Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [FormToolkit] Defining TableWrapData width
[FormToolkit] Defining TableWrapData width [message #467357] Mon, 30 January 2006 05:36 Go to next message
Originally posted by: alexixlebaulois.yahoo.fr
Does anybody know how to define TableWrapData width (I want to obtain fixed width cells). I have tried "maxWidth" method but it's not what I'm looking for. Thank you for your help...
Alexis
Re: [FormToolkit] Defining TableWrapData width [message #467361 is a reply to message #467357] Mon, 30 January 2006 06:22 Go to previous messageGo to next message
I think the idea behind TableWrapLayout is to fit the children in the
available space and shrink and wrap them if they are to big. Like in a web
browser, see the class javadoc for details. Maybe a GridLayout is more
what you want. It is possible to adjust the width in GridData.
The javadoc of TableWrapLayout says that if children have the same minimum
and maximum sizes then the behavior is much like GridLayout. Maybe you can
alter these sizes if you can not live without TableWrapLayout.
hth,
Ricky
Re: [FormToolkit] Defining TableWrapData width [message #467368 is a reply to message #467361] Mon, 30 January 2006 11:56 Go to previous messageGo to next message
Thank you for your help. As you seem to know this toolkit, can you tell me how to make a tree (created with FormToolkit) fill verticaly the whole window. I've tried "new TableWrapData(TableWrapData.FILL_GRAB, TableWrapData.FILL_GRAB)" but my tree only filled horizontaly.
Alexis
Re: [FormToolkit] Defining TableWrapData width [message #467374 is a reply to message #467368] Mon, 30 January 2006 12:45 Go to previous messageGo to next message
Now you got me, I only looked at FormToolkit to implement a poor mans look
and feel behavior for my own widget factory.
But also I do not quite understand how a tree should look like when it is
filled vertically. A trees height is determined by its expanded nodes I
would assume. Maybe you mean the container the tree is in. E.g. you have a
Composite c which is the parent of your Tree t.
Tree t = new Tree(c,SWT.NONE);
To give the tree all the available space, set the LayoutData of the parent
composite c to something with FILL, depending on the particular Layout.
Here are some pointers which might help:
Some samples on how to use SWT widgets:
http://www.java2s.com/ExampleCode/SWT-JFace-Eclipse/CatalogS WT-JFace-Eclipse.htm
An article about Forms:
http://www.eclipse.org/articles/Article-Forms/article.html
hth,
Ricky
Re: [FormToolkit] Defining TableWrapData width [message #467435 is a reply to message #467374] Tue, 31 January 2006 05:02 Go to previous messageGo to next message
------=_Part_541_10241597.1138701912706
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Thank you for the links. I agree with you, a tree height fits to its content. I didn't express very well. I was thinking about the TableWrapData containing the tree (but I'm not sure it's the key of my problem). Take a look at the attached screenshot. You see the tree on the left ? The border of the tree fills the page vertically and it's what I want to obtain.
Content-Type: image/jpeg; name=example.JPG
Content-Disposition: attachment; filename=example.JPG
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRofHh0a
HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgN DRgyIRwhMjIyMjIy
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/ wAARCAGJAwcDASIA
AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQA
AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcY GRolJicoKSo0NTY3
ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKT lJWWl5iZmqKjpKWm
p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP0 9fb3+Pn6/8QAHwEA
AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQA AQJ3AAECAxEEBSEx
BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2 Nzg5OkNERUZHSElK
U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOk paanqKmqsrO0tba3
uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMB AAIRAxEAPwDvfDnh
y21uzubi4urtGS5aMCKQAYAB7g+tbP8Awgen/wDP9qP/AH9X/wCJo8B/8gi8 /wCv1/8A0Fa09e1i
TR4rIxWy3El3dx2qK0vlhS+cEnaeOPSu6pUq+15Ifp2OSnTpunzSMz/hA9P/ AOf7Uf8Av6v/AMTR
/wAIHp//AD/aj/39X/4mtiO61KNjJfWthb2qKWklW9ZigAznBjUY/EVakvrS KzF5JdQJalQwnaQB
MHod3TByPzrJ16y6/kaKjS7fmc7/AMIHp/8Az/aj/wB/V/8AiaP+ED0//n+1 H/v6v/xNXLXxVYXH
iDUNJkmtoWtnjjidrhczuw5VV9VPykDPPpWjJq+mxXgs5NQtEuiwUQNMofJ6 DbnOTkfnTdXEJ2f5
ISp0XqjC/wCED0//AJ/tR/7+r/8AE0f8IHp//P8Aaj/39X/4mt2fV9NtWkW4 1C0haJlWQSTKpQsC
VByeCQCR64p02pWFtax3U97bRW8uPLleVVR8jIwScHI5pe3r/wBIfsaX9MwP +ED0/wD5/tR/7+r/
APE0f8IHp/8Az/aj/wB/V/8Aia1rvWY44LGezNtdw3V0kHmC6RFAJIJUnhyC Pujk/hU93q+m2Eoi
vNQtLaQruCTTKhI9cE9ODT9tX/pIPZUjC/4QPT/+f7Uf+/q//E0f8IHp/wDz /aj/AN/V/wDia37j
UrCzdkub22gZUEjLLKqkITtDHJ6Z4z60f2lYfYft3222+x/8/Hmr5fXH3s46 8fWl7et/SD2NIwP+
ED0//n+1H/v6v/xNH/CB6f8A8/2o/wDf1f8A4muitL60v4jLZ3UFzGG2l4ZA 4B9MjvyKnpPEVVo3
+CGqFN9Dlv8AhA9P/wCf7Uf+/q//ABNH/CB6f/z/AGo/9/V/+JrqaKX1mr3/ ACD2FPsct/wgen/8
/wBqP/f1f/iaP+ED0/8A5/tR/wC/q/8AxNdTRR9Zq9/yD2FPsct/wgen/wDP 9qP/AH9X/wCJo/4Q
PT/+f7Uf+/q//E11NFH1mr3/ACD2FPsct/wgen/8/wBqP/f1f/iaP+ED0/8A 5/tR/wC/q/8AxNdT
RR9Zq9/yD2FPsct/wgen/wDP9qP/AH9X/wCJo/4QPT/+f7Uf+/q//E11NFH1 mr3/ACD2FPsct/wg
en/8/wBqP/f1f/iaP+ED0/8A5/tR/wC/q/8AxNdTRR9Zq9/yD2FPsct/wgen /wDP9qP/AH9X/wCJ
o/4QPT/+f7Uf+/q//E11NFH1mr3/ACD2FPsct/wgen/8/wBqP/f1f/iaQ+At OIIN7qBB6gyr/wDE
11VFH1mr3/IPq9Pscl/wrvSP+fi9/wC+0/8AiaP+Fd6R/wA/F7/32n/xNdbR Wn1/E/zsj6nQ/lRy
X/Cu9I/5+L3/AL7T/wCJo/4V3pH/AD8Xv/faf/E11tFH1/E/zsPqdD+VHJf8 K70j/n4vf++0/wDi
aP8AhXekf8/F7/32n/xNdbRR9fxP87D6nQ/lRyX/AArvSP8An4vf++0/+Jo/ 4V3pH/Pxe/8Afaf/
ABNdbRR9fxP87D6nQ/lRyX/Cu9I/5+L3/vtP/iaP+Fd6R/z8Xv8A32n/AMTX W0UfX8T/ADsPqdD+
VHJf8K70j/n4vf8AvtP/AImj/hXekf8APxe/99p/8TXW0UfX8T/Ow+p0P5Uc l/wrvSP+fi9/77T/
AOJo/wCFd6R/z8Xv/faf/E11tFH1/E/zsPqdD+VHJf8ACu9I/wCfi9/77T/4 mj/hXekf8/F7/wB9
p/8AE11tFH1/E/zsPqdD+VHJf8K70j/n4vf++0/+Jo/4V3pH/Pxe/wDfaf8A xNdbRR9fxP8AOw+p
0P5Ucl/wrvSP+fi9/wC+0/8AiaevgHTUXat5qAA7CVf/AImuqopSxteStKVx rC0VtE5b/hA9P/5/
tR/7+r/8TR/wgen/APP9qP8A39X/AOJrqaKj6zV7/kV7Cn2OW/4QPT/+f7Uf +/q//E0f8IHp/wDz
/aj/AN/V/wDia6mij6zV7/kHsKfY5b/hA9P/AOf7Uf8Av6v/AMTR/wAIHp// AD/aj/39X/4mupoo
