Home » Eclipse Projects » Rich Client Platform (RCP) » Adding Menu Items thru Plugin.xml
Adding Menu Items thru Plugin.xml [message #467582] Tue, 08 May 2007 07:51 Go to next message
Originally posted by: arshia.yahoo.co.in
Can you please let me know how to add actions to the menubar of our
widget through plugin.xml
Thanks in advance,
Arshia
Re: Adding Menu Items thru Plugin.xml [message #467584 is a reply to message #467582] Tue, 08 May 2007 08:33 Go to previous messageGo to next message
Hi...
Add the org.eclipse.ui.actionsets plug-in under the Extensions
tab....create a new actionset upon that and then create a menu and an
action upon that actionset...don forget to give the menubar path in the
action attributes...
this should work for u....
Re: Adding Menu Items thru Plugin.xml [message #467589 is a reply to message #467584] Tue, 08 May 2007 09:17 Go to previous messageGo to next message
Can u send some snippet of this.. actually I am new to eclipse
Re: Adding Menu Items thru Plugin.xml [message #467610 is a reply to message #467589] Tue, 08 May 2007 19:53 Go to previous messageGo to next message
In that case, read these:
http://www.eclipse.org/articles/article.php?file=Article-act ion-contribution/index.html
http://eclipse.org/articles/Article-RCP-1/tutorial1.html
http://eclipse.org/articles/Article-RCP-2/tutorial2.html
http://eclipse.org/articles/Article-RCP-3/tutorial3.html
Alex.
Re: Adding Menu Items thru Plugin.xml [message #467612 is a reply to message #467610] Wed, 09 May 2007 00:26 Go to previous messageGo to next message
Thanks for reply..
My view is sampleView and I want to add exit action to this view. I have
written the following in plugin.xml to add my action to the menubar of my
view.
<extension point="org.eclipse.ui.viewActions">
<viewContribution
id="SampleView"
targetID="sample.SmapleView">
<action
id="org.eclipse.ui.articles.action.contribution.view.action1 "
label="Exit"
icon="icons/exit.png"
tooltip="Tooltip for View Action 1"
menubarPath="additions"
class="sample.ExitAction"
enablesFor="*">
</action>
</viewContribution>
</extension>
it didn't add any action to the menu bar.. What exactly to give as
manubarpath in the above code..
Thanks in advance,
Arshia Jamal
Re: Adding Menu Items thru Plugin.xml [message #467621 is a reply to message #467612] Wed, 09 May 2007 04:09 Go to previous messageGo to next message
When you add XML to EZ, it eats it so you can't see what you've added:
http://www.eclipsezone.com/eclipse/forums/m92145447.html#921 45447
You need to surround XML text with (xml) and (/xml), except using [] instead of ().
Alex.
Re: Adding Menu Items thru Plugin.xml [message #467623 is a reply to message #467621] Wed, 09 May 2007 04:24 Go to previous messageGo to next message
here is the code ,
<xml>
<viewContribution
id="com.sequenom.everest.ui.CustomerView"
targetID="com.sequenom.everest.ui.project.CustomerView">
<action
label="Exit"
class="com.sequenom.everest.ui.project.ExitAction"
enablesFor="*">
</action>
</viewContribution>
</extension>
</xml>
Re: Adding Menu Items thru Plugin.xml [message #467625 is a reply to message #467623] Wed, 09 May 2007 04:28 Go to previous messageGo to next message
here is the code ,
(xml)
<extension point="org.eclipse.ui.viewActions"> <viewContribution
<action
label="Exit" icon="icons/exit.png"
enablesFor="*">
</action> </viewContribution> </extension>
(/xml)
Re: Adding Menu Items thru Plugin.xml [message #467638 is a reply to message #467625] Wed, 09 May 2007 08:32 Go to previous messageGo to next message
Sadly, that didn't seem to work. What about translating your &lt; and &gt; to something else like () so that it doesn't get munged? Much more Lisp-like :-)
Alex.
Re: Adding Menu Items thru Plugin.xml [message #467691 is a reply to message #467638] Thu, 10 May 2007 01:25 Go to previous messageGo to next message
What is the wrong with this code in plugin.xml to add actions to the view
menubar,
I have just removed '<' tag from the actual code and pasted here
viewContribution
action
enablesFor="*">
/action>
/viewContribution>
/extension>
Thanks in advance,
Arshia
Re: Adding Menu Items thru Plugin.xml [message #467731 is a reply to message #467691] Thu, 10 May 2007 09:29 Go to previous messageGo to next message
Arshia Jamal wrote:
> view menubar,
> viewContribution id="com.sequenom.everest.ui.CustomerView"
> action
> enablesFor="*">
> /action>
> /viewContribution>
> /extension>
This should, in theory, add the action to your view dropdown menu (the
little triangle in the top right corner of your view title).
Is that not where it went? Or is it you want to add the action to the
main menu bar (like File, Edit, Help, etc).
Later,
PW
Re: Adding Menu Items thru Plugin.xml [message #467818 is a reply to message #467731] Fri, 11 May 2007 00:12 Go to previous messageGo to next message
Thanks for the reply.. I want to add the action to the menubar,toolbar
of my view not to the main menubar and main toolbar...
<viewContribution id="com.sequenom.everest.ui.CustomerView"
targetID="sample.CustomerView">
<action
enablesFor="*">
</action>
</viewContribution>
</extension>
How to add the action to my view dropdown menu (the little triangle in the
top right corner of your view title). Please help me... Just few dyas back
I stared exploring all these..
Arshia Jamal
Re: Adding Menu Items thru Plugin.xml [message #712674 is a reply to message #467731] Sun, 07 August 2011 11:37 Go to previous messageGo to next message
I have the same problem in plugins.But anyhow did you check the targetID attribute value.Check your xml file that your targetID is correct or not.If it is correct then there is something wrong in your java code.Please if you correct it by this way then inform me also.
/Regards
arifihsan50@yahoo.com
Re: Adding Menu Items thru Plugin.xml [message #712676 is a reply to message #467818] Sun, 07 August 2011 11:41 Go to previous message
Hi Again!
If you want to add your actions to menu bar or toolbar then you have to use the extension point org.eclipse.ui.actionSets.
/ihsan
Previous Topic:Update RCP without UpdateManager
Next Topic:Dynamic menu contribution doesn't show up in a toolbar
Current Time: Wed Jul 23 12:15:11 EDT 2025
Powered by FUDForum. Page generated in 0.36529 seconds
