Home » Eclipse Projects » Standard Widget Toolkit (SWT) » CTabFolder and TabFolder
CTabFolder and TabFolder [message #467504] Wed, 01 February 2006 03:10 Go to next message
I have found when using Windows XP theme with Eclipse the
TabFolder/TabItem use a nice highlighting scheme as Windows XP does (see
second page in New Java Project wizard). But in our application, which
is also running on Windows XP theme, we must use CTabFolder/CTabItem (as
a container for MultiPageEditorPart) and we don't get these nice tabs
highlighting. Can anybody shed some light onto this or hint how to get
CtabFolder to look like TabFolder?
TIA,
Ihor
Re: CTabFolder and TabFolder [message #467598 is a reply to message #467504] Wed, 01 February 2006 12:01 Go to previous messageGo to next message
> TIA,
> Ihor
Check out this page. It's not in english, but the code is! :)
http://yoichiro.cocolog-nifty.com/eclipse/2004/10/ctabfolder .html
On it, you will find a code snippet for setting the colors of the
CTabFolder to match the system colors. Not sure if this is what you were
looking for, but it makes a very good looking CTabFolder that depends on
the OS colors.
// System colored CTabFolder
Display display = Display.getCurrent();
  Color titleForeColor =
    display.getS ystemColor(SWT.COLOR_TITLE_FOREGROUND);
  Color titleBackColor1 =
    display.getS ystemColor(SWT.COLOR_TITLE_BACKGROUND);
  Color titleBackColor2 =
    display.getS ystemColor(SWT.COLOR_TITLE_BACKGROUND_GRADIENT);
  tabFolder.setSelectionForeground(tit leForeColor);
  tabFolder.setSelectionBackground(
    new Color[] {titleBackColor1,
titleBackColor2},
    new int[] {100},
    true
Re: CTabFolder and TabFolder [message #467604 is a reply to message #467598] Wed, 01 February 2006 14:07 Go to previous messageGo to next message
Cool. It worked! This is something I was looking for for a while.
Thanks.
Sincerely,
Stan
"Adam Kumpf" <kumpf@mit.edu> wrote in message
news:8db04b21699d5a05ec0c75be8e21be1e$1@www.eclipse.org...
>> second page in New Java Project wizard). But in our application, which is
>> also running on Windows XP theme, we must use CTabFolder/CTabItem (as a
>> TIA,
>> Ihor
> the OS colors.
> &#12288;&#12288;Color titleForeColor =
> &#12288;&#12288;&#12288;&#12288;display.getS ystemColor(SWT.COLOR_TITLE_FOREGROUND);
> &#12288;&#12288;Color titleBackColor1 =
> &#12288;&#12288;&#12288;&#12288;display.getS ystemColor(SWT.COLOR_TITLE_BACKGROUND);
> &#12288;&#12288;Color titleBackColor2 =
> &#12288;&#12288;&#12288;&#12288;display.getS ystemColor(SWT.COLOR_TITLE_BACKGROUND_GRADIENT);
> &#12288;&#12288;tabFolder.setSelectionForeground(tit leForeColor);
> &#12288;&#12288;tabFolder.setSelectionBackground(
> &#12288;&#12288;&#12288;&#12288;new Color[] {titleBackColor1,
> titleBackColor2},
> &#12288;&#12288;&#12288;&#12288;new int[] {100},
> &#12288;&#12288;&#12288;&#12288;true
> &#12288;&#12288;);
Re: CTabFolder and TabFolder [message #467609 is a reply to message #467604] Wed, 01 February 2006 15:45 Go to previous messageGo to next message
This is not what I'm looking for. Windows XP theme has a thin golden
strip on the top of the active tab, and when you move your mouse cursor
over inactive tabs they will get this thin golder strip as well. SWT
TabFolder as a native peer supports Windows XP theme, but CTabFolder
(pure Java) does not.
This article will give you an idea of what I'm looking for.
http://www.javalobby.org/java/forums/t16488.html
which I think is not possible with current SWT.
Ihor
> Thanks.
> Sincerely,
> Stan
>>>TIA,
>>>Ihor
>>the OS colors.
Re: CTabFolder and TabFolder [message #467772 is a reply to message #467609] Mon, 06 February 2006 10:30 Go to previous message
CTabFolder is not meant to be just like a native tabfolder with added
capabilities. CTabFolder is meant to be part of the "branding" of Eclipse
giving it a customized look.
"Ihor Strutynskyj" <eclipse-news@telus.net> wrote in message
news:drr6l7$s4g$1@utils.eclipse.org...
> This is not what I'm looking for. Windows XP theme has a thin golden strip
> on the top of the active tab, and when you move your mouse cursor over
> inactive tabs they will get this thin golder strip as well. SWT TabFolder
> as a native peer supports Windows XP theme, but CTabFolder (pure Java)
> does not.
> Ihor
>> Thanks.
>> Sincerely,
>> Stan
>>>>TIA,
>>>>Ihor
>>>the OS colors.
Previous Topic:Hexagon
Next Topic:programmatically limiting scale drag
Current Time: Wed Jul 23 20:36:24 EDT 2025
Powered by FUDForum. Page generated in 0.05338 seconds