+s1e/wCQewp9jlv+ED0//n+1H/v6v/xNH/CB6f8A8/2o/wDf1f8A4mupoo+s 1e/5B7Cn2OW/4QPT
/wDn+1H/AL+r/wDE0f8ACB6f/wA/2o/9/V/+JrqaKPrNXv8AkHsKfY5b/hA9 P/5/tR/7+r/8TR/w
gen/APP9qP8A39X/AOJrqaKPrNXv+Qewp9jlv+ED0/8A5/tR/wC/q/8AxNH/ AAgen/8AP9qP/f1f
/ia6mij6zV7/AJB7Cn2OW/4QPT/+f7Uf+/q//E0f8IHp/wDz/aj/AN/V/wDi a6mij6zV7/kHsKfY
5b/hA9P/AOf7Uf8Av6v/AMTR/wAIHp//AD/aj/39X/4mupoo+s1e/wCQewp9 jlv+ED0//n+1H/v6
v/xNH/CB6f8A8/2o/wDf1f8A4mupoo+s1e/5B7Cn2OW/4QPT/wDn+1H/AL+r /wDE0f8ACB6f/wA/
2o/9/V/+JrqaKPrNXv8AkHsKfY5b/hA9P/5/tR/7+r/8TR/wgen/APP9qP8A 39X/AOJrqaKPrNXv
+Qewp9jlv+ED0/8A5/tR/wC/q/8AxNH/AAgen/8AP9qP/f1f/ia6mij6zV7/ AJB7Cn2OW/4QPT/+
f7Uf+/q//E0f8IHp/wDz/aj/AN/V/wDia6mij6zV7/kHsKfY5b/hA9P/AOf7 Uf8Av6v/AMTR/wAI
Hp//AD/aj/39X/4mupoo+s1e/wCQewp9jlv+ED0//n+1H/v6v/xNH/CB6f8A 8/2o/wDf1f8A4mup
oo+s1e/5B7Cn2OW/4QPT/wDn+1H/AL+r/wDE0f8ACB6f/wA/2o/9/V/+Jrqa KPrNXv8AkHsKfY5b
/hA9P/5/tR/7+r/8TR/wgen/APP9qP8A39X/AOJrqaKPrNXv+Qewp9jlv+ED 0/8A5/tR/wC/q/8A
xNH/AAgen/8AP9qP/f1f/ia6WeZbe3kmcErGhcgdcAZrLbxJZI7I4KspwVM0 QIP/AH3TWIrPZ/kJ
0aS3Rnf8IHp//P8Aaj/39X/4mj/hA9P/AOf7Uf8Av6v/AMTW9YajbajEZLeR WKnDIGUleSOcE9cc
VnLb2a209xNaQSFZZ2ZmiVmOJG9fYf56iXiqq3f5DVCm+hS/4QPT/wDn+1H/ AL+r/wDE0f8ACB6f
/wA/2o/9/V/+JqYS6czlF0uJmV9jARwna2M4ODxwCf8A9fFrT1sLiZWjsIUK hZFfy4+Qc4IK/wC6
f89F9bq/0v8AgB7Ck9vzM/8A4QPT/wDn+1H/AL+r/wDE0f8ACB6f/wA/2o/9 /V/+JrY1XVV0tFd1
TYVZmZnIxgqOwJJJYVBFrgmdUjNizsFZUF58xDAEcbc8gj86r61V2v8AgJ0q SdjO/wCED0//AJ/t
R/7+r/8AE0f8IHp//P8Aaj/39X/4muktpvtFrDPt2+YivjOcZGalo+s1e/5D 9hT7HCaVZJpvi3Ub
KOWWSKKJdplbJ5Ck/wA6Ksx/8j7q/wD1yj/9BSissZrVv5R/9JRWH0hbzf5s s+A/+QRef9fr/wDo
K0zx4Yha6IZ5PLh/teDzH8wptXDZO4EFcDvnin+A/wDkEXn/AF+v/wCgrXU1 01Z8lfm/rYzpx5qN
v63Ofs7nw5FcrJb64ssiKzbW1Z5RgKSSVaQggDJ5HGM9q5uxWK21mHVLiCSL woZ2ewWQER28rbcT
FD9xGO/aTwpbOFyDXolFRGvy3318y3TvY5PTbmCx8e+IUu547drr7J9nWVwh m+Qr8mfvc8cd65/T
ysXhO80nWNY0uynLTC9hu7YvcbyS2/PmDzGxtKsAe2M4r0yimsRbp2/BW7Cd K/Xv+JxnhK3WPxVr
pkdp54reyj+0SxlZGBhGSQ3zAkqCQe456ViQWilLueDWI9JuNN1e9jsWmUeQ qsFBj+b5V68D03EK
cHHp1FNYp8zdu34K3bqL2Kta/c87uNSn1XTtHubm3to5h4kijaa2z5Vztyok UnkjA25yfu/gNHTL
3T9JufEcWvzQQzz3ckuLnBM1sVwgGfvrgMAozjkYHSuzopPEJrl5dPXzGqTT vfU848H2VzB4l0uL
UoWF1DobMom5aMG4YL16HY2Mdgce1PvLKC58Q+IYX1H+zEtr2zu4JtgMUUxj YlmB+Ubu5JGW28no
fRKKp4tubnbdfrcSoJRUb/1axzHhHVLzUZL+O+FlcTWvlRf2hZcx3A2lsbsY JUkk44BfoO/T0UVz
1JKUrpWNYRcVZu4UUUVBQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFXU/+ QVef9cH/APQTWDaS
6r9nLadYWN1A00x8ya8aI58xugEbAjGOc/hXUVR/sm13Oym4TexchLqRRknJ OA2ByauMrEThzFbS
zcnULg3cEUE5t4t0cUpkUfPLjDFVJ4x2H9ainONEvj6faT/4+/8An/ORqW1j Bau7x+YXcAM0krSE
gZwPmJ9T+dV301ptOuLV5Apm84BgM4DsxH8x+X0NRP3mVFWVjmFiPn6gi2lq rSXLKPJny0n7qQ/N
83yHnP8ADyx+p1PDMfkqkQiSJVt02okm9QpeUjDbmzxg9T/gHwu26VlntkMz l5Slu4LkqynnzOPv
seMcnNXdH0X+ycqsqGMRrGiIjAKoLHqzMTy3r2qrLl3+XQzpJxXK0vXr6ehD rrotzb+aYREYZd4m
iMikboxgqD6kUyDUGl8uOHUdN3MqlYxEQ2CAV+XfkcEVo6hpUWotGZZHXYrL gKjBgSp5DKR1UU1N
MljjWOPUrpUUAKqpCAAOwHl0lY0cVbz/AEJNJO7R7E+tvGf/AB0VcqK2gW1t YbdCxSJFRS3UgDHN
S0hnGx/8j7q//XKP/wBBSiiP/kfdX/65R/8AoKUVWL/ifKP/AKSjPD/A/WX5 ss+A/wDkEXn/AF+v
/wCgrXU1y3gP/kEXn/X6/wD6Ctb1/kpEmfkeTa49RtJx+YFbYhXrNf1sTRdq aLdFc/JcaJFqcWmS
TaemoTJvitWZBK688hOpHytyB2PpWZbeJ/Ct5q0elwTQveyXVxZrF9lYZmgU NKuSuPlDA5zg54Jr
PkXcvmfY7OiuXm1bwxb6mNMn1DSItQLqgtXmjWUs2No2E5ycjAxzkVfnh0+1 t5Li4jtYoYkLySSK
qqigZJJPAAHenyLuHM+xs0VjQQ6fdW8dxbx2ssMqB45I1VldSMggjggjvUn2 K1/59of+/Yo9mu4c
77GrRWV9itf+faH/AL9iq9kdJ1K0S7sTZXVtJnZNBsdGwcHDDg8gj8KORdw5 32N2isr7Fa/8+0P/
AH7FH2K1/wCfaH/v2KPZruHO+xq0VlfYrX/n2h/79ij7Fa/8+0P/AH7FHs13 DnfY1aKyvsVr/wA+
0P8A37FH2K1/59of+/Yo9mu4c77GrRWV9itf+faH/v2KPsVr/wA+0P8A37FH s13DnfY1aKyvsVr/
AM+0P/fsUfYrX/n2h/79ij2a7hzvsatFZX2K1/59of8Av2KPsVr/AM+0P/fs UezXcOd9jVorK+xW
v/PtD/37FH2K1/59of8Av2KPZruHO+xq0VlfYrX/AJ9of+/Yo+xWv/PtD/37 FHs13DnfY1aKyvsV
r/z7Q/8AfsUfYrX/AJ9of+/Yo9mu4c77GrRWV9itf+faH/v2KPsVr/z7Q/8A fsUezXcOd9jVorK+
xWv/AD7Q/wDfsUfYrX/n2h/79ij2a7hzvsatFZX2K1/59of+/Yo+xWv/AD7Q /wDfsUezXcOd9jVo
rK+xWv8Az7Q/9+xR9itf+faH/v2KPZruHO+xq0VlfYrX/n2h/wC/Yo+xWv8A z7Q/9+xR7Ndw532N
Wisr7Fa/8+0P/fsUfYrX/n2h/wC/Yo9mu4c77GrRWV9itf8An2h/79ij7Fa/ 8+0P/fsUezXcOd9j
VorK+xWv/PtD/wB+xR9itf8An2h/79ij2a7hzvsatFZX2K1/59of+/Yo+xWv /PtD/wB+xR7Ndw53
2NWisryY7d43gjSN/MRSUUDILAEH14rVqJRsNO4UUVXvWZbU7GKksqkjrgsA f0zSSu7FPQsUVy82
reGLfUxpk+oaRFqBdUFq80aylmxtGwnOTkYGOcir88On2tvJcXEdrFDEheSS RVVUUDJJJ4AA71py
LuRzPsbNFY0EOn3VvHcW8drLDKgeOSNVZXUjIII4II71J9itf+faH/v2KPZr uHO+xq0VlfYrX/n2
h/79iq9kdJ1K0S7sTZXVtJnZNBsdGwcHDDg8gj8KORdw532N2isr7Fa/8+0P /fsVQ1K/8PaN5X9q
Xel2Pm58v7VJHFvxjON2M4yPzFHIu4cz7HSUVjQQ6fdW8dxbx2ssMqB45I1V ldSMggjggjvUedJ/
tD+z82X23yvO+z/J5nl5279vXbnjPTNHIu4c77G7RWNPDp9rbyXFxHaxQxIX kkkVVVFAySSeAAO9
UNN1Tw/q99eWWnva3M1mkLzeXFlQsq74yGxtYMvOVJo5F3DmfY6iisr7Fa/8 +0P/AH7FH2K1/wCf
aH/v2KPZruHO+xq0VlfYrX/n2h/79ij7Fa/8+0P/AH7FHs13DnfY1aKyvsVr /wA+0P8A37FH2K1/
59of+/Yo9mu4c77GrRWV9itf+faH/v2KPsVr/wA+0P8A37FHs13DnfY1aKyv sVr/AM+0P/fsUfYr
X/n2h/79ij2a7hzvsatFZX2K1/59of8Av2KPsVr/AM+0P/fsUezXcOd9jVor K+xWv/PtD/37FH2K
1/59of8Av2KPZruHO+xq0VlfYrX/AJ9of+/Yo+xWv/PtD/37FHs13DnfY1aK yvsVr/z7Q/8AfsUf
YrX/AJ9of+/Yo9mu4c77GrRWV9itf+faH/v2KPsVr/z7Q/8AfsUezXcOd9jV orK+xWv/AD7Q/wDf
sUfYrX/n2h/79ij2a7hzvsatFZX2K1/59of+/Yo+xWv/AD7Q/wDfsUezXcOd 9jVorK+xWv8Az7Q/
9+xR9itf+faH/v2KPZruHO+xq0VlfYrX/n2h/wC/Yo+xWv8Az7Q/9+xR7Ndw 532NWisr7Fa/8+0P
/fsUfYrX/n2h/wC/Yo9mu4c77GrRWV9itf8An2h/79ij7Fa/8+0P/fsUezXc Od9jVorK+xWv/PtD
/wB+xUtoiw3YjiUJG0bMyqMDIK4OPxP+QKTgraMFI52P/kfdX/65R/8AoKUU R/8AI+6v/wBco/8A
0FKKnF/xPlH/ANJQsP8AA/WX5ss+A/8AkEXn/X6//oK10V0u4Rez5/Q1zvgP /kEXn/X6/wD6CtdQ
yhsZ7HNbYh2qv+uhNFXpo8B1/TvFs/ibWfGVvo07/wBmazbpa2++X7VLbwZj dYQIz+6m83ccHHDZ
DdaseH9D1aH4nWV3Lpd7HbL4j1uZpmt3CCOSGMI5bGNrEEA9DjivdfLT+6KP LT+6PyrK6NLM8osL
e7s/i94nuZpNbsra8lsBA1tp5lgu9sWGDyGJwqgnBIZMZPPHHM29l411LT4L G7j1uTTrmw1eHT0m
aQXDOwYRDUS/yD5SdmO+3tXvvlp/dH5UeWn90flRzILM8NFrrMPhrwZa6c2v Wenxoyaxvt753jnF
ugQbFZJvL3BgBGRGDj0xRNp3iaWaaH+1PEuoQ2vhSd7a7WO6sTLerM4jzGCC ZNuBhslwAxznNe5e
Wn90flR5af3R+VHMgszxW0m8Yy+MPD1zdDUdQhubeyF5alLuyFk/lbpXLIFg cbjuYNuJP7sKMViW
X/Caf8I5Z/2x/wAJR/yAb37P5P2rzv7R+0P5fm+X8/3Nm3zPkx0719C+Wn90 flR5af3R+VHMgseD
ahD47Wz8T6hIde/tmzt9JexWB5TE0xRPtOyJD5Ug3BtwCso5rotG/wCEkT4s XS3H23UdJllnkS4b
7ZapZqFCqhjbbBKucqNgZm/1hIxXq/lp/dH5UeWn90UcyCxV2mjaat7RRtFP nFylTaaNpq3tFG0U
