a=20
this=20
to send more=20
it.</FONT></DIV>
the impl=20
class?</FONT></DIV>
<DIV>Hi all</DIV>
basis on=20
working=20
<DIV> </DIV>
association</DIV>
the=20
works</DIV>
</FONT><B><FONT=20
{</P>
color=3D#7f0055=20
color=3D#7f0055=20
size=3D2>,</P>
size=3D2>);</P>
and=20
<DIV> </DIV>
Re: Problem using UML Genmodel [message #574069 is a reply to message #468690] |
Fri, 26 January 2007 05:15  |
Also, there is to say that I Model/genmodel importing/extending Metaclasses
from UML.merged.uml
Greetings, Andreas
Re: Problem using UML Genmodel [message #574201 is a reply to message #468946] |
Andreas,
Kenn
> Greetings, Andreas
Current Time: Fri Jul 18 00:04:25 EDT 2025
Powered by FUDForum. Page generated in 0.13422 seconds
