Home » Eclipse Projects » Rich Client Platform (RCP) » Having different JRE versions
Having different JRE versions [message #463904] Tue, 20 February 2007 04:49 Go to next message
Eclipse 3.2 recommends JRE 1.4.2_10.
There are many users who would like to upgrade to a newer
JRE version, which is probably required by other applications.
How is such a case handled?
Even though there are multiple JRE's installed, can we tell the Eclipse
launcher to use a specified version?
How is that done?
Delicia.
Re: Having different JRE versions [message #463908 is a reply to message #463904] Tue, 20 February 2007 05:05 Go to previous messageGo to next message
Hi Delicia,
I run Eclipse 3.2 on Java 1.5, and I ran it on Java 1.6 and there were
no problems.
You can tell the launcher which version to use by -vm option in the
command line when running Eclipse (for options look here
http://help.eclipse.org/help21/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm).
I hope this help you :)
regards,
Jakub Jurkiewicz
Delicia napisał(a):
> How is that done?
> Delicia.
Re: Having different JRE versions [message #463910 is a reply to message #463904] Tue, 20 February 2007 05:10 Go to previous messageGo to next message
Originally posted by: m.hybler.aegis.cz
Delicia wrote:
> How is that done?
> Delicia.
You cxan do it in eclipse at window-preferences and java-installed JREs
I think.
Re: Having different JRE versions [message #463911 is a reply to message #463908] Tue, 20 February 2007 05:26 Go to previous messageGo to next message
Thanks, Jakub & Michal.
I too haven't seen problems on my machine with Java 1.5
Another user however, reported a crash (JVM terminated exit
code=1073807364). I'm trying to figure out possible causes.
The link you've given is useful.
Thanks again,
Delicia.
Re: Having different JRE versions [message #463945 is a reply to message #463911] Tue, 20 February 2007 13:46 Go to previous messageGo to next message
Originally posted by: lamont_gilbert.rigidsoftware.com
> I too haven't seen problems on my machine with Java 1.5 Another user
> however, reported a crash (JVM terminated exit code=1073807364). I'm
> trying to figure out possible causes. The link you've given is useful.
> Thanks again,
> Delicia.
I think 1.5 is fully supported on 3.2. I have not read anywhere that it
was not supported.
Re: Having different JRE versions [message #467546 is a reply to message #463904] Sun, 06 May 2007 09:29 Go to previous message
Originally posted by: aseem.verma.tcs.com
I too have run the Eclipse on JRE 1.5 and it works fine. However i got a problem while running the application in Internet Explorer.
We have installed JRE 1.5.0_10 on our XP machines. While running the application on IE, after logging,the applet opens but doesn't by default gets displayed onto the screen. We have to manualy select it i.e it hides behind the application already opened, doesn't itself shows up.
The same is not a case in machines with version 1.4.2_07. Moreover while opening the application with Eclipse, no such problem is encountered so not able to debug.
Are there some settings to be done at the IE level. Please suggest.
Previous Topic:need something like SelectionListener
Next Topic:Add resource to eclipse.org
Current Time: Tue Jun 17 18:24:24 EDT 2025
Powered by FUDForum. Page generated in 0.03721 seconds