c4cpU2mjaat7RRtFHOHKVNpo2mre0UbRRzhylTaaNpq3tFG0Uc4cpU2mjaat 7RRtFHOHKVNpo2mr
e0UbRRzhylTaaNpq3tFG0Uc4cpU2mjaat7RRtFHOHKVNpo2mre0UbRRzhylT aaNpq3tFG0Uc4cpU
2mjaat7RRtFHOHKVNpo2mre0UbRRzhylTaaNpq3tFG0Uc4cpU2mjaat7RRtF HOHKVNpo2mre0UbR
RzhylTaaNpq3tFG0Uc4cpSKElP8AfU/qKvU0oD+eadUydykrBUN0u6Aj/aU/ qKmpGG4YpJ2dxs8n
sba8svi94nuJpNbsra8lsBA1tp5lgu9sQDB5DE4VQTgkMmMnnjjmbey8a6lp 8Fjdx63Jp1zYavDp
6TNILhnYMIhqJf5B8pOzHfb2r33y1PYUeWn90flVcyJseGi11mHw14MtdObX rPT40ZNY32987xzi
3QINisk3l7gwAjIjBx6Yom07xNLNND/aniXUIbXwpO9tdrHdWJlvVmcR5jBB Mm3Aw2S4AY5zmvcv
LT+6PyqOF7a5QvBJHKgdkLIwYBlYqw47hgQR2IIo5kFmeM2k3jGXxh4euboa jqENzb2QvLUpd2Qs
n8rdK5ZAsDjcdzBtxJ/dhRisSy/4TT/hHLP+2P8AhKP+QDe/Z/J+1ed/aP2h /L83y/n+5s2+Z8mO
nevoXy0/uj8qPLT+6Pyo5kFjwbUIfHa2fifUJDr39s2dvpL2KwPKYmmKJ9p2 RIfKkG4NuAVlHNdj
4yWe3+IfgnVPsV7PZWf277RLa2kk/lb4lVciNWPJ46evpXpHlp/dH5UeWn90 flRzILHg0ekeK7Cz
0zyl1HTNBvdXvrxrW3hnd7OB0Bt43itnWRBnzDsRtqlhu54rT0fRr238e6Dq Oq3Ot6lbDRvscepC
0ubd5J1uiVWdF+ZV2EZMvyvjcSea9m8tP7o/Kjy0/uj8qOZBZngV1eeN5tSk ngtdbs5bq11Vbuyi
ivJEtnEbmALK7NGzFlUq0ITrgcECq9rp3ixINcuVk1SwvbmLRGaWWzu3N2Ut j5sbPCplX5vvMvOR
tJG6voXy0/uj8qPLT+6PypXQWOW8FNfzeDdMk1Kxnsb14t0tvPcSTOpJJyWk LPyMHaxJXO09K39p
pwvLEah/ZwuoPtvlef8AZvMHmeXnbv29dueM9M1LJLBC8KSyxo8z7IlZgC7b S2F9TtVjgdgT2p84
uUg2mjaat7RRtFPnDlKm00bTU88sFrby3FxLHDBEheSSRgqooGSSTwABzmpN oo5w5SptNG01b2ij
aKOcOUqbTRtNTxywTPMkUsbvC+yVVYEo20NhvQ7WU4PYg96k2ijnDlKm00bT VvaKNoo5w5SptNG0
1b2ijaKOcOUqbTRtNW9oo2ijnDlKm00bTVvaKNoo5w5SptNG01b2ijaKOcOU qbTRtNW9oo2ijnDl
Km00bTVvaKNoo5w5SptNG01b2ijaKOcOUqbTRtNW9oo2ijnDlKm00bTVvaKN oo5w5SptNG01b2ij
aKOcOUqbTSwoRchj/cYfqKtbRSBQGyPTFJzGonHx/wDI+6v/ANco/wD0FKKI /wDkfdX/AOuUf/oK
UUsX/E+Uf/SUTh/gfrL82WfAf/IIvP8Ar9f/ANBWuprlvAf/ACCLz/r9f/0F a6mtcT/Ff9dCaH8N
GYiXN3eXoF/cQpFMI0SNY8AeWjfxKT1Y96l+w3H/AEFrz/viH/43VSb/AI9P EH+83/ohKwJodY/4
SHWYZtC0yLR47FXhnSQlg2Z/mX9yMudse5N2EG0gturJysapHVfYbj/oLXn/ AHxD/wDG6PsNx/0F
rz/viH/43Utx9reCVYVjVyrBGEuCDhsHlCP7vY9Twcc8zBaav5oWKOdNRDP5 9y0gEbZcFNzbMSfJ
uAwp2kj5V7c9bEOm0lG9/IuFNS6nQ/Ybj/oLXn/fEP8A8bryjVfH3iax1y+t Eu4/Jt7qSJA9uNxR
XAGSVHJAbnGPmXGQuW9LsLfXUvY2vLmN7cZ3qJVJPBxwIV747ivMH0q3udc1 AvYecsus3Md3Lh1+
xw7wRL8oULndIdzhlOzOWwWbsy+UK837WLSs9Hp27MwxPNTj7j1v/mVl+JHi kbd97bnpuxbKM/dz
j06P9Ny9dp3C/EjxSNu+9tz03YtlGfu5x6dH+m5eu07mCwsmu/IttN8+4i0+ C4SAu7G5ldIiw2qQ
2ArO2FOcgknb8oivNGiHiGGOa3+w2JezjuhvK+Q0sasw+ckjo55zjHNeysLh X9nz3f8AmcDrV/5v
6+4sL8SPFI27723PTdi2UZ+7nHp0f6bl67Tuf/wsPxbGsTS3UQV1DA/ZQocZ UEr7ZWQd8ZHXad0l
xpFkJsw6Pci8WB2jsJoXi88h4wMR+a0h+VpDkMAdnH3WzcttPW70u1jm09mk SJttlulA3g37BCob
cSGRRyd3UZ5OYdDCqPNyfi/8ylVr3tzfh/wDMX4keKRt33tuem7Fsoz93OPT o/03L12ncL8SPFI2
7723PTdi2UZ+7nHp0f6bl67Tunt9FtpJvn0vybpoEaWGdJvs1od8gPmlW8yP KIjAsSPmYnAIK1b/
AEzTYPDiTxW1yX8iJ1u/LxG8jbS6eYZNrYy42qgYFeT8rE0sPhG7cv4v/MXt a9r839fcPX4keKRt
33tuem7Fsoz93OPTo/03L12ncL8SPFI27723PTdi2UZ+7nHp0f6bl67TupLp Ultpd1/xLPtd5DPN
Ddffb7IEVcN8jADJL8tkHZx0OdZtF05Li4FxpzR20DTC1dZHU3sSwzN5oZiQ SCkZ3INvz8gggUSw
2EX2fx/4IlWrv7X4f8ArL8SPFI27723PTdi2UZ+7nHp0f6bl67TuF+JHikbd 97bnpuxbKM/dzj06
P9Ny9dp3JHp+mS+HWvPsU5eSKWV5YYyY7eQMwSPzGlCqMBPlZWYhuDllxnR2 UVpot9NeWm+5D2yw
kyEBFljkcMQOvAUgcYOM8ZUtYXCu/u7eb/zB166+1/X3GkvxI8Ujbvvbc9N2 LZRn7ucenR/puXrt
O4X4keKRt33tuem7Fsoz93OPTo/03L12ndZTQLWC41W5m01ms0uJGsjIZBHL EIbh12sCNy/JGcg9
O/NQNFCfDE8lrp0bvdpFcvboZGEAU3MbSL827A2qSWJALc9QBP1fC9Idur6/ Mfta/WX4f8AavxI8
Ujbvvbc9N2LZRn7ucenR/puXrtO4X4keKRt33tuem7Fsoz93OPTo/wBNy9dp 3XNastPtbm/c6fHM
8KTXJeaaVmlP2xoQrHfyNpB4wSQMk8gsvtB0qysb1Et7ucxNcKboR5ETpI6o rSeYqKSFQlShY7+O
WUBKhhGl7j+9/wCY3Vr/AM39fcVl+JHikbd97bnpuxbKM/dzj06P9Ny9dp3C /EjxSNu+9tz03Ytl
Gfu5x6dH+m5eu07quiaQWuZvtdk10VijYW0UTTyESKHVwqSIdoXGTu4LqMZP GnqOgWtkkkK6a32R
IrotqTGTKyRyTLGpbPlgnZGuNuTu45IqpYfCRly8v4v/ADJVau1e/wDX3EMP xD8WysFW6ikYLuYJ
ajOFClj3wMCQ+2R12ncxfiR4pG3fe256bsWyjP3c49Oj/TcvXad2jPpUNjqO pf8AEs/s/wAn7XDa
/wCsH2iL7PPlvnY7sbU5XA+fnqMUtc0lfttwltaK8ct3Ik+ozvKwtX+0MgVn ztA2hCdwLfPnPIqV
QwraXLv5v/Mp1a6Xxfh/wCNfiR4pG3fe256bsWyjP3c49Oj/AE3L12ncL8SP FI27723PTdi2UZ+7
nHp0f6bl67Tu030y3tLSaS20af7Rd28kK2FxbyxGYpLbtlU8xnJwWOQ38HTg 5qrpNrPLZ7rRrlJV
t0vJmeRjZRG3hPmZBwo+eQ5fKjZgAAEUKhhHryfi/wDMHUrr7X4f8ArL8SPF I27723PTdi2UZ+7n
Hp0f6bl67Tu2PCnjPxHrfiWy027vk8mYOJGhtwrAiPcCDtYAblbrjhgM5HzY w0/Tp5TaHT2UQWlp
cNJas7TzGTyQ6gMxUk+a2AAOQvbIOjoFitr8S9GVLWCEbJJPKjjlDR5jlA8x ZN5R8Y6MBgjDEHDZ
4ihh40m4Rs/+G8y6VWq5pSeh6p9huP8AoLXn/fEP/wAbo+w3H/QWvP8AviH/ AON1eoryOZndYo/Y
bj/oLXn/AHxD/wDG6PsNx/0Frz/viH/43V6ijmYWKP2G4/6C15/3xD/8bo+w 3H/QWvP++If/AI3V
6ijmYWKP2G4/6C15/wB8Q/8Axuj7Dcf9Ba8/74h/+N1eoo5mFij9huP+gtef 98Q//G6PsNx/0Frz
/viH/wCN1eoo5mFjm9T1TUbDwz59rNC962oRWaS3MW9QHu1g3MqFM4Vs4BHI qPPiv/oN6L/4JZf/
AJKqLXf+RYi/7D1r/wCnKOs3xtrY0uzsrKPW7XRrrUZzFHfTmMiBVRpGfY/D A7Vj6jBlBznAM1G0
9Bx2NfPiv/oN6L/4JZf/AJKoz4r/AOg3ov8A4JZf/kquP1Xxnd6x4HvbvRII RIdC+3zzfbihtvMS
QARsqHe6NFIDnZgqOeTt0ptb1C/1/RDDAkGltq1xamQXTebM0UNyrK8YTbs3 xkg7z91TgHpnzSKs
jez4r/6Dei/+CWX/AOSqVR4sZgo1vRck4/5Asv8A8lVoU+L/AFyf7woU2Fg8 NalNrPhXSNUuFjWe
9sobiRYwQoZ0DEDJJxk+prUrn/An/JPPDX/YKtf/AEUtdBWpIUUUUAef6ymj weOY5/P0PVdTa7th
/Z1zCk1/b5KLuhfdujjRf35XYf8Alo24bsrza61r+t6O/wDaOrWijfZXV5Hb TLLLpTrdwM25fIVY
Ai+aSszSH931ISQn2SigDi/FTRNp/ha8GvSQWcN6JZNZVocKhtJ1WVmZDEA7 Mq524JcAYJFYceoa
z4f0eW/0y5nvZLvVdYii02WFHjDo15MuzYokLF4VGC5yHYAA7SPUKKAOP8C6 pqOo/b1u9XsdVt4/
LMVxaXS3OGO7chljgij4AQ7QCw3EscMlcnp3i7WLnQtIl03xPHqd3e29m97J JFBKthPJc2sfllYl
TaHWacbXO4+X8rKVJr1maaO3gknlbbHGpdjjOABk1mWFxp2madbWFnb3kdra xJDCn2Sc7UUAKMlc
nAA600m9hXRzNzrWoWfiBrJtaka8gvbS1ttNkSENf2ziHzbkqEDsV3zndGVQ eTyuFYHn7DxjrEnh
i0utO8QR6zcXGmRT6hJIYAumStJbq2WijxEAktw371Xx5GcEK4Pp39q2/wDz zvP/AACm/wDiar2F
xp2madbWFnb3kdraxJDCn2Sc7UUAKMlcnAA60cr7BdHI+HdY1/U9Z0uzk120 ns2S7mee023H2lIm
tdoE3lRoTulkUsiY25X/AFg3rz9hqmoaP4Y8PxadqMd3eQaO8NyblYQ2msJL COWNnWMmIRK7s28N
jaGcOFAr1b+1bf8A553n/gFN/wDE0f2rb/8APO8/8Apv/iaOV9gujzmTxTrE OjW0lx4gtJoTcTKk
ml3UEt7egLHtWAywJDcEO7hhGinhFBZ1ZW6zxTqhsdR0+3uNb/sLTZopnk1D MK/vVMYji3TKyDcr
ytjG4+XwcBs7X9q2/wDzzvP/AACm/wDiaP7Vt/8Annef+AU3/wATRyvsF0cr 4AbUb671nVdRlnt7
ieW2Nxp3lqkcczWNozHBXzAwJK4LYA7Z5rDt7aSW/wBPsE1+7t7weKL12t4x AZLFXS/dCFaMkCRS
GzJuyDlcCvRv7Vt/+ed5/wCAU3/xNH9q2/8AzzvP/AKb/wCJo5X2C6PNb3xZ 4lFwsMWqWNr9n86K
3e7lWI6hLHdTw7fLEEjTNthiLJD5bZl4++gXqPHWtXWkfYPJ1L7LDJ5heG0l gF/csNoRLeOZWSXl
juUYbldpJ+Vui/tW3/553n/gFN/8TR/atv8A887z/wAApv8A4mjlfYLo8t8R a/rt3a+KrS5v7EQ/
