Home » Archived » Buckminster » Buckminster updating / change-list generation
Buckminster updating / change-list generation [message #468199] Tue, 04 August 2009 09:41 Go to next message
Greetings folks,
I'm relatively new to Buckminster, but enthusiastic! Please excuse me if
I don't wield the vocabulary properly or don't grok some of the concepts.
I've read in this newsgroup various postings about extending Buckminster
to allow for updating an existing workspace (presumably via a cquery) and
generating change-lists as a side effect. Such a functionality would be
useful for CI framework integration - the goal being to maintain a
workspace and bump it to the latest code, recording changes, comments,
authors, etc, then rebuild and run tests. In my case, integration with
Hudson is most immediate, but I imagine that other CI frameworks would
benefit from similar functionality.
Would something like the following make sense:
* add IComponentReader.update(IPath location, Resolution resolution,
MaterializationContext ctx, IUpdateDeltaObserver observer,
IProgressMonitor monitor)
* add IComponentReader.canUpdate(); ??
* create IUpdateDeltaObserver which will get update events based on what
is being updated.
* create UpdateJob that is designed to update a materialized workspace and
record update events into a file based on configuration params
* create UpdateCommand that is wired to buckminster update <cquery> with
appropriate options to control placement, naming etc. of the change-list
xml output
* Optional extensions
** allow for a quick-as-possible (early bail on first change detected)
probe if an update would change something (IComponentReader.needsUpdate()
and an additional command?)
** allow for an option to run the update, gather the deltas, but not
actually do anything (additional boolean arg to IComponentReader.update?)
Questions:
* Would this be a reasonable pattern for all readers? I suppose, to
start, some readers could update silently or noop & log on the update??
* Is the Reader the proper level of abstraction for differentiating the
update functionality?
* Would it be better to offer the update as a set of parameters to the
materialization Job/Command rather than a separate command entirely
(enforce identical resolution and other workflow phases)?
* Is this the right direction?
If it's cool with the powers that be, I'd be happy to roll up my sleeves
once a direction is agreed upon.
pete
Re: Buckminster updating / change-list generation [message #468241 is a reply to message #468199] Tue, 04 August 2009 12:06 Go to previous messageGo to next message
Another option would be to add a couple of options to the existing
import/resolve command:
-U/-update : would instruct the materialization to get the components up
to date
-O/-output <filename> : would instruct the materialization to log changes
to the given file (have to come up with the proper format for it)
The MaterializationContext could be extended to have a boolean for update
and some kind of DeltaLogger for logging the changes.
Any feedback or preference - or am I totally talking out my ear?
I think I'll play a bit with this direction as it involves less mucking
about and see how it feels with a subversive implementation.
-pete
Re: Buckminster updating / change-list generation [message #468298 is a reply to message #468199] Tue, 04 August 2009 18:56 Go to previous messageGo to next message
I don't quite get the use case.
What exactly is it you want to keep track of?
Is it the delta between "what you have in your workspace", and "what you
will have if you run a query"? A sort of "team synchronization" but done
by Buckmisnter so it involves everything in the query, not just the
source code repositories...
Or, is this intended as a mechanism to update a workspace for the
purpose of making it faster to only update it instead of re-creating it?
- hnrik
Peter M. Murray wrote:
> Greetings folks,
> if I don't wield the vocabulary properly or don't grok some of the
> concepts.
> and generating change-lists as a side effect. Such a functionality
> would be useful for CI framework integration - the goal being to
> maintain a workspace and bump it to the latest code, recording changes,
> comments, authors, etc, then rebuild and run tests. In my case,
> integration with Hudson is most immediate, but I imagine that other CI
> frameworks would benefit from similar functionality.
> is being updated.
> and record update events into a file based on configuration params
> xml output
> (IComponentReader.needsUpdate() and an additional command?)
