Home » Archived » Service Component Architecture (SCA) Tools » Service term in SCA
Service term in SCA [message #468212] Tue, 04 August 2009 10:52 Go to next message
Originally posted by: michael.gebhart.googlemail.com
I have a problem with the term of service in SCA. What is meant with a
service here? Is it a service in terms of a service that should be
published within a service inventory (as for instance UDDI) that other
interested parties can use it? Should these services be designed that
they can be used from other parties too?
Or is this service for internal use only? This would mean that it is
simply an interface for a component?
Best regards
Michael
Re: Service term in SCA [message #468355 is a reply to message #468212] Wed, 05 August 2009 04:44 Go to previous messageGo to next message
Michael Gebhart a écrit :
> Best regards
> Michael
Hi Michael,
I think that your misunderstanding is prompted by the fact that SCA
wants to unify 2 visions of distributed systems: (a) the
architecture-based and (b) the service-oriented visions.
In vision (a), a distributed system is organized as an architecture
built as an assembly of components with well defined interfaces. In
vision (b), a distributed system is organized as a set of independent
services used by different clients. Moreover, the main idea behind the
term service is the possibility to re-use them (services must be
designed for that : autonomy, loose coupling, stateless,...) and to
aggregate them to construct other services. You can find more
information here [0] (page 5) and an interesting article about service
granularity here [1].
So, to answer your question, SCA services
- can be used by other interested parties : a service promoted at the
composite level with a web service binding can be used by non SCA clients,
- can be used to construct an assembly of components. In this case, the
service can or not (internal use only) be promoted outside the composite.
Stephane Drapeau
Obeo
[0]:
http://www.scorware.org/projects/rsc/deliverables/SCOrWare-L 1-Specifications-V2-0-20090414_pdf?action=download&nodec orator
[1]:
http://www.ibm.com/developerworks/webservices/library/ws-soa -granularity/
Re: Service term in SCA [message #468390 is a reply to message #468355] Wed, 05 August 2009 07:33 Go to previous messageGo to next message
thanks for your answer. I try to formalize my question in a differnt way:
Assuming a distributed system developed with SCA (S1). We have 5
components (A, B, C, D, E).
Now, another system is developed, also with SCA (S2). It requires
functionality that is already implemented in S1, more precisely
component A and B.
What happens? The developer who develops S2 does not know about A and B.
They are not provided as Webservice and are not registered within a
service registry.
How does the developer find A and B? Should A and B be exposed as web
service from the beginning and published into a service registry?
Or are they exposed as web service only on demand? But in this case: How
does the developer know about A and B?
Next problem: A third system has to be developed, S3. It requires
functionality that is part of S1, but not A, B, C, D or E.
The developer of S1 declares himself ready to comply with exposing the
required functionality as a component F. This can be used by S1 and S3.
But there are other ways possible: F could also be part of S3 and S1
uses this component as part of S3. Or should F be a completely new
application? What is the right way to expose shared functionality?
Best regards
Michael
Re: Service term in SCA [message #468397 is a reply to message #468390] Wed, 05 August 2009 08:14 Go to previous messageGo to next message
The SCA specifications don't address these problems.
If a developer wants to be aware of the services already developed and
how to re-use them, then, a service repository or something like that is
needed.
The SCOrWare project has developed a semantic trader [0] (page 65),
which, I think, can be an interesting solution. We can imagine using it
at development time or at runtime.
Stephane
[0]:
> component A and B.
> service registry.
> Best regards
> Michael
Re: Service term in SCA [message #468398 is a reply to message #468397] Wed, 05 August 2009 08:19 Go to previous messageGo to next message
You can easily add SAWSDL annotations on composite files with the
Composite Designer [0].
Stephane
[0]: http://wiki.eclipse.org/STP/SCA_Project/Ontology
> needed.
> Stephane
> [0]:
>> Hi,
>> component A and B.
>> B. They are not provided as Webservice and are not registered within
>> a service registry.
>> How does the developer know about A and B?
>> Best regards
>> Michael
Re: Service term in SCA [message #468431 is a reply to message #468390] Wed, 05 August 2009 09:58 Go to previous messageGo to next message
Hi Mickael,
> component A and B.
> service registry.
A and B are components.
If their services are not promoted, they cannot be used outside the
composite.