ZNThk03zw00UCRTCOXyVhDx7gsbb3lKEScAF0A0JfFPilNY1c29xYz3Fv9uE ejeYZZgsSyeQ/wBn
SESJvKRHc8xVhJ8oBdAPQv7Vt/8Annef+AU3/wATR/atv/zzvP8AwCm/+Jo5 X2C6OJjubSbxVoF5
D41kvrQJd2/24S2jLJMz2hW0LJGEywVmCgCQ4ODgVl6V4s8SzWM1xdapYlni ha9ihlWaTSi80SyF
lECiDy0eYlZmkIMWeQkhPpX9q2//ADzvP/AKb/4mj+1bf/nnef8AgFN/8TRy vsF0cboGoyw6F441
HRtQ/t+4hu3ltZ/kl+0yLYwFVxCFVvmG3CgHjHXmq+k+ItZOnXcq63Y6tLFL F9ijtLhLr7ZKRJut
jKkESDKqrfKC0fMkhMfynuv7Vt/+ed5/4BTf/E0f2rb/APPO8/8AAKb/AOJo 5X2C6OBfUbu21nUN
WtdYku799CVrO1Nuka6lcxNeM0IiK+bmIlQY1YOuQHLHkx6ZrWvajc2Ngvii Ca3udQWH7dps8N24
H2a5kaPzPsyQ9YojtCFxkknDrXoX9q2//PO8/wDAKb/4mj+1bf8A553n/gFN /wDE0cr7BdHCweJ9
SfWNMtbnVty/a5LQW1k9v9suDHdyw+bNC6cw7IgWaEqVPmHbt5Sn4c8S6g2m 6KranHDebNNittHj
hhRbu2kitzLOIwu/CeZPzGVRfI5GFbPo39q2/wDzzvP/AACm/wDiaP7Vt/8A nnef+AU3/wATRyvs
F0cb4d8Q3tjp2jX+t6zPd2t/4fk1e7eeGMfZzGIC3liJFO3Ez5B3H5VxjnPo FUf7Vt/+ed5/4BTf
/E0f2rb/APPO8/8AAKb/AOJo5X2C6L1FUf7Vt/8Annef+AU3/wATR/atv/zz vP8AwCm/+Jo5X2C6
L1FUf7Vt/wDnnef+AU3/AMTR/atv/wA87z/wCm/+Jo5X2C6L1FUf7Vt/+ed5 /wCAU3/xNH9q2/8A
zzvP/AKb/wCJo5X2C6L1FUf7Vt/+ed5/4BTf/E0f2rb/APPO8/8AAKb/AOJo 5X2C6L1FUf7Vt/8A
nnef+AU3/wATR/atv/zzvP8AwCm/+Jo5X2C6L1FUf7Vt/wDnnef+AU3/AMTR /atv/wA87z/wCm/+
Jo5X2C6L1FUf7Vt/+ed5/wCAU3/xNH9q2/8AzzvP/AKb/wCJo5X2C6L1FUf7 Vt/+ed5/4BTf/E0f
2rb/APPO8/8AAKb/AOJo5X2C6L1FUH1m0jjaSRbtUUEszWcoAA7k7av0NNbj ucbH/wAj7q//AFyj
/wDQUooj/wCR91f/AK5R/wDoKUU8X/E+Uf8A0lGeH+B+svzZZ8B/8gi8/wCv 1/8A0Fa6muW8B/8A
IIvP+v1//QVrqa1xP8V/10Jofw0ULNFkudVR1DK1wAVIyCPJjoXTLH7S4Njb bQikfuVxnJz/AA/T
ufoO9Wb/AI9PEH+83/ohKwJodY/4SHWYZtC0yLR47FXhnSQlg2Z/mX9yMuds e5N2EG0gturCW5sj
uKKrXD3awSmGKMuFYphtxJw2ODtB/h43DqeRjJ5mDUNVMo8pp5NS3P59qYwU XDgLuG/EfybiMMN2
B8zd8K1dUmk03f8Ar+kXCHN1Ovrze/8AhSb3Vry8XWljS5uZJ/L+xjKh3DEZ DAE8vzjnKk5IO7rr
C61yS9jS8s1jtzncwjQY4OORMx647Gs3xJ4i1LTbjVmshaCDRtMXUrlJomdr lWM37tGDKIjiA/MQ
/wB8fL8vza4fES+OF4vbsRUpp+7KzOftPhPPazxzDXYHZMZD6arqeFB+VnI/ v4yDjcvXb8xN8KLm
6n8658Qq7tt3bbHaMAIMKPMwowHAA4AKj+H5tiDxFr10kaqNNge91i602zkM TyiNYGuSZJF3LuLL
AF2gjB+fcc7FsW/iua18Gahqmom0n1CxTUX8iDMInW1leMlVYuVB2pk5bBce orp+s1r35mZexp7W
OaX4QSDbv19T03YssZ+7nH7zjo/03L12ndLa/Ci5tZBIniFQxQxuRY9VZQrg ZkOMgyD23L/dO7Qt
fEvig3UWkX1paWeoXVxHHBcTxJhFaKeQlreO5kJH+jlQxkXJc4H7s7sefWtV 0fxZqlvbyWjXlxep
G8zxyeUHZdJhLeUJACMTMQCSRgAMAW3DxVZ/aYexp/yj1+EEg279fU9N2LLG fu5x+846P9Ny9dp3
C/CCQbd+vqem7FljP3c4/ecdH+m5eu07tXUPFWvWEN6kwtEi0u4ePUNXSxea KNRDDKp+zLKJACJi
Cys+3yySAGyljSvFGuX/AIlEcumRx6PLe3NjFKxiQ7oTIu5W84vISYW+QQrg MTuITLP61X/nYewp
/wAqMJfhBINu/X1PTdiyxn7ucfvOOj/TcvXadwvwgkG3fr6npuxZYz93OP3n HR/puXrtO7pdW8Vz
Wtv4iuLA2lxBp+hR6paSDLrKzi4IyQcMhEKEYx1PPIxGfEr2XgnW9RRoPt9p /as0EEsjPvFvPKoO
GbcVGEzggDcANowAfWq/87D2FP8AlRzy/CCQbd+vqem7FljP3c4/ecdH+m5e u07hfhBINu/X1PTd
iyxn7ucfvOOj/TcvXad2rqnijxHpN/8A2GsNpqOqTPAYZ7W18tQsiXLEGKSc BiBatz5q/wCsHHy4
eTS/E/iXUbq6hXTLFpLLT/PktxOvmTT+bcxCIMrtHHuMCk5ZvLO5DvJ3KfWq /wDOw9hT/lRjL8IJ
Bt36+p6bsWWM/dzj95x0f6bl67TuF+EEg279fU9N2LLGfu5x+846P9Ny9dp3 ath4h8Q6nqlvpNvq
GmxXgS5a8Nxo8yGB4vs2Itn2jBOLjdvV2UjbtyOTX0zx5rmsXVpd2ujxx6Sz 2UU5d4sK1xFDJ/rW
mQgr9oUBRC28qACC+EPrVf8AnYewp/yopL8IJBt36+p6bsWWM/dzj95x0f6b l67TuF+EEg279fU9
N2LLGfu5x+846P8ATcvXad2idT8SarZeE9Rg1Gxtf7Xu0mgiFpIyxRvZ3Ehj lxMPOxhcEbBuUNjo
BJD4o1WCC4ijtI5JLu4vLbTGxJIv2lL2WLEpLE7NpjkwvISKcgBUUUfWq/8A Ow9hT/lRlL8IJBt3
6+p6bsWWM/dzj95x0f6bl67Tulf4UXM0dtHP4hV1gQRqBY4wu4MQP3ncmU85 xuXrt+bQh8XeJJ9U
uGg0OOawNxeWlojSwwmWWDzQAspmLMXaEjb5K7QxO4hCW6Dwvqlzqdlc/bp4 5Ly2uDBPGti9qYH2
I2xlaRwxAYHerFSCMEjkr61W/mYexp/ynHz/AAoubu6kubrxCsk0r+ZKwsdu 5iVLEDzMDJ8z6bl6
7TuiX4QSDbv19T03YssZ+7nH7zjo/wBNy9dp3eo0ULFVl9ph7Gn/ACnly/CC Qbd+vqem7FljP3c4
/ecdH+m5eu07hfhBINu/X1PTdiyxn7ucfvOOj/TcvXad3qNFP61X/nYewp/y o8uX4QSDbv19T03Y
ssZ+7nH7zjo/03L12ndpeHfho2ha9Z6pJq6XJttx8sWYTczR7Mglm28lzxzg gZwDu7+ipliKslyy
k2hqlCLukFFFFYmgUUUUAFFFFABRRRQAUUUUAclrv/IsRf8AYetf/TlHRqmm 31xf2t9ptzZW9zBF
LCXurV58o5QkALKgHMa9c9BjHObd5FpE3hi6XXbiO309bx3eZ7k24RluSyHz AylSHC4II5xWD9p+
Hn/Q6/8Al3XH/wAkUTjdhF6CxeCrS5sZoNXKTPM0vmGwe4s1lSRmdlkAmYuN 7yHBOBvIAGTnSXw3
paarHqSxTCeOVpo0F1L5KSMrKziLd5YYh3yduSWJ6kmsz7T8PP8Aodf/AC7r j/5Io+0/Dz/odf8A
y7rj/wCSKjk8x3Nu00awsfsP2aDZ9gtTaW3zsdkR2ZXk8/6tOTk8deTVrTLO 3062s7G0j8u2tkSG
JMk7UUAAZPJ4A61zX2n4ef8AQ6/+Xdcf/JFH2n4ef9Dr/wCXdcf/ACRS5PML nQeBP+SeeGv+wVa/
+ilroKp6TDY22jWMGlmM6fHbxpamOTepiCgJhsncNuOcnNXK0EFFFFAGdqNz dwX2mR27wLHcXBil
EkZY4EbP8pDDB+QjkHrntg09K1S/kttLnv2tpF1JFMYgiZDE5jMmDlm3DCtz xggcHPy6N5p4vLmy
nNzPEbSUyqse3DkqV+bKk42sw4I+8e+MQadokenpbo11c3S2yCO3WfZiEAbe Nqrk44ycnGcEZOdk
4cln/W//AADNqXN/XkXrab7Tawz+VJF5qK/lyrtdMjOGHYjuKlqK2h+zWsMH myS+Uip5krbnfAxl
j3J7mpaydr6Foo6z/wAgLUP+vaT/ANBNZvifxhpnhL7K2pnZDPvJk8+FNirj cdrurvgN0jV27YyQ
DqasjyaNfRxqzO1vIFVRkklTwBXPa/pFhr32v/Tdasfttp9iu/slmT9oh+fC nzIX248yTldp+c5J
wMOza0C+otx4+srS3vLu60zUobO3e7jjuWERW4kthIZEQLIWBxDKQXCg7eoJ AOf4i8cT6fHCRbXe
l3Fu8k11bXUUUzNB9ju5EYCOQqQXtzwHVvkIJUEE0rrwu134f1e0nv8AUJp7 h9SksbZ7Rxb28lyZ
wr5WESE7JmBDFgCzYBwpGhfeF9K1WGYanf69eXEqNG109psfyzDPCEwkKpgC 5lYHbnLDJIAFLlfY
Lo3V8TROmo3CafdmwsUmLXrPCkUjwsVkRd0gYEMrjc4VflJ3YwTj6b4/i1vW dNt9JspLu3nS5W6E
UsLtbPG1vhi6ymNk2z5OwueQMZDATvpFg63UIvdaSzmlNzHarZnZb3Hmibzk Jh3lhKC+GZk5I27c
AR2WiWVlf/2iNT16XUGuGmlupLIbpUZIUaIqIAgQi3i5Chvl4YZOTlfYLol0 rxxbX1lYTm2u5IJk
tUnvliSOKKedI2jjZDIXBbzovuh1HmDLcMRc0DxZBr32T/iXX1j9ttPttp9r 8o/aIfkyw8t3248y
Phtp+cYBwcZVj4b0fT4rS2guda+wwfZme0a0YpPLAsaxSufK3hgIYuFZVOwZ Xls39NsdL0v+yPI/
tNv7K09tPg32kh3RnyslsRjLfuV5GByeOmDlfYLo6aiqP9q2/wDzzvP/AACm /wDiaP7Vt/8Annef
+AU3/wATRyvsF0XqKo/2rb/887z/AMApv/iaP7Vt/wDnnef+AU3/AMTRyvsF 0XqKo/2rb/8APO8/
8Apv/iaP7Vt/+ed5/wCAU3/xNHK+wXReoqj/AGrb/wDPO8/8Apv/AImj+1bf /nnef+AU3/xNHK+w
XReoqj/atv8A887z/wAApv8A4mj+1bf/AJ53n/gFN/8AE0cr7BdF6iqP9q2/ /PO8/wDAKb/4mj+1
bf8A553n/gFN/wDE0cr7BdF6iqP9q2//ADzvP/AKb/4mj+1bf/nnef8AgFN/ 8TRyvsF0XqKo/wBq
2/8AzzvP/AKb/wCJo/tW3/553n/gFN/8TRyvsF0XqKo/2rb/APPO8/8AAKb/ AOJo/tW3/wCed5/4
BTf/ABNHK+wXReoqj/atv/zzvP8AwCm/+Jo/tW3/AOed5/4BTf8AxNHK+wXR eoqj/atv/wA87z/w
Cm/+Jo/tW3/553n/AIBTf/E0cr7BdF6iqP8Aatv/AM87z/wCm/8AiaP7Vt/+ ed5/4BTf/E0cr7Bd
F6iqP9q2/wDzzvP/AACm/wDiaP7Vt/8Annef+AU3/wATRyvsF0XqKo/2rb/8 87z/AMApv/iaP7Vt
/wDnnef+AU3/AMTRyvsF0XqKo/2rb/8APO8/8Apv/iaP7Vt/+ed5/wCAU3/x NHK+wXReoqj/AGrb
/wDPO8/8Apv/AImj+1bf/nnef+AU3/xNHK+wXQaz/wAgLUP+vaT/ANBNXqx9 T1CK40q8gihvGkkg