> Questions:
> Cheers,
> pete
Re: Buckminster updating / change-list generation [message #468303 is a reply to message #468298] Tue, 04 August 2009 20:40 Go to previous messageGo to next message
Hi Henrik,
Hudson has a concept of an SCM module which is responsible for:
* checking out the project's specified source
* polling and reporting (yes or no) if the sources required have changed
since the checkout (or last update)
* updating the sources and (optionally)reporting a log of changes,
comments, users, etc if available
Buckminster as it stands is great for the first responsibility, but
doesn't have any functionality for the latter two.
It seems to me that most of the Buckminster readers (CVS, SVN, p2 sites,
urls) can provide these additional functionalities if desired (at least
the updating and polling, in some cases without change-log)
We could then extend the current Buckminster/Hudson integration to include
an SCM module for seamless CI integration. You'd just specify the
Buckminster for the SCM, type in the cquery URL, then specify a
Buckminster build-step to perform whatever build operation you desire.
Right now, I have Hudson check out my Subversion sources (which
unfortunately requires that they share a common root folder and then use a
"local" Buckminster source to wire-up my sources for building. This means
I have to manually sync my Hudson configuration with the dependencies in
my plugin projects.
Only Buckminster has enough context to perform these operations without
hard-wiring dependencies etc.
Does that explain the use-case?
pete
Re: Buckminster updating / change-list generation [message #468334 is a reply to message #468199] Wed, 05 August 2009 03:16 Go to previous messageGo to next message
Hi Peter,
This sounds very interesting and the improvements that you suggest make a lot of sense. I have some suggestions that
might help make it even easier and perhaps keep the API changes to a minimum.
In general, I think the reader should be able to detect the difference between a check-out and and update automatically.
For CVS/SVN we can almost provoke this behavior today by adding an advisor node to the CQUERY that prevent that a
resolution takes place against the workspace. The problem is that check-outs will still be performed instead of updates.
Buckminster already contains some code that makes a halfhearted attempt to manage what should happen when things already
exists (see org.eclipse.buckminster.core.mspec.ConflictResolution). It's not currently used by the workspace
materializer but that could easily change. Valid values are FAIL, KEEP, REPLACE, or UPDATE
We also have a way to collect statistics about the materialization (see
org.eclipse.buckminster.core.materializer.MaterializationSta tistics). It's only used by the "filesystem" and the
deprecated "site.mirror" materializer at present but it would serve us well for this purpose.
So what about this:
* We add a default ConflictResolution attribute to the resolution/materialization context (the RMContext)
* This attribute should default to KEEP but we add a command line option to control it to the import command and to the UI
* We make the resolver sensitive to this attribute in the following way:
KEEP - Do what it does today. I.e. resolve from the workspace/target platform (and be happy with what's there)
UPDATE - Don't resolve from the workspace/target platform. Always do an external resolution, then automatically update
instead of check-out if the component is already present. If it's not, do a normal check-out
REPLACE - Don't resolve from the workspace/target platform. Do an external resolution, then force a check-out (the
behavior we get with an advisor node that prevents workspace resolution).
FAIL - Fail hard if the component already exists at its destination.
* Use the MaterializationStatistics for all types of materializers. Using the IUpdateDeltaObserver that you suggested to
populate it might be a good approach for the workspace materializer when SVN/CVS type of readers. The p2 materializer
however, does not normally use use a reader to perform its updates. Instead, it uses the p2 engine to run a collect phase.
* Add a command line option to import that will cause the content of the MaterializationStatistics to be reported
I like the idea of a quick-as-possible probe and a dry run. I can see how the latter would be implemented.
Thomas Hallgren
> Greetings folks,
> concepts.
> is being updated.
> xml output
> Questions:
> Cheers,
> pete
Re: Buckminster updating / change-list generation [message #468347 is a reply to message #468334] Wed, 05 August 2009 04:15 Go to previous messageGo to next message
since this feature request orignates from the hudson integration, I'd
like to add something to the ideas to make it usable as easy as possible
within hudson.
