Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Several Images in one table cell
Several Images in one table cell [message #467611] Wed, 01 February 2006 16:35 Go to next message
I would like to add more then one image to a table cell. I couldn't find any hints how to do that. All I can do is add one image and some text, but not more then one image.
Any idea?
Thanks, Daniel
Re: Several Images in one table cell [message #467620 is a reply to message #467611] Wed, 01 February 2006 16:53 Go to previous messageGo to next message
I am unsure if a solution for the SWT Table exists.
If you choose to use KTable, this is possible.
However, you would have to implement your own renderer (which gives you
maximum flexibility since you can directly access the GC).
> Any idea?
> Thanks, Daniel
Re: Several Images in one table cell [message #467789 is a reply to message #467620] Mon, 06 February 2006 13:56 Go to previous messageGo to next message
Originally posted by: daniel.flueck.whitesands.ch
Ok, thanks. I'll have a look at KTable.
But some more questions arised in the last days:
1) If I use different images of different size in the same table, all
images are resized to the first one set in the table. Is there any
way around that?
2) As soon as I use images in any column, my first column gets some
extra space for an image. Even if I never set an image in the first
column. Is this common behaviour?
Thanks, Daniel
>> Any idea?
>> Thanks, Daniel
Re: Several Images in one table cell [message #467793 is a reply to message #467789] Mon, 06 February 2006 14:38 Go to previous message
Originally posted by: hoeggerand.post.ch
Hi Daniel
1) This issue is handled by your hacking tricks. Compute the cell size
out of your images and set it to the table.
2) This is a well known issue (it is also not possible to adjust the
first column SWT.CENTER). My hint is to not use the first column. Set
the first column to a width of 0 and fill your data up from the second
column
To your source question:
Do not waste any time into displaying more than one img in one column,
it is not provided.
cu andy
> way around that?
> Thanks, Daniel
>> you maximum flexibility since you can directly access the GC).
>>> Any idea?
>>> Thanks, Daniel
Previous Topic:Image button with text
Next Topic:Embedding objects in styledtext - Snippet 212 questions
Current Time: Fri Jul 25 21:46:06 EDT 2025
Powered by FUDForum. Page generated in 0.04067 seconds