dFH2OUZJUgfw1sU2rLUFucbH/wAj7q//AFyj/wDQUooj/wCR91f/AK5R/wDo KUUYv+J8o/8ApKIw
/wAD9Zfmyz4D/wCQRef9fr/+grXU1y3gP/kEXn/X6/8A6CtdTWuJ/iv+uhND +GihZoslzqqOoZWu
ACpGQR5MdC6bpxuXT7FbcIp2+UmBkn2z278ccd6ryO0dvrzoxVldiGBwQfIS uffVrxvEmr6V/ZGq
QwWtkk8d014pAJM43nE5JRvKUKAu4HduAGKwlubI7eiq1xcyxQSyLbSMUViA ehwG/u5bnA6An5hw
eQOdj8Q3irFcHy5HnaQCy2PuGxwmE+UNwCWbcCflOFHOMKuIhStzdS403LY6 uqd5pOm6hcWtxe6f
aXM9o++2kmhV2hbIOUJGVOVByPQelUbDWru7vY4JdNkhRs5kKzADAJ/iiUfq Kq694om0i4vlgsI7
iDTLJdQv3e4MbLCTJjylCMJHxDJwxQfd+bk7bpVY1VzQ/wAvzFKLi7M0NV0G y1XRLjSWSOC3nfe4
S3icbi/mE7JEZCS2SSVPJJ680aL4e03QbC1tLK2jUWySLHIUUMPMffJjaAFD MAxVQF4AAAAAx4/F
19cpiDRoxJPqc+m2Xn3m1Jnhafe7FUYom2A44JLErgKA7XLXxP8A8Uhfa/qN n5H2D7X9ogt5fN/4
95JEbYxCbs+WSMgda0JLkfhrQYdLm0uLRNNTT5n3y2i2qCJ245ZMYJ+VeSOw 9Kr6h4Q0HUbAWUmm
WkcG+IlYoEG5Y3iYIflwUIgiUjuqAdhjHs/G2oXYS2OgSQ6hPcLBbCc3EFvI THLIcySwI4IWF87Y
2GWj5+Y7ct/FuqaV4j1O3kg+0XEl2kcdqbzEEbsmmR7Q5iLbQ907AgDq2VJY FQDtF8NaCqWSLomm
hLBy9motUxbsWDEx8fISwByMcjNWI9J02HVJtUi0+0TUJk2S3awqJXXjhnxk j5V4J7D0rl7zxzc2
IeC4020gu4LhoLue4vHSwgIjikGbnyjgss0YXeiAsHAOQu+xpnjOXU/Er6dH o939jFxPbLeCGYgP
EWVi5MQiCFo2AKysclAVBLBQDYvPDWg6hb2tve6JptzBaJsto5rVHWFcAYQE YUYUDA9B6Uaj4e03
UtLvLB7aOFLq3uLdpIEVXVZ+ZSpxwWb5j6kAnNU9Y8T/ANlf2/8A6H5v9kaU upf63b5u7z/k6Hb/
AKjrz97pxzJp2q3d14dv722tpLu7huL6OG3eVFMrRTyoqb9oCg7AASDgEZLE EkAsR+GtBh0ubS4t
E01NPmffLaLaoInbjlkxgn5V5I7D0qwNJ01bd7ddPtBA9utq8YhXa0KghYyM YKAMwC9BuPrXJ6j8
QrOIQ6hapPPpEeJHuISFMubKe6KeW654jWFhgrkyAZG1lJB8QmiRH1fR57CE SsJbho7hY1jFvPMW
XzYI3dgLcgqFwA6kMTlQAbFz4I8N3cth52jWL2thFNFb2RtYzAnmsjMwQrgN lOCMfebrmtSTSdNm
1SHVJdPtH1CFNkV20KmVF54V8ZA+ZuAe59a5NviC/kHbpOJ44oDcb5m8m1lZ 7hJlmkWNtkcbWrqZ
dpUlgflX5q7CwuftmnW11ugbzokkzby+bGcgH5HwNy88NgZHOBQBTbw1oLJe o2iaaUv3D3im1TFw
wYsDJx85DEnJzyc1cWws08vbaQL5Urzx4jA2SPu3OPRjvfJ6nc3qasUUAZ76 Fo8l5dXkmlWL3V3E
YLmZrdC80ZABR2xllwAMHjgVYsbCz0yzjs7C0gtLWPOyGCMRouSScKOBkkn8 asUUAFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQByWu/8ixF/wBh61/9OUdasl40bqhe ZmYEhUVnOBjPQH1F
ZWu/8ixF/wBh61/9OUdXZ4me5jfyZJFEbqRHL5fJK4ydy8cGpq/EEdiy9zIi oS0vzMqgHIOWIAyD
060qXLyAlZJOCAc5GDgHv7EVTa3d7kObVS5njkEhZD5SAqSuSc9m6Z60lrA9 rAxFqjTeUh3Ark4j
QbM9fvKfasyi/wCbJ/z0f/vo06KWQyoC7Ebh3qvIZE83bGH2L8uHA3tzx7dB z71PGMXCDIOGHI+t
JXApeBP+SeeGv+wVa/8Aopa6Cuf8Cf8AJPPDX/YKtf8A0UtdBW5IUUUUARPc wRTxQSTxpNNnyo2c
BnwMnaOpwOuKfHLHKpaN1dQxUlTkZBwR9QQR+FYmtWE95q9nJbrtmgtZ3hlY EKku+EqGIGQGAYED
kqWFc/PNqZ0YTW9vf2cu66ubdTbTu7u80jBGSNgqkDYf3gZTv4GAc9EKKlFN P+tTKVRxbVjvaK46
e31NIrqaJtR87ZfzoPNlI82OXFuAucYKk4TG1hjIOBi1YR6n/wAJG7z3Nz/r 5d8X2eXy/J+by/nL
+V08s/Iu/PB/jNJ0Va9wVTW1jd1OaS30q8nibbJHA7qcZwQpIqP7Dcf9Ba8/ 74h/+N1Wn/5E6X/j
5/5B5/4+v9b/AKv+P/a9ffNa9ZvQtalH7Dcf9Ba8/wC+If8A43R9huP+gtef 98Q//G6vUVPMx2KP
2G4/6C15/wB8Q/8Axuj7Dcf9Ba8/74h/+N1eoo5mFij9huP+gtef98Q//G6P sNx/0Frz/viH/wCN
1eoo5mFij9huP+gtef8AfEP/AMbo+w3H/QWvP++If/jdXqKOZhYo/Ybj/oLX n/fEP/xuj7Dcf9Ba
8/74h/8AjdXqKOZhYo/Ybj/oLXn/AHxD/wDG6PsNx/0Frz/viH/43V6ijmYW KP2G4/6C15/3xD/8
bo+w3H/QWvP++If/AI3V6ijmYWKP2G4/6C15/wB8Q/8Axuj7Dcf9Ba8/74h/ +N1eoo5mFij9huP+
gtef98Q//G6PsNx/0Frz/viH/wCN1eoo5mFij9huP+gtef8AfEP/AMbo+w3H /QWvP++If/jdXqKO
ZhYo/Ybj/oLXn/fEP/xuj7Dcf9Ba8/74h/8AjdXqKOZhYo/Ybj/oLXn/AHxD /wDG6PsNx/0Frz/v
iH/43V6ijmYWKP2G4/6C15/3xD/8bo+w3H/QWvP++If/AI3V6ijmYWKP2G4/ 6C15/wB8Q/8Axuj7
Dcf9Ba8/74h/+N1eoo5mFij9huP+gtef98Q//G6PsNx/0Frz/viH/wCN1eoo 5mFij9huP+gtef8A
fEP/AMbo+w3H/QWvP++If/jdXqKOZhYo/Ybj/oLXn/fEP/xuj7Dcf9Ba8/74 h/8AjdXqKOZhYo/Y
6ijmYWMnUILu0026uY9Vuy8ULyKGSLBIBPPyVrVR1n/kBah/17Sf+gmr1N6o FucbH/yPur/9co//
AEFKKI/+R91f/rlH/wCgpRRi/wCJ8o/+kojD/A/WX5ss+A/+QRef9fr/APoK 11Nct4D/AOQRef8A
X6//AKCtdTWuJ/iv+uhND+GjPtoknm1aKQbkecKwzjIMMYNK2m28jyRO1y0Z QZUzy4Oc553YP07f
iKgMrwRa7LGdrpIWU4zgiCMisJvEiN4i1TSYZNWW5tbRZRPJp7KjtmbKljCF CDyvlfdtfcQpJBrC
W5sjs6jS3hjmlmSGNZZceY6qAz44GT3xUVxexW8EsrLJiNWY5XaOAx+82FH3 TySB055FYieKCLdb
6SGM2Um7aFlXegVwnXcVbJYHIIAHc8Zxq1qdNrnLjCUtjpKy9S8PaZq1ws95 BIzhBG4SeSNZkBJC
SqrASpy3yuGHzNx8xzDYeJrLUL2O1hVhI+cZliboCeiuT29KbrHii20e4mik tLudLW3F3eywhNtp
AS2JH3MCw/dyHCB2+Q8crmqVWFVc0HdClFxdmGp+G4LrRJLCx8u1k+0PdRTM ZSYpXdnkdSkiOC2+
QfK68OR93KmPSPCOnabplva3C/bpI4rmKSScs4kW4kEkylWZtyswH3yzYGCx JJMa+MraZJDb6bqU
0gvZLCGMRohuZ42lDrGXcKQqws+4kLjgEuCguWniSzuPDlxrlxHPZWtr9o+0 JOoLxeQ7pJkIWBwY
2+6TmtCSMeEdHFu8Rju3d3V/tMl9O9wpUEDbOXMigBnGFYDDuP42zT1TwJpO oQYj8+C4aWF3uftE
rSMqPbMw3b9wZltIl353Ajd1JzX074jaTqsTrYwT3F8JUiSygnt5nkLK7jDp KYh8sUpwzg/J0+Zd
1P8A4Tiew1vUYL62u5ALhUt7FIojKpZLBRHv8wJkSXZzksDk4YBQGAOgPhHR 2t0t3ju3iDs8ivfT
t9oLAA+fl/342qq4k3DaNvTirEPh7TLfVDqMcEgn3tIqGeQxRu2dzpEW2I53 NllUE73yfmbOW/je
1WeGxXTb5tXllki/szfAsylESRvmaURthJY2wrscP0+V9pZ+PtEvvFDaBDLm 6EskCN5sR3yxhi6+
WHMq42P8zIqnbwTuXcAWLrwVoN5p0FhJazpaw2i2QSC8mh3wKMLHIUcGRQCc B843N/eOdC10TTrO
6jube32TR/aNjb2OPPlEsvBP8TqD7YwMDiq+peJLPS/7X8+Odv7K09dQn2KD ujPm4C5Iy37luDgc
jnrixo2of2nYyXGc7Lu5t/8AV7P9VM8fTc39zrnnrhc7QARv4c0iW3jt5bGO WCO4nuRHISymSYSC
UkE4YMJpRtOR83TgYjg8L6TBA8Xkzzb5YZmkubuWeQtE4kjHmOxbarjcFzty W4+Y5x9O+I2k6rE6
2ME9xfCVIksoJ7eZ5Cyu4w6SmIfLFKcM4PydPmXcJ4vvTeanFcaXPbQ22oWd qkzJG4UzC1zE4E2f
MBnb5lBQAA/ORtYA3Lnw/p90LkN9rhN1cC5ma1vZoGeQRrGCWjdTjaijb04B xnmtCCCG1t4re3ij
hgiQJHHGoVUUDAAA4AA4xXLt4+sltY7j+zNSKXSRyaeAIs30byxRK8f7z5Ru niOJNhw/ThgI9R8V
X8kSCxtJ7FopXhvTPp0l+9vKFR0jMVs/O9JN/mBiq7dp+ZsAA7CiuPX4iaJD rFno019Bc3UvkRPc
28kSxtLKqlNkZkMrK29CCquoD8t8rER6T48kudB0Ca80e7/tbVrcSw2cLwKZ wsaO8ke+YDZ84wpb
zMZO3AJAB2lFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAcr rFtd3XhZlsrWS7ni
1aO48iNkVnWK+WRgC5Vc7UPUik/tTVP+hR1z/v5Zf/JNbulf8ecn/Xzcf+jX q9RNJvUUdjlP7U1T
/oUdc/7+WX/yTR/amqf9Cjrn/fyy/wDkmuroqeRFXOU/tTVP+hR1z/v5Zf8A yTSpquqK6t/wiGuH
Bz/rLL/5JrqqKOVBcx/CdjcaZ4N0OwvI/LurXT7eGZNwO11jUMMjg4IPStii iqEFFFFABRWJrWrS
WF/Z24v7CxjmildprxdwJUxgKPnXk7yep6U+38QLKkBmsrmHd5STsQNtvLIF IjYEhifnQZC4+bnG
DjT2UnFSRHOr2NiisLT/ABLHdwwu1rc+UfJR7rYixiSREZRt3lhnzEHQgE9c Amp9H1ae/wBK065u
LGeKS6Vc7QpUZj37+GOEOMDPOSARzQ6UkrsFOL2LuoLC2m3S3LskBhcSMvUL g5I/Cs3z/wDqI6x/
4Af/AGmrus/8gLUP+vaT/wBBNUdY8UW2j3E0Ulpdzpa24u72WEJttICWxI+5 gWH7uQ4QO3yHjlcy
nZFPcXz/APqI6x/4Af8A2mjz/wDqI6x/4Af/AGmqy+MraZJDb6bqU0gvZLCG MRohuZ42lDrGXcKQ
qws+4kLjgEuCguWniSzuPDlxrlxHPZWtr9o+0JOoLxeQ7pJkIWBwY2+6Tmnz Lt/X3CsM8/8A6iOs
f+AH/wBpo8//AKiOsf8AgB/9prK074jaTqsTrYwT3F8JUiSygnt5nkLK7jDp KYh8sUpwzg/J0+Zd