If a user would use buckminster as 'SCM' in hudson, I'd have the plugin
to fidle around with the original resolve/import command to add the
parameters necessary to pipe the changelog output to a file that's well
known to the hudson plugin automatically.
Now I think it's likely that a user will use more than one component
request to populate the workspace. In that case I think it would be nice
if there'd a property for the change oberserver that controls if the
changelog file should be replaced if it is exisiting or if it should
append to the end of the file. That way several component requests will
end up in one accumulated change-log file that can be processed by the
hudson plugin.
Johannes
Thomas Hallgren schrieb:
> Hi Peter,
> a lot of sense. I have some suggestions that might help make it even
> between a check-out and and update automatically. For CVS/SVN we can
> CQUERY that prevent that a resolution takes place against the workspace.
> to manage what should happen when things already exists (see
> currently used by the workspace materializer but that could easily
> It's only used by the "filesystem" and the deprecated "site.mirror"
> So what about this:
> external resolution, then automatically update instead of check-out if
> external resolution, then force a check-out (the behavior we get with an
> Using the IUpdateDeltaObserver that you suggested to populate it might
> readers. The p2 materializer however, does not normally use use a reader
> phase.
> Regards,
> Thomas Hallgren
>> Greetings folks,
>> concepts.
>> Buckminster to allow for updating an existing workspace (presumably
>> via a cquery) and generating change-lists as a side effect. Such a
>> functionality would be useful for CI framework integration - the goal
>> being to maintain a workspace and bump it to the latest code,
>> recording changes, comments, authors, etc, then rebuild and run
>> tests. In my case, integration with Hudson is most immediate, but I
>> imagine that other CI frameworks would benefit from similar
>> functionality.
>> what is being updated.
>> with appropriate options to control placement, naming etc. of the
>> change-list xml output
>> Questions:
>> the update functionality?
>> sleeves once a direction is agreed upon.
>> Cheers,
>> pete
Re: Buckminster updating / change-list generation [message #468449 is a reply to message #468347] Wed, 05 August 2009 11:00 Go to previous messageGo to next message
Johannes,
Those suggestions make sense to me.
As I understand the SCM module specification from Hudson it is up to the
SCM module to "interpret" the change log and convert it into an
object-graph for Hudson to consume. This should ease conversion of
whatever log file format we end up with for Hudson.
-pete
Re: Buckminster updating / change-list generation [message #468457 is a reply to message #468334] Wed, 05 August 2009 11:19 Go to previous messageGo to next message
Hi Thomas,
I'm struggling with understanding that UPDATE/REPLACE should suppress both
workspace and target platform resolution. I have cqueries that ultimately
want to find target platform components for resolution. The cquery is not
materializing those elements (e.g. equinox plugins). If UPDATE suppresses
finding them at all, wouldn't the resolution fail in that case?
-pete
Re: Buckminster updating / change-list generation [message #468462 is a reply to message #468449] Wed, 05 August 2009 11:26 Go to previous messageGo to next message
Hi Peter,
that is how I understood it as well.
The SCM Plugin gets its chance to update the workspace and is
responsible for producing a changelog.xml in the workspace root so it
can get picked up by hudson.
So as long as there is a way to parse the output generated by
buckminster, it should be nothing but a simple transformation to the
format expected by hudson.
Johannes
Peter M. Murray schrieb:
> Johannes,
> -pete
Re: Buckminster updating / change-list generation [message #468466 is a reply to message #468462] Wed, 05 August 2009 11:39 Go to previous messageGo to next message
Hi Johannes,
I've read your past posts on this topic and hope I'm not intruding by
sticking my oar in.
We're eager to get this integration going as we've got the hood up on our
build/ci system currently and I'd like to go straight to Buckminster if we
can get this all ironed out.
-pete
Re: Buckminster updating / change-list generation [message #468493 is a reply to message #468466] Wed, 05 August 2009 12:26 Go to previous messageGo to next message
Hi Peter,
it's actually the opposite of intruding.
