Home » Modeling » GMF (Graphical Modeling Framework) » Problem with compartments
Problem with compartments [message #235037] Wed, 01 July 2009 17:04 Go to next message
I'm trying to create an element with one compartment like the Topic
element in the Tutorial Part 2, so I followed the Tutorial, it worked well
on the example, but when I tried to do with my own diagram it didn't work,
when I drop some element into my package compartment, I can't move o
resize the element inside the package, they go automatic to the corner of
the compartment when I drop it in the compartment. I tried to change the
layout of my packagefigure but it didn't work either.
In my .graph configuration I used the same of the tutorial. A Figure
Descriptor with a Rounded Rectangle using the Flow Layout False and some
labels.
And I created a Compartment named taskCompartment with my PackageFigure as
Figure.
In the .map, I let the wizard create the package node, and put the other
by my self.
Frist I created a compartment mapping on the Package Node and associate it
with the compartment of .graph.
After that I inserted a Child Reference on the Package Node and a Node
Mapping on it.
On the Child reference I put this:
-Child : Node Mapping <Task/Task>
-Children Feature : EMPTY
-Compartment Feature : Compartment Mapping <taskCompartment>
-Containment Feature : taksReference : Taks
-Referenced Child : EMPTY
On the Task's node:
Element : Task
Diagram Node : Node Task(TaskFigure)
Tool : Creation Tool Task
I'm sure that I miss something, but I didn't find it following the
tutorial again.
I can send by e-mail two screenshots to show what is the problem if you
didn't catch.
Re: Problem with compartments [message #235099 is a reply to message #235037] Thu, 02 July 2009 07:21 Go to previous messageGo to next message
Hello Fabricio,
Try setting "isListLayout" property of corresponding GenCompartment to "false"
in .gmfgen model and regenerate code.
Alex Shatalin
Re: Problem with compartments [message #235246 is a reply to message #235099] Fri, 03 July 2009 09:49 Go to previous messageGo to next message
It's working now.
Now I would like to know if I can set a default size to the compartment,
because if I set the flow layout to the package, the compartment appears
too little and i need to find where is it on the figure.
Re: Problem with compartments [message #467856 is a reply to message #235246] Mon, 03 August 2009 04:15 Go to previous messageGo to next message
Hi Fabricio, Alex
Actually, I have the same problem. If I use Flow Layout, compartment size
is too small. In earlier versions of GMF everything works OK.
I use Eclipse Galileo and GMF 2.2.0.v20090114.
Is this a bug?
Please, I need some workaround.
Sinisa
Re: Problem with compartments [message #467930 is a reply to message #467856] Mon, 03 August 2009 08:09 Go to previous messageGo to next message
I don't know if it's a bug or feature, but I use StackLayout as a
workaround.
There's only a label for the name and the compartment in my node.
Now the compartment fills the whole node, so its even possible to add a
sub-node over the label.
But maybe there's a better way.
Tobias
P.S.:
I'm using GMF 2.1.3
Sinisa wrote:
> Hi Fabricio, Alex
> Is this a bug?
> Regards
> Sinisa
Re: Problem with compartments [message #467952 is a reply to message #467856] Mon, 03 August 2009 08:52 Go to previous messageGo to next message
Hello Sinisa,
I think GMF-generated figure code was changed a bit. In order to layout things
properly you have to use corresponding layouts/layout constraints in .gmfgraph
model.
This is not a bug - GMF is generateing a code exactly like it is specified
in .gmfgen model. I suppose in the past a bit different (incorrect) code
was generated.
Alex Shatalin
Re: Problem with compartments [message #467953 is a reply to message #467930] Mon, 03 August 2009 08:54 Go to previous messageGo to next message
Hello Tobias,
It's good idea to use different layout in .gmfgraph model. I suppose if it
is important for this figure you have to even add more panes there.. It's
all about properly layouting child figures..
Alex Shatalin
Re: Problem with compartments [message #467974 is a reply to message #467952] Mon, 03 August 2009 09:39 Go to previous message
Tobias, Alex
Thank you guys very much.
Stack Layout working a job for me right now, but still remains a problem
with adding node over the label.
I am relatively new in this GMF story, probably there are many ways to
solve this problem (probably a combination of layouts), but I still don't
know how to do it. I will work on it.
Thank you again.
Sinisa
Previous Topic:Property section problem : unable to load class
Next Topic:How get gmf editor export image when editor closed !
Current Time: Mon Jul 28 11:02:15 EDT 2025
Powered by FUDForum. Page generated in 0.19205 seconds