1P8A4Tiew1vUYL62u5ALhUt7FIojKpZLBRHv8wJkSXZzksDk4YBQGOZdv6+4 LHQ+f/1EdY/8AP8A
7TR5/wD1EdY/8AP/ALTVJ/G9qs8Nium3zavLLJF/Zm+BZlKIkjfM0ojbCSxt hXY4fp8r7Sz8faJf
eKG0CGXN0JZIEbzYjvljDF18sOZVxsf5mRVO3gncu45l2/r7gsXfP/6iOsf+ AH/2mjz/APqI6x/4
Af8A2mp7nWhDrMel29hd3k+yOSdoTGFto3ZlV33upIJSThAx+Q5HIzjt8QNN itY7uex1KO3uEjls
3EKyG7heWKMSRojM+AZ4jtYK5D8KSCAcy7f19wWNHz/+ojrH/gB/9po8/wD6 iOsf+AH/ANprOl+I
WjW3iCDRLkSQXjvDFIkk0G6GaUKUjKCTex+dBujV0G772FYrsX+uQ2Gs6fpR tbue5vkkePyYwyqq
NGHLsSAoAkByeuCBliqscy7f19wWIPP/AOojrH/gB/8AaaPP/wCojrH/AIAf /aapXHjqwg0zSb1L
K+n/ALVtI7q2hjWMOQ8kEaqdzhQ265j744bngZjj8YT3HiWw0uDSLvLpcLew P5Xm2jobYqzHzNhT
ZcBjsLn5lwMhhRzLt/X3BY0fP/6iOsf+AH/2mjz/APqI6x/4Af8A2msbS/iB Ff2lqY9J1K6lmSFE
kijhiWed7dLgxorTEqRExc7jtG0gMxwGkX4l+G5dYs9PhufM+1eQEl8yNMNM qtEPKZxMdwkj5VCo
3ckbW2nMu39fcFjV8/8A6iOsf+AH/wBpo8//AKiOsf8AgB/9pp/iTxHa+GNO jvbxN8byiID7RBDy
QT96aRFP3TwDn2xnGfaeOrC+nDW9lfPpplt4f7S2xiHfOkTxDaX835vPiH3O C3OACQcy7f19wWLv
n/8AUR1j/wAAP/tNHn/9RHWP/AD/AO01hTeOjfaVp01rZX2myX8tlNam7WFv tFtJdW8chGx32/LO
o+bafnGOQcanh3xUNehsjbWV3cJJbxPc3ipHFFDI8KzBWRpC4JV0Py7wN4G4 4bBzLt/X3BYs+f8A
9RHWP/AD/wC00ef/ANRHWP8AwA/+01z0fxKt9SlsY9GsZLyd70QXFpFPbSye W0E8isjpMYgd0JyG
fOFPHKk6A8cW0UV08ltd3KWT3D3s0MSItpBHPNEJHDSZYfuJPubmOwnau5Vo 5l2/r7gsaPn/APUR
1j/wA/8AtNHn/wDUR1j/AMAP/tNUv+E6sIvPmvbK+srCKW6hW+mWNo5Xt/MM gVUdpOkMrDcoyE9S
AdjRtUOsacl79hntI5MGITSQyeYhAIdWid1KnPHPbpjGTmXb+vuCxU8//qI6 x/4Af/aaPP8A+ojr
H/gB/wDaa26KOZdv6+4LGJ5//UR1j/wA/wDtNHn/APUR1j/wA/8AtNbdFHMu 39fcFjE8/wD6iOsf
+AH/ANpo8/8A6iOsf+AH/wBprboo5l2/r7gsYnn/APUR1j/wA/8AtNHn/wDU R1j/AMAP/tNbdFHM
u39fcFjE8/8A6iOsf+AH/wBpo8//AKiOsf8AgB/9prboo5l2/r7gsYnn/wDU R1j/AMAP/tNHn/8A
UR1j/wAAP/tNbdFHMu39fcFjE8//AKiOsf8AgB/9po8//qI6x/4Af/aa26KO Zdv6+4LGJ5//AFEd
Y/8AAD/7TR5//UR1j/wA/wDtNbdFHMu39fcFjn7mSGS0mS51LVxAyMJN1jgb cc5Pk8cV0FUdZ/5A
Wof9e0n/AKCavUm7oa3ONj/5H3V/+uUf/oKUUR/8j7q//XKP/wBBSijF/wAT 5R/9JRGH+B+svzZZ
8B/8gi8/6/X/APQVrqa5bwH/AMgi8/6/X/8AQVrqa1xP8V/10Jofw0ZsEK3L 6xA5IWSbYSOuDDGK
a+lLLcXO67kLywrHK4WISOmXwrYTO0bmxz1ZuncWZrZNbnQAtHKXAPTIgjNY p8YWLa5f6TBrmmTa
jawbzCpB3sPN3RqBKTvXyyWGMgFc+2EtzZHXVUj0uyivGu1t088ksGPO0nqV B4XOTnGM981K93bo
rEyqxUElU+ZjjOQFHJPytwOeDWYniGLiWS2nS1ZmVJdjEgq2w7kxlSWIAAyf UDBrGrOlFr2n9efl
6lxUn8Js1h6x4XttYuJpZLu7gS6txaXsUJTbdwAtiN9ykqP3kgyhRvnPPC4v W+rWl1OsMRn3tnG6
3kUdM9SoFQ6l4h0zSbhYLyeRXKCRykEkiwoSQHlZVIiThvmcqPlbn5Ti4VIT V4O/oS4tbmfqPhpk
0QQ6TJIL+C9mvrWV51jMcszyNIdxikXG2aVQDG3BHfDCPSfCPlaCun6veT3f nRXqXkSy7Y5vtUvm
Pu2quWXJUOAnDMQq7sC5/wAJfobJctHdyTfZrhrWRILeWR/OVnDRqqqSzjYz FVBIXDn5SCbllren
X2jtq0VxssU8zzJbhGg8vy2ZX3hwCu0qwOQMYqxGe/hYzRK1xruqz30Uolt7 12hDwEK6fKgjEXKy
SAkoSd3J+VNuXq/gEXha7tdTuxqT3EEj3Mpj/hksy7gCPbv22SEDG3cxyMEA bA8XaObd5TJdo6Oq
fZpLGdLhiwJG2AoJGBCucqpGEc/wNjLj8d2sOp6hFf8A7q1ilCwYt5zOymOz KgxBCSxe7CkfKw+U
bT8xABYu/BFrqGnTWN7qV9cQXcvm6gsiQH7ccIo8z918m1Y0UGLYRjOd3zVo Wfh9LHUWuIdQvham
WSdLDeohSWQsztkKHbLO52szKC2QBtXbGfF2ji3SUSXbu7sn2aOxne4UqATu gCGRQAyHLKBh0P8A
GubEPiHTLjVDp0c8hn3tGrmCQRSOudyJKV2O42tlVYkbHyPlbABl6h4Jg1DT jZ/2zqsPm6eunXcy
vE8l5CoYDzGkjb5v3kh3LtJLnOcDFweFbE2s1nLNdy2dwl6k9s0uElF1L5km QuDkEsqkHIDN1JzV
y61qys9RgsJGne6m2kJBbSTbAxwrSFFIjUkHDPgHa3PynGe3jbw7HBJcTah5 FumwieeGSKORWdUE
kbsoWSPc6ZdSVAdSSAQaAK//AAhaveSX8+varPqR8rybxxbh7fyxKBtVYghy txKDuVvvcYIBFh/C
cEkrvJqN8yyy21zcIfKAmuIGiZZmwmQxECKQpCYzhQTmrA8UaSbyG1M06yS7 Bl7SVUjZwCkcjlds
ch3LhHKt86jGWGbF7renadqNlp91cbLu+3fZoQjM0u0qGxgHpvUn0Xcx+VWI AMeLwLYRrbRve30s
Nl5S2MbtGBaRRyxSiJSEBZSYIgS5ZsJwwJJNyfw7Ibq8uLHW9S097y4+0Ti3 WBgzeVHEB+8ifACx
A8d2bOeAC48X6Ha2FleyXchgvrdbm28u3ldpY2eJFIVVLZLTxDbjPzdODiuv jTT5NZ06whiu5Bep
NlhazCSCSNoQFki2bowRMG3PtAG09GBoAksvCNnpk8Q068vrOxTyi9jDKPLl aJEjQsxUycLHGCA4
VgnzA7m3V7jwRa3Whx6FNqV9JoyfJ9hdIGRoRtCQljFv2qF4YMJOc7yQCCy8 e6JdWsTmWdpmiidl
trK5mRmkiSUJGwiHmNscPtA3bcsVAVsaA8U6M15DbR3nm+bsCzxRO8ALgFFa ZQY1ZgybVLAnemAd
y5ANiisvVfEGn6NcW9vd/a2nuEd4o7WymuWKoVDEiJGIALoMnHUVXXxhoEj3 SRalHMbVEeXyUaQA
OqNHgqCGLiRNgGS5yFyVYAA3KKwz4u0cW6SiS7d3dk+zR2M73ClQCd0AQyKA GQ5ZQMOh/jXNfw94
ttNT8K2GqXk0cc7pZx3SxxvtS4uEiZUHU4Jnj5yQN3J4OADpKK5e78dabA1k 0EF9dW9zdi3M0Vjc
MCDFLIrxYjPnqfKxmPIwwbOOuxa61ZX2oz2Vs08kkO4PILaTycqdrKJdvlsw PBUMSCGBGVOADQoo
ooAKKKKACiiigAooooAKKKKACiiigDjvEkEN14P+z3EUc0EuuWySRyKGV1Op ICCDwQRxij/hDvCv
/Qr6H/4LYf8A4mpNd/5FiL/sPWv/AKco61qmq7MI7GIfCHhQEA+GNCBY4GdO h5P/AHzQPCHhQkge
GNCJU4ONOh4P/fNas2Vlgk2sVR2LbVLHlGUcDk8kVXwPtJ82O52SGR0RFkVj gRLkheezdazV31KK
f/CHeFf+hX0P/wAFsP8A8TTo/BvhVpUB8L6HgkA/8S2H/wCJrWiWRYIhL/rd i7+n3sDPT3zUsX+u
T/eFF3cCn4E/5J54a/7BVr/6KWugrn/An/JPPDX/AGCrX/0UtdBWxIUUUUAQ PaRvfw3hLeZFE8Sj
PBDlCc+/yD9aqy6PDLeNOZ51jeVJ5bcFdkkibdrE43AjYnAYD5RkcnOjRVKb WwnFMybXw9aWlh9j
jknMfmwS5ZhnMIjC9uh8pc/U9O09rpa2cNvDHdXPk2z5ijLAAJsKCM4ALKAc jOTkAknFX6KbqSe7
EopFPVkeTRr6ONWZ2t5AqqMkkqeAKwdY03TdYuJpZJtXgS6txaXsUNm+27gB bEb7oiVH7yQZQo3z
nnhcdVRU3VrMZx2o2EKaIIdJGoC/gvZr61leKSMxyzPI0h3GCRcbZpVAMbcE d8MI9J0a3i0FdP1e
41O786K9S8iW3mWOb7VL5j7tsa5ZclQ4CcMxCruwO1oo0DU5J9MgmiVrjWPE M99FKJbe9e0w8BCu
nyoIRFyskgJKEndyflTbl6v4Xtrwtd2t/q41J7iCR7mW0b+GSzLuAIdu/bZI QMbdzHIwQB6DRRoG
pxV34d0zUNOmsb2+1q4gu5fN1BZLAH7ccIo8z9x8m1Y0UGLYRjOd3zVfs7Sz sdRa4hvNaFqZZJ0s
PsriFJZCzO2RGHbLO52szKC2QBtXb01FGganKw2FtbXFlcW+pa9HPBbw208j WrSNexxElRKXiY5y
8hLJtJ3nJ4GKkXhvR41to3udalhsvKWxje0YC0ijlilESkRAspMEQJcs2E4Y EkntaKNA1OZa0s/7
Ykv4bzWreOeVJ7i0htXWOeVVVVZj5fmDhIwVVwpCYIILbpLeCxg1KC/abV5p 4EukQzW0rfLPKkrD
7mcKY1VR2UY5610VFGganDJ4X0pZrMtf69Jb2CRx2Vq1p8lvGk0MyopEIdhm 3jXLsxwDzk5q+dN0
1dbk1iCbV4LyS4Mzulm5DIUhR4sNERsYW8RJHzAg4YAkV1VFGganHaT4f0XR o7FLdtXYWVxHcR+Z
ayHLJZi0AOIxx5Yz2+bnpxRpehabowtYrG+16K0hSESWy2zhbh4o0jR3YRb8 7Y4wVVlU7cFSGYN2
NFGganK3FhbSmGaHUtetryF7jZdpatJII5pBI8WJImXYCqAfLkCNQDjOcjRf C9tpks0El/q8mlpc
WslvZC0ba/2eCBI3kbyQ+8PAGwrBTtXI5YH0GijQNTz7RPC9tbaJpFvq9/q9 5d6fb20cZFowSDyn
hlZI9sKlkZ4Ixl9zYXggkk3LPw3o9lYHTYrnWv7MltFtbqya0YpdAQCDc7eV vVvLRB8jKPlBxyc9
rRRoGpxX9gWr3kl/PrPiGfUj5Xk3j2Kh7fyxKBtVbcIcrcSg7lb73GCAQS+G 9HkW5jS51qKG981b
6NLRiLuKSWWUxMTESqgzygFCrYfliQCO1oo0DU5U6bpot7aKGbV4Xtr25voZ Us3LLLOJtx+aIggf
aHIBHZc55zY0O303Qbe5jgGoSy3Vw11czyWDq00rAAuQkaoDhVHyqM4yckkn oqKNA1KP9q2//PO8
/wDAKb/4mj+1bf8A553n/gFN/wDE1eoo0DUo/wBq2/8AzzvP/AKb/wCJo/tW 3/553n/gFN/8TV6i
jQNSj/atv/zzvP8AwCm/+Jo/tW3/AOed5/4BTf8AxNXqKNA1KP8Aatv/AM87 z/wCm/8AiaP7Vt/+
ed5/4BTf/E1eoo0DUo/2rb/887z/AMApv/iaP7Vt/wDnnef+AU3/AMTV6ijQ NSj/AGrb/wDPO8/8