I started with the Hudson plugin because I needed a good buckminster
integration for Hudson to have some convincing arguments why we should
utilize Buckminster instead of the existing ant script hell. The more
help there is, the better will the integration be at the end, so your
help is very much appreciated.
I'd say the user base of the buckminster hudson plugin is rather tiny
right now, so I'm always happy to hear feedback from other users what's
currently hurting them and what features they are missing.
So please let me know about what else you'd need to satisfy your
company's needs.
btw: I asked Kohsuke about a buckminster component in the Hudson Issue
Tracker so I don't keep abusing the buckminster newsgroup (Sorry for
that, Thomas :) )
Should be in place soon I hope:
https://hudson.dev.java.net/issues/
Johannes
> Hi Johannes,
> sticking my oar in.
> our build/ci system currently and I'd like to go straight to Buckminster
> if we can get this all ironed out.
> -pete
Re: Buckminster updating / change-list generation [message #478675 is a reply to message #468457] Thu, 06 August 2009 07:24 Go to previous messageGo to next message
> Hi Thomas,
> both workspace and target platform resolution. I have cqueries that
> ultimately want to find target platform components for resolution. The
> cquery is not materializing those elements (e.g. equinox plugins). If
> UPDATE suppresses finding them at all, wouldn't the resolution fail in
> that case?
Right. Something is wrong with that idea :-). We cannot suppress target platform resolution since we don't know how the
TP was originally populated. Not in it's present shape.
The correct way to resolve this is probably to change how the p2 materializer configures the target platform definition.
Currently, we just use a "Directory" container and put everything there. This could be more sophisticated so that we
generate one or several "Software Site" containers that uses a slicer by default. A "Software Site" knows its origin and
knows how to perform an update. It would also give the user a better experience when accessing the TP definition in the
UI. Not sure how to go about listening to the update events though.
Perhaps you should defer the TP update for now?
Thomas Hallgren
Re: Buckminster updating / change-list generation [message #478680 is a reply to message #478675] Thu, 06 August 2009 07:39 Go to previous messageGo to next message
Hi Thomas,
I have a working prototype in my workspace of what we've been discussing.
Here's how it's functioning now:
1) -U indicates to the import command to perform an update. -O specifies
the log file output
2) The import command scribbles on the cquery to add an advisor node which
indicates useWorkspace=false for everything
3) The SVN reader always updates (switches, really, in case the url has
changed) if there is an existing svn checkout in the destination location.
4) The SVN reader generates log events to an observer
I used #2 instead of the ConflictResolution for two reasons:
- Minimize code changes to prototype (e.g. constructor bloat on the
RMContext subtypes)
- More importantly - I had to do something to make the target platform
resolution step not look at the workspace. Since I wasn't sure how best
to do that, I put the check & filters right in the findBest* methods by
asking the cquery.useWorkspace(). Those methods don't have an RMContext
available
This really was an attempt to feel out the edges of the task more than
implement a "right" approach - so we can totally rework it. It really
hinges on what is the right fix for the useWorkspace issue. I've posted a
mininimal script to reproduce this issue in a separate posting.
-pete
Re: Buckminster updating / change-list generation [message #478705 is a reply to message #478680] Thu, 06 August 2009 09:17 Go to previous messageGo to next message
Wow!
This sounds great Peter. Some comments inline. I do understand that what you have is a prototype and as such I think
this sounds really good.
> Hi Thomas,
> discussing. Here's how it's functioning now:
> specifies the log file output
OK.
> which indicates useWorkspace=false for everything
Is this implemented in the generic part of the SVN reader (i.e. the part used for both Subclipse and Subversive)?
What is needed to get the same type of events from CVS? Is that easy to achieve?
> RMContext subtypes)
Couldn't you just add a setter/getter for this attribute to the RMContext? The initial value would be KEEP.
