Home » Modeling » EMF » Cancellation of XMI load/save
Cancellation of XMI load/save [message #467867] Mon, 03 August 2009 05:04 Go to next message
Hi, i would to provide cancellation of long-running XMIResource save
operation.
I noticed this discussion :
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 2862.html
But it isn't very clear to me.
Is progress monitoring supported (as indicated in the javadoc) and if
yes, what is the procedure to pass the IProgressMonitor to the save method ?
Thanks !
PS : Sorry for bad english.
Re: Cancellation of XMI load/save [message #467936 is a reply to message #467867] Mon, 03 August 2009 08:15 Go to previous messageGo to next message
Romain,
There is currently no support for progress monitoring of load or save.
XSDResourceImpl supports it for load so you could look at that example,
but I'm not sure what canceling save would mean: given that the document
could be partly written out to the file system it sounds like perhaps a
very bad thing to do.
> operation.
> method ?
> Thanks !
Re: Cancellation of XMI load/save [message #467943 is a reply to message #467936] Mon, 03 August 2009 08:36 Go to previous messageGo to next message
Hi Ed,
If the user cancels the save operation, i would have deleted the
partially written file of course :)
Thanks for your response.
Ed Merks a écrit :
> Romain,
>> operation.
>> method ?
>> Thanks !
Re: Cancellation of XMI load/save [message #467968 is a reply to message #467943] Mon, 03 August 2009 09:37 Go to previous messageGo to next message
Romain,
And you'd have the restore the original contents or write to a temporary
file that you rename. If multiple resources are involved, you'd want to
restore them all. You really have resources that are so big that
clients might change their mind part way during saving them? It's hard
to imagine...
> Hi Ed,
> Ed Merks a écrit :
>> Romain,
>> save. XSDResourceImpl supports it for load so you could look at that
>> example, but I'm not sure what canceling save would mean: given that
>> the document could be partly written out to the file system it sounds
>> like perhaps a very bad thing to do.
>>> operation.
>>> if yes, what is the procedure to pass the IProgressMonitor to the
>>> save method ?
>>> Thanks !
Re: Cancellation of XMI load/save [message #467975 is a reply to message #467968] Mon, 03 August 2009 09:45 Go to previous message
Well, that's just a "bonus" feature :-D but as the user can cancel the
process during model creation, it would be logic to be able to cancel
the serialization (usually 500 MB models or more, which can take several
minutes : i use the XMLResource.OPTION_FLUSH_THRESHOLD &
XMLResource.OPTION_USE_FILE_BUFFER options).
Well, after reflexion, I already handle cancellation during model
creation, we can consider that the user had time to change his mind
before serialization.
Thanks.
Ed Merks a écrit :
> Romain,
> to imagine...
>> Hi Ed,
>> Ed Merks a écrit :
>>> Romain,
>>>> operation.
>>>> save method ?
>>>> Thanks !
Previous Topic:[Teneo] Problems with Teneo Gmf Mindmap Tutorial
Next Topic:Multivalued feature names
Current Time: Sun Jul 27 03:32:48 EDT 2025
Powered by FUDForum. Page generated in 0.04249 seconds