Apv/AImj+1bf/nnef+AU3/xNXqKNA1KP9q2//PO8/wDAKb/4mj+1bf8A553n /gFN/wDE1eoo0DUo
/wBq2/8AzzvP/AKb/wCJo/tW3/553n/gFN/8TV6ijQNTH1PUIrjSryCKG8aS SB0UfY5RklSB/DWx
RRQ30QHGx/8AI+6v/wBco/8A0FKKI/8AkfdX/wCuUf8A6ClFPF/xPlH/ANJR GH+B+svzZZ8B/wDI
IvP+v1//AEFa6muW8B/8gi8/6/X/APQVrqa1xP8AFf8AXQmh/DRmRwfaf7Zg 3bfNl2bsZxmGMZqO
XR5pbi7uDPbLPd2620sggfJjUuVGPMwMGR+cd+egqzY/8fmp/wDXyv8A6Kjq 9WMlqaobJHHNE8Uq
K8bqVZGGQwPUEdxWXH4b01JMmHfCufLtmx5UYY5YBQOQTg4bIBAxjFa1FZzp wnZyV7FKTWzKcGk6
bbTLNb6faRSr9144VVh24IFY+veF5tXuL5oL+O3g1OyXT79HtzIzQgyY8pg6 iN8TScsHH3fl4O7p
KKqMVHRKwNt7nJ3/AIfu9P0SKTTnkudQstTuNRtlWFGDNO825WRpYwQqXD/8 tF5UH/ZMeleGNRuf
CsmmazeeVHfxagL23giVSWupjIrBiX2Miu42guuW+8wUE9hRTEcXZ+BGsAlz Zy6NZahDcLPCbHR1
gt8iOWP95GJN7krNJ/y0ABC4Aw2+nrfgjVJrp9Vtb+CbUpbu3lK/ZtsanzbD e+DJkqosmbbuyQ+0
HIyfQKKAOLvPA1zfh5ZtStEvrm4ae5voLN454iY4ov8ARXEu6A7IlByZAxzk bfkqxpnge20zxK+q
xrpuDcT3KyDTUF2XlLFg9wSSUBkbAVVOAgLEBt3WUUAc/BoeqW2o2t+mrwS3 TWlva6i89nn7SIi5
3RhXURMxlkzneOVwODuy4vAk3labBPqsbwaSkEFgEtSrCGOeCUiUlyHci2jX coQDLHacgDtKKAOT
uPA9tP4sfWwumsZriK5kefTUluleNUVRFMxwiYjXjYSCXIZSQV1INGuBrVrq d1qH2iS3ivIQPJCZ
SaaORBwf4FiVOnzdTg9diigDh08BXm/SoZdZgax0iKK3so1sisnlx3FtKPMf zCGYi1VchVGWJx2r
UXwvNB4nm121v41nmuGZ45bcuvkvHbI6DDgh82qEPyBuIKtwa6SigDj9C8C/ 2JDpkf8AaPnfYbuK
5z5G3fssBZ7fvHGcb88/3feqelfDS20u6sJRJptwbdLUyXE+lo90XgijjXyp WYiNCIlO3axBZyGB
IK95RQByd9o/iNvEemXdnqNoTDb36SXV1Z+YqrLPC8UQjWRDkKm3fk58skjL Ciy8Dw6doNzpVrfS
bGuLS4tpJYwxja2jt1jDgEbwWtlLY25DEDHWusooA5OPwpqVvftrFvq1oNal eUzyyWLNbsrpAhCx
CUMpxbQ8mRud/HzALTsvAV5p2nWem22swfYUlsLi6EtkWklktRAo2MJAEVhb x8FXIJbk5AHcUUAc
nb+FNStdN06zh1a0xo7xnSmexY7FWJ4cT4lHmkxyHlfL+YZxj5auaV4bfTvE N7qhuYEjuPM22tlA
0EbF3DGSZTIyyTfKB5gVCQWzkbQvQUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAclrwf/hEzJHB
PN5OswTOkELSvsTUEdiEUFjhVJ4B6Un/AAkth/z761/4Ir7/AOM1cu9Vm0bw 7Jd29tHcztqP2eOK
SUxKWlu/KBLBWIAL56HpUf8Aa3ir/oC6H/4OJv8A5Fomk3qEdiv/AMJLYf8A PvrX/givv/jNJ/wk
mn7t32bWc4xn+wb7OOD/AM8fYflVn+1vFX/QF0P/AMHE3/yLR/a3ir/oC6H/ AODib/5FqLRHqV/+
ElsP+ffWv/BFff8AxmnJ4n09ZFY22tYBB/5AV9/8Zqb+1vFX/QF0P/wcTf8A yLSjVPFTMANF0PJ4
H/E4m/8AkWi0Quyz4LgmtfAvh63uIpIZ4tMtkkjkUqyMIlBBB5BB4xW5WfoW p/234e0zVvJ8n7da
RXPlbt2zegbbnAzjOM4FaFWIKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooA
42P/AJH3V/8ArlH/AOgpRRH/AMj7q/8A1yj/APQUoqsX/E+Uf/SUZ4f4H6y/ NlnwH/yCLz/r9f8A
9BWuprlvAf8AyCLz/r9f/wBBWuprXE/xX/XQmh/DRRsf+PzU/wDr5X/0VHV6 qNj/AMfmp/8AXyv/
AKKjq9WMtzVBRRRSGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQByWu/8ixF/wBh61/9OUdHiO/u9O0g TWJhW5kura3Rp4y6
L5s6RklQyk4Dk4yOlGu/8ixF/wBh61/9OUdWNY0tNY042b3E1v8AvYpllg27 0eORZFI3Bh95B1Bq
avxBHYyf+EjuNOu5NK1GD7bqg8owiwjEYuRIJSAFkfCMoglJDOQQoIOW2A/4 TfSQshkE0TReUJVk
2DYzSyxOD82D5ZgmZyMgKhYFgM1O3heF41kfUL1tSWUSrqR8szhgrIABs8va EkdduzHzs2NxLUQ+
EdJikhkkh+0skU0conVGE7SsWd3G3BbLzYxgATSAABsVloUVH8cWazXYXTdQ kt7JXkvLlRFst0Sa
aJnIMgZhmCRsKrHAHGTiuri/1yf7wrm08Haemm31j510UvdOXT55Cy73UeaT ITt5kYzOzMc5Jzjr
npIv9cn+8KOoFPwJ/wAk88Nf9gq1/wDRS10Fc/4E/wCSeeGv+wVa/wDopa6C tyQooooAKKy9aOtB
IzpC2rLhvOEpIkxxjy/4d3X73Gcds1yWi6hdmC5htZLpHkmYRteORG3ygtnP zbg3mZ2c7vvdKKnu
U3UYR96fKeg0Vzml3p07Tr/Ub+eQWFvbiR5Wd5QCgYylc5YrgD1zg1oWOu2e ovsgh1FDvCf6Rp1x
AMlWbq6AYwp56ZIHVgDNJupTVRLQqceWXKzTooqppuow6pavcQK6olxNbkOA DuilaNjwTxlDj2x0
6Vdna5JboqpZ6jDe3WoW8auHsbgW8pYDBYxJJkc9MSL1xyD9aNV1GHSNHvdT uFdobO3kuJFjALFU
UsQMkDOB60crvYC3RRUYmVrh4AH3oiuSUYLgkgYbGCflOQDkcZxkZQElFFFA BRRUFje2+pafbX1p
J5ltcxLNE+0jcjAFTg8jgjrRbqBPRRUckyxPEjByZX2LtRmAO0tyQMKMA8nA zgdSAQCSiiigAooq
OOZZXlRQ4MT7G3IygnaG4JGGGCORkZyOoIABJRUFve291PdQwybpLSUQzDaR scorgc9fldTx6+ua
noasAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQBxsf/I+6
v/1yj/8AQUooj/5H3V/+uUf/AKClFVi/4nyj/wCkozw/wP1l+bLPgP8A5BF5 /wBfr/8AoK11Nct4
D/5BF5/1+v8A+grXU1rif4r/AK6E0P4aKNj/AMfmp/8AXyv/AKKjq9VGx/4/ NT/6+V/9FR1erGW5
qgooopDCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiig
AooooAKKKKACiiigAooooAwZdJTW9BlspLme2/05pkmg270eO6MikblZfvIO oNRf8Ixf/wDQ361/
34sf/katXSv+POT/AK+bj/0a9Xqct2JbHOf8Ixf/APQ361/34sf/AJGo/wCE Yv8A/ob9a/78WP8A
8jV0dFTYZzn/AAjF/wD9DfrX/fix/wDkalHhnUAcjxfrQP8A1wsf/keuiop2 Ap6TpsOjaNY6XbtI
0Flbx28bSEFiqKFBOABnA9BVyiigAooooAp39u17GLRsiCQHzWViCQMfLx69 /bI78cxceHJ7rxAt
sgk/s6IxzNLID0DZ8sHqx+Xr2B55xu7F3SONpJGVUUEszHAAHcmqqatpskix x6haM7EBVWZSST2A
zWMox5rt7lxk7aFDxdb+b4G122hEaF9NuI03usaLmJgMsSAo9yQBXAeL5vDM +h/Z9F8S2V1K/wBo
3rdeIRNjdZXMSY86U7cvKo4x1BPAyPWqK7aVb2atYzaueS6le+FLbVnFheeH pfD6/Z5ZtKt760SO
6cLdK/7pnVCwL2zktjIjXBJQCrFnrfh+P4ftp0eraJasb+S4Onf2jbDNsb1p TB8rmP5oSU27tvzY
JAzXqVFW8Smkmtrde3yFY8Lnm8OXEs8iz6dZaQ17LKmk215pTMC0FsiyGOV2 gABinGQd43jHDNV+
9v8AQTpesWlxfaRqep3OmvBZapJq1pM1v/oYiMRlkdJMtIJDlUCnzdxxuYD2 Wir+t7e7+Icp4f4m
1Cw1HU9SnttX0v7XdRXkMk8N/p8dvNC1tKkKF9wnZs+RuDkoGBI4VSNa/fwf ceLLHOp+HrjRI/s/
mrcahBKrFY7/AHM4dyXbfPESxySz5ySCR61RSeL0sl0tv/wA5TwvXdR0FPD+ sx3c2kashsruDS4o
760lNhia5KMivICoMb24URgtiILgbVFdL441nw3rVxpz/wDCQadeWMCTCW1t r2wkYyMU2OUuiY8K
FkGfvDeAOC1en0UfWldS5dr9e/yDlPMLbW9AgvrCSXW9Imt7dLeO7WTXIpGu 51VQtyclQ5jwBlgr
P97bmGINzxbw0mgaJp5vNLS3sInhvLeyu9Mf7Xc7YVF0FnYxspCSDc22X5hw AWr3CilHFKOy/H+u
4cp5DaXHhy2FxetrWgyayupae0V++q28lwbdI7VJv3xKsQQk4OQpYFvl+bBz UudPazMWn63oljJ5
rmO9ur+0jvmc2d1H5s8sEjCTEk0e1x8/LEgkb29woprF26fj/wAAOU8eS68I X+sWb58PWGhC6ieX
S57yy2BlgulaYxxyMh3GWBc5LfJyAFBq3qfiHw5H4BbTptU0i8CauhSwjvre TdajUAyIAX2hBDtG
CQqqMHABx6tRSeJTabW1uvb5BY8eXVfDCTie4/sS60QyzGDQft9i32YsluFf y2lEIw0VwflYn9/n
qz4j0UeHH1uFvE2s+GtThjt3DzXOoW86yTfZ7CPeA7biS0E/JAPBzjcM+y0U /rWmi/EOU80+Hl7p
UeplLm80u912+tYGa9ivreeY7LaBJIWYOZGbfE7nAKY53ZyK9Loornq1PaS5 rDSsFFFFZjCiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA42P/kfd X/65R/8AoKUUR/8A
I+6v/wBco/8A0FKKrF/xPlH/ANJRnh/gfrL82WfAf/IIvP8Ar9f/ANBWuprl vAf/ACCLz/r9f/0F
a6mtcT/Ff9dCaH8NFGx/4/NT/wCvlf8A0VHV6qNj/wAfmp/9fK/+io6vVjLc 1QUUUUhhRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQ
AUUUUAUdK/485P8Ar5uP/Rr1eqjpX/HnJ/183H/o16vU5bsS2CiiikMKKKKA CiiigAooooAzPEMr
R6FcqiqzzhbddzYAMjCMEnB6Fs1iX93qMiSQXNkZIpFIMaNIw+91ytufTHXp g85zXQa1p66rot7Y
tHE5nhZFEoyobHyk8HocH8K5WbwY0hymjaLF14Tyz3z3tj9Pwqo+zs1Nbkvm +ybenaqbLRdQm1aQ
Iull/PlDGXEaoJMn5QSQjAdMnGe9RS+JptLHn+ILFNNs5EkeGVJzOw2RtKyy qq/K/lozfIXX5GG7
O3c+00G3s/Cl7ps+mwvHcrcGe0siEEoct8isdnO0hckr0HIArk9atfE2taNe 2l9omqXcgtZ4tPyt