> available
I think they do actually. The IVersionFinder has a getQuery() method. It returns the NodeQuery which in turn has a
getContext() method.
> a mininimal script to reproduce this issue in a separate posting.
I'll have a look at that when I'm back from vacation (Monday).
Thomas Hallgren
Re: Buckminster updating / change-list generation [message #478947 is a reply to message #478705] Fri, 07 August 2009 11:33 Go to previous messageGo to next message
Current status update on Buckminster update / polling prototype
functionality:
- implemented the update using the ConflictResolution attribute on the
RMContext.
- the NodeQuery.useWorkspace() method now checks for advisornodes as well
as checking the RMContext for ConflictResolution.KEEP or
ConflictResolution.FAIL.
- (hack?) fixed the problem of useWorkspace not functioning by checking
NodeQuery.useWorkspace() in the getBest*() static methods on
EclipsePlatformReaderType and filtering response accordingly.
- Subversive Reader implementation now checks and if subversion management
directory exists and performs a switch rather than a checkout (could push
up some logic to generic svn superclass for both Subversive and Subclipse)
Polling prototype implementation:
- added -p/--poll argument to import to perform a noop query if an update
is needed
- added two booleans to RM context to support this
-- m_poll - indicates if this RM cycle is a polling cycle
-- m_needsUpdate - indicates if one or more readers registered that it
needs to update
- import command logs INFO with result and process return code = 999 if
needs update (is this the best way to communicate that state?)
- implemented for Subversive the polling functionality
Possible improvements:
- stop the polling as first reader encounters desired update
- others?
I've also taken a pass at the Hudson end, Johannes. I've introduced an
SCM implementation that knows how to run buckminster to poll one or more
cqueries and use the update to perform incremental updates with change log
reporting.
Now that the prototype seems to be up and running - any suggestions on
improving the architecture / implementation?
pete
Re: Buckminster updating / change-list generation [message #478953 is a reply to message #478947] Fri, 07 August 2009 12:04 Go to previous messageGo to next message
Hi Peter,
that sounds fantastic so far.
Did you implement the hudson part as a separate plugin or as an
extension to the current plugin?
Are you able to share what you've got so far? I'd be very much
interested to have a look at your work.
Johannes
Re: Buckminster updating / change-list generation [message #478960 is a reply to message #478953] Fri, 07 August 2009 12:44 Go to previous messageGo to next message
Hi Johannes,
I did extend your work on the Hudson Buckminster integration plugin to add
the SCM component. I was able to leverage the configuration information
as well as the CommandLineBuilder (with some mods).
How would be the best way to share this stuff? I could zip the sources
and send if you like. Email me @ pete <at> pmurray < dot > com . if
that sounds good.
I jumped through a few hoops to get new individual plugins into a
buckminster installation to test the Hudson integration. I ended up
manually exporting the changed plugins from the PDE into the bucky
installation directory using a fixed qualifier replacement and then
editing the config.ini to point to them. Is there a better way?
-pete
Re: Buckminster updating / change-list generation [message #478972 is a reply to message #478947] Fri, 07 August 2009 13:41 Go to previous messageGo to next message
Hi Peter,
This sounds very positive. I think you should open a bugzilla where you can describe your efforts and also attach
patches that we can look at. My guess is that your contribution will be considered non trivial so I must prepare for IP
approval from the Eclipse EMO before your work can be accepted into our code-base. No big deal really, but it means that
you must assert that you are the author behind it all and that your employer has no objections to the fact that you
contribute your work to us under EPL.
Some comments and questions inline.
> functionality:
> RMContext.
> well as checking the RMContext for ConflictResolution.KEEP or
And ConflictResolution.UPDATE ?
Sounds OK to me.
> management directory exists and performs a switch rather than a checkout
> (could push up some logic to generic svn superclass for both Subversive
> and Subclipse)
If the meta-data is the same, that would be great. The addition of this check is good news. I'm surprised no one has
complained about it not being done earlier. This also relates to the issue of qualifier replacement in combination with
local reader that has been brought up by both Carsten Reckord and Chase Wolfinger on this newsgroup earlier.