If they are promoted, then they can be used by any client.
The way this client will find these services is undefined (registry or
another solution).
That would be the best solution if you want to use existing products.
Another solution is to implement an SCA registry, which will distinguish
composite services from component services.
As Stéphane mentionned it, the SCOrWare project proposed a prototype of
semantic trader and registry to deal with this case.
If the feature is not exposed as a service, then you cannot know it.
Unless you developped the system (S1) yourself.
That's the basis of SOA: you can only know and rely on the interface
(and possibly on meta-data if you have a registry).
Exposing a feature as a component in SCA makes no sense.
You expose services (=> a component with at least one service that will
be promoted at the composite level).
One solution could be to make F a composite.
You may have one component F' in (S1), having the composite F as the
implementation, and F'' in (S3), having another component with the same
implementation F.
The usual solution will be to create a new component having the same
implementation.
In general, you do not share components in SCA. But you can share
interfaces and / or implementations. The goal of component types and SCA
Java annotations is to facilitate the reuse of implementations in SCA. A
component by itself is only "the configuration of an implementation"
(that's what is stated by the OSOA specification).
Eventually, the governance of SCA artifacts is not part of the SCA
specification. For the moment, you can only rely on the SOA governance
principles (meaning interface + meta-data).
Vincent.
Vincent Zurczak
EBM WebSourcing
+33 (0) 4 38 12 91 72
Re: Service term in SCA [message #479238 is a reply to message #468431] Mon, 10 August 2009 08:11 Go to previous messageGo to next message
thanks for your answers.
Thus, in general it can be said that services in SCA do not have
anything in common with the services within an SOA unless they are
exposed as webservices.
Services within an SOA are governed by an SOA governance. This is not
the case for services within an SCA application.
Thus, SCA is more something like EJB++. Components with different
languages and different inerfaces. But only as webservice and part of
the SOA governance it is part of an entire SOA solution.
Best regards
Michael
Re: Service term in SCA [message #479263 is a reply to message #479238] Mon, 10 August 2009 09:41 Go to previous message
I would not say that.
Web services by default do not imply governance.
You can see web services only as technical services. You do not have to
use a registry when you create a web service. It can work without it.
Governance is part of best practices.
You can apply these best practices to SCA services too.
You can use SCA for your SOA. But that is not mandatory.
You can do SOA without SCA and use SCA without making SOA. There is a
small space frame for having both at the same time.
Vincent.
> Best regards
> Michael
Vincent Zurczak
EBM WebSourcing
Re: Service term in SCA [message #575467 is a reply to message #468212] Wed, 05 August 2009 04:44 Go to previous message
> Best regards
> Michael
Hi Michael,
Stephane Drapeau
Obeo
[0]:
[1]:
Re: Service term in SCA [message #575500 is a reply to message #468355] Wed, 05 August 2009 07:33 Go to previous message
component A and B.
service registry.
Best regards
Michael
Re: Service term in SCA [message #575528 is a reply to message #468390] Wed, 05 August 2009 08:14 Go to previous message
needed.
Stephane
[0]:
> component A and B.
> service registry.
> Best regards
> Michael
Re: Service term in SCA [message #575544 is a reply to message #468397] Wed, 05 August 2009 08:19 Go to previous message
Stephane
> needed.
> Stephane
> [0]:
>> Hi,
>> component A and B.
>> a service registry.
>> Best regards
>> Michael
Re: Service term in SCA [message #575568 is a reply to message #468390] Wed, 05 August 2009 09:58 Go to previous message
Hi Mickael,
> component A and B.
> service registry.
composite.
another solution).
implementation F.
implementation.
Vincent.
Vincent Zurczak
EBM WebSourcing
Re: Service term in SCA [message #575723 is a reply to message #468431] Mon, 10 August 2009 08:11 Go to previous message
Best regards
Michael
Re: Service term in SCA [message #575743 is a reply to message #479238] Mon, 10 August 2009 09:41 Go to previous message
Vincent.
> Best regards
> Michael
Vincent Zurczak
EBM WebSourcing
Previous Topic:Missing service, reference and property name
Next Topic:Missing 'Generate Java Skeleton' function
Current Time: Sun May 11 12:31:08 EDT 2025
Powered by FUDForum. Page generated in 0.04853 seconds