What happens if the switch isn't possible due to lack of needed credentials? Does it check if a repository has been
set-up in the workspace (like it does in the GenericSession constructor) and make use of its credentials?
I think it's OK to fail the update with an exception unless a switch can be performed.
> update is needed
> needs to update
A non zero return code usually means failure. If hudson has some protocol for this then I propose we use that.
> - others?
This is plenty for now. Next steps will undoubtedly involve CVS but perhaps we can get more people involved once the
needed API changes has crystallized.
I'm also thinking about how we can improve the target platform story so that we can include P2 updates to it here.
You don't mention how the update observer collects/reports events. Have you done anything with
MaterializationStatistics? I looked at that class and realized that in order to collect it must be complemented with a
list of files or something. It only collects component identifiers in its current shape.
Thomas Hallgren
Re: Buckminster updating / change-list generation [message #478973 is a reply to message #478972] Fri, 07 August 2009 14:06 Go to previous messageGo to next message
Hi Thomas,
Some responses inline below:
Thomas Hallgren wrote:
> Hi Peter,
Shouldn't be a problem.
>> functionality:
>> RMContext.
NodeQuery.useWorkspace() returns true if
a) getComponentQuery().useWorkspace(getComponentRequest()) // as before
AND
b) the context's conflictResolution is either KEEP or FAIL
It returns false if the conflictResolution is UPDATE or REPLACE
> Sounds OK to me.
>> and Subclipse)
I'll check on the GenericSession constructor - currently nothing special
is being done for that case, so I assume it would fail.
performed.
>> update is needed
>> needs to update
Currently the Hudson integration runs buckminster in a separate VM - thus
the process return code being a convenient boolean communication. Parsing
the output would be another route - or generating some kind of output file
to parse. I can imagine that a return-code boolean indicator might be
useful for calling the update-probe from a shell script as well.
>> - others?
That would be cool! Then I could totally buckminsterize my dependency
network for CI with Hudson!
done anything with
current shape.
Yes - I didn't use the MaterializationStatistics class at this point
without further conference with you. I implemented a very simple
IChangeLogger interface which gets setup on the MaterializationContext by
the import command. There are Null and XML implementations.
One thought is that the MaterializationStatistics.m_updated field track a
list of "ComponentChange" objects each of which tracks timestamp, author,
comments and an (optional?) list of changed paths (each of which is an
action (Add, modify, delete, replace) and a file path). This would track
the update information and could be serialized afterward by the import
process. Does that sound right to you, Thomas?
> Regards,
> Thomas Hallgren
Re: Buckminster updating / change-list generation [message #478976 is a reply to message #478973] Fri, 07 August 2009 14:17 Go to previous message
> AND
Got it :-)
> thus the process return code being a convenient boolean communication.
> Parsing the output would be another route - or generating some kind of
> output file to parse. I can imagine that a return-code boolean
> indicator might be useful for calling the update-probe from a shell
> script as well.
True. I think you and Johannes are best suited to come up with a solution for this. Whatever you decide will be OK.
>> Have you done anything with MaterializationStatistics? I looked at
>> complemented with a list of files or something. It only collects
> by the import command. There are Null and XML implementations.
> a list of "ComponentChange" objects each of which tracks timestamp,
> author, comments and an (optional?) list of changed paths (each of which
> is an action (Add, modify, delete, replace) and a file path). This
> would track the update information and could be serialized afterward by
> the import process. Does that sound right to you, Thomas?
Yes. That sound just right.
- thomas
Previous Topic:useWorkspace not functioning?
Next Topic:Build complains about missing dependencies after import
Current Time: Thu Sep 04 10:00:02 EDT 2025
Powered by FUDForum. Page generated in 0.09733 seconds