nDtkkheISTMLlt7bXYfKqL8zHYTt27UYU5aPReb/AK+dxtvqdiPFekG3eUyX SOrqn2eSynW4YsCR
thKeYwIVzkKRhH/utiN/GWhpKqG5nOYhM7raTFIELMuZWCbYsNG4beV27Gzj BrjtR0jWNZdrzVvD
V1d34eIxq9pZtaFY1mCh4WvCWP8ApEpzvHIQ4+U7pE0e/j0nV7GPw1qkK6jp Y08i3hsIo4TunYsi
Lcgbc3BwvXC8sxJNaexo2+L8UK7O81LWbLSfKFy07SS52RW9vJPIwGMtsjVm 2jKgtjALKCckZjXx
DpUjokd6kju8SxqgLGXzF3IyYHzoQGO9cqAjkkbGxyXia1vfEFxZ3LeDbqSa 1SSNE1K3sruHbIUL
HZ9qUh8xrhs8AsMHORJAmr213ZXEPh/W1axiS1tk2aeqC3wnmIyrOBucopyu 0LsQBcBxJCow5U29
fVDuzX0zxtp1/oGn6nLDewyXkSuLVLKeWQfKrMVVY9zxjeo8wDZkjnJAq3F4 s0We++yQ3TyHfGnn
pbyG33SKroPPC+Xlg6YG7kuoHJArh59B1OfT9MtpfCs93/ZUTWtmNQsrK4jF uRGBvT7YN0o8pf3g
KjBYbBni/Dp9/b6fcWcXhvWxHJf2d4pxYLtFuLcBMLcBfm+z9goG7hcDnR0a PR/iu/8AkK7OlPi7
S2aFkn22zylDc3EUsMTKIpJd8cjJskXbETuDbdvO77oYfxjo0cSs73qyPKIl tzp1wJyxVmBEWzft
Ijk+bbt+Rucg1w//AAjWoXFo1tdeH9Xit3dwbXT1tILeNGt54T5UTXbiNz9o LMw4JVflzljpxW+v
S67a61qOg6pNewSoSLeK0ijaNIrhFXa125DZuXJbJBCqMDkkdGj0l+KC7Owm 8QabBow1Z53NmXWP
KQu772cRhPLCl9+87SuMg5BAINQHxXpAt0lEl07s7J9njsp2uFKgE7oQnmKA GQ5KgYdP7y55a9i1
7/hGn02x8NaoLk6oL9JZzabFze/aSCouctgZHUZx1XPEcdt4jgvm1eDRNRGs yvIZpJLe0a3ZXWFC
FiF6GU4touTIed/HI2yqNPrLq+q+X9fgF2dKfGmkLdPB5z3BLnyfsFtPdmRB FDIXPlxkAYnTkEgh
l5ySBY0jxLa6xquoWNujsLV08u4jRnhmjaKKQMJAuzP73G3cTgbuhrktA0m9 8P6rHdW/hzXpIYrd
reOKRrLdtMVpECWFxgkC0z0Gd/bHM/heHWPDMK20fh7V57U28Kyqy2au00cM cO8N9qwEKRL8hBOS
TuxxTlSpWfK9bd1uF2beo+MLK11iwsopP3T3UsV3cywSLBGkcE0jYmIEe5Wj AI3HGHBAIOLY8V6Q
bd5TJdI6uqfZ5LKdbhiwJG2Ep5jAhXOQpGEf+62OKv8AR9Y1EGxm0PV10Y3F 3ceSkdmLjdcRzK48
03e3ANw5H7voFBzySxND1OPT5oovBsEFxJLG4a30qyhjj2BwroEvRIsoLnEn mfKB8oUkkv2NGy97
8V3C7O4n8V6RbCRpZLpUhtzcTOLKcrAoj8wiQhMRvswdjYblePmGa8njTSIr hVMzyRSpGbc29tPN
JMXM2CqJGcoRA7BgSCATwNpblptO14abqel22ka2bLU7Vobl7xbSe4aT7MsA k8wXajoiMQVJJ3cj
cNsmtw+I7zxLaa1pnh7UYJonhDC5W0kVVjju1yAt0pYk3I4yuNpOT0pKjS7/ AIoLs3rjxzYRXF9H
GjvHb6b9uWcxTeWMGYOkpWNjCVMBBDDdklQu5cG/ceLNFtXulnunRLZJGkmN vJ5R8tS0ipJt2u6h
XyiksNjcfKccVJo+sfYdRtodD1dDqtlPbXzPHZtlpGnkDRAXY2ASXMhw2/Kh RkEFialo+salZ3Wn
NoerpYO95NbqI7MyxzXKTK5d/teHQfaJCFCqfu5Y4O5+xot7/iv6/r5BdnoG m6zZat5otmnWSLG+
K4t5IJFBzhtkiq204YBsYJVgDkHF+ud0lry48T32oXGj6jYpPZQQD7SbcqDE 8rcGOZySfO/ugDYe
eQK6KuWpFKVkUgoooqACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigDjY/
+R91f/rlH/6ClFEf/I+6v/1yj/8AQUoqsX/E+Uf/AElGeH+B+svzZZ8B/wDI IvP+v1//AEFa6muW
8B/8gi8/6/X/APQVrqa1xP8AFf8AXQmh/DRRsf8Aj81P/r5X/wBFR1eqjY/8 fmp/9fK/+io6vVjL
c1QUUUUhhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAUdK/485P+vm4/9GvV6qOlf8ecn/Xzcf8Ao16v U5bsS2CiiikMKKKK
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDj Y/8AkfdX/wCuUf8A
6ClFEf8AyPur/wDXKP8A9BSiqxf8T5R/9JRnh/gfrL82WfAf/IIvP+v1/wD0 Fa6muW8B/wDIIvP+
v1//AEFa6mtcT/Ff9dCaH8NFGx/4/NT/AOvlf/RUdXqo2P8Ax+an/wBfK/8A oqOr1Yy3NUFFFFIY
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABR
RRQAUUUUAFFFFAFHSv8Ajzk/6+bj/wBGvV6qOlf8ecn/AF83H/o16vU5bsS2 CiiikMKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDjY/+R91 f/rlH/6ClFEf/I+6
v/1yj/8AQUoqsX/E+Uf/AElGeH+B+svzZZ8B/wDIIvP+v1//AEFa6muW8B/8 gi8/6/X/APQVrqa1
xP8AFf8AXQmh/DRRsf8Aj81P/r5X/wBFR1eqjY/8fmp/9fK/+io6vVjLc1QU UUUhhRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUU
UUAUdK/485P+vm4/9GvV6qOlf8ecn/Xzcf8Ao16vU5bsS2CiiikMKKKKACii igAooooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigDjY/8AkfdX/wCuUf8A6ClF Ef8AyPur/wDXKP8A
9BSiqxf8T5R/9JRnh/gfrL82WfAf/IIvP+v1/wD0Fa6muW8B/wDIIvP+v1// AEFa6mtcT/Ff9dCa
H8NFGx/4/NT/AOvlf/RUdXqo2P8Ax+an/wBfK/8AoqOr1Yy3NUFFFFIYUUUU AFFFFABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFAFHSv8A
jzk/6+bj/wBGvV6qOlf8ecn/AF83H/o16vU5bsS2CiiikMKKKKACiiigAooo oAKKKKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigDjY/+R91f/rlH/6ClFEf/I+6v/1y j/8AQUoqsX/E+Uf/
AElGeH+B+svzZZ8B/wDIIvP+v1//AEFa6muW8B/8gi8/6/X/APQVrqa1xP8A Ff8AXQmh/DRRsf8A
j81P/r5X/wBFR1eqjY/8fmp/9fK/+io6vVjLc1QUUUUhhRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAU dK/485P+vm4/9GvV
6qOlf8ecn/Xzcf8Ao16vU5bsS2CiiikMKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACii
igAooooAKKKKACiiigDjY/8AkfdX/wCuUf8A6ClFEf8AyPur/wDXKP8A9BSi qxf8T5R/9JRnh/gf
rL82WfAf/IIvP+v1/wD0Fa6muW8B/wDIIvP+v1//AEFa6mtcT/Ff9dCaH8NF Gx/4/NT/AOvlf/RU
dXqo2P8Ax+an/wBfK/8AoqOr1Yy3NUFFFFIYUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFHSv8Ajzk/ 6+bj/wBGvV6qOlf8
ecn/AF83H/o16vU5bsS2CiiikMKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooo
oAKKKKACiiigDjY/+R91f/rlH/6ClFEf/I+6v/1yj/8AQUoqsX/E+Uf/AElG eH+B+svzZZ8B/wDI
IvP+v1//AEFa6muW8B/8gi8/6/X/APQVrqa1xP8AFf8AXQmh/DRRsf8Aj81P /r5X/wBFR1eqjY/8
fmp/9fK/+io6vVjLc1QUUUUhhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAUdK/485P+vm4/9GvV6qOl f8ecn/Xzcf8Ao16v
U5bsS2CiiikMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigDj
Y/8AkfdX/wCuUf8A6ClFEf8AyPur/wDXKP8A9BSiqxf8T5R/9JRnh/gfrL82 WfAf/IIvP+v1/wD0
Fa6muW8B/wDIIvP+v1//AEFa6mtcT/Ff9dCaH8NGXFdJaX2oLNFc/POrqUtp HBHlIOqqR1B/Kpv7
Vt/+ed5/4BTf/E1eorK6NbMo/wBq2/8AzzvP/AKb/wCJo/tW3/553n/gFN/8 TV6iloGpR/tW3/55
3n/gFN/8TR/atv8A887z/wAApv8A4mr1FGgalH+1bf8A553n/gFN/wDE0f2r b/8APO8/8Apv/iav
UUaBqUf7Vt/+ed5/4BTf/E0f2rb/APPO8/8AAKb/AOJq9RRoGpR/tW3/AOed 5/4BTf8AxNH9q2//
ADzvP/AKb/4mr1FGgalH+1bf/nnef+AU3/xNH9q2/wDzzvP/AACm/wDiavUU aBqUf7Vt/wDnnef+
AU3/AMTR/atv/wA87z/wCm/+Jq9RRoGpR/tW3/553n/gFN/8TR/atv8A887z /wAApv8A4mr1FGga
lH+1bf8A553n/gFN/wDE0f2rb/8APO8/8Apv/iavUUaBqUf7Vt/+ed5/4BTf /E0f2rb/APPO8/8A
AKb/AOJq9RRoGpR/tW3/AOed5/4BTf8AxNH9q2//ADzvP/AKb/4mr1FGgalH +1bf/nnef+AU3/xN
H9q2/wDzzvP/AACm/wDiavUUaBqUf7Vt/wDnnef+AU3/AMTR/atv/wA87z/w Cm/+Jq9RRoGpR/tW
3/553n/gFN/8TR/atv8A887z/wAApv8A4mr1FGgalH+1bf8A553n/gFN/wDE 0f2rb/8APO8/8Apv
/iavUUaBqUf7Vt/+ed5/4BTf/E0f2rb/APPO8/8AAKb/AOJq9RRoGpR/tW3/ AOed5/4BTf8AxNH9
q2//ADzvP/AKb/4mr1FGgalH+1bf/nnef+AU3/xNH9q2/wDzzvP/AACm/wDi avUUaBqUdJz9hLMj
punmcB1KnBlYjg8jgir1FFDd3caCiiikAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFF
FFABRRRQAUUUUAFFFFAHGx/8j7q//XKP/wBBSiiP/kfdX/65R/8AoKUVWL/i fKP/AKSjPD/A/WX5
ss+A/wDkEXn/AF+v/wCgrXRSXlrE5SS5hRx1VnAIrnfAf/IIvP8Ar9f/ANBW tCO4jtdJF1O+2OOH
zZXwTxjLHjk9zXRWjzVX8vyM6UrU0aH9oWX/AD+W/wD39X/Gj+0LL/n8t/8A v6v+NQRyJNEksTq8
bgMrKchgehB7isPWPGWhaFqD2OoXM63KWpvHSK0mm2QAkGRiiEKoIOSelZck UaczOj/tCy/5/Lf/
AL+r/jR/aFl/z+W//f1f8arQTw3VvHcW8qSwyoHjkjYMrqRkEEcEEd6zNe8R Wnh7+zPtcc7/ANo3
8WnxeUoO2STO0tkjC8HOMn2o5Ij5mbn9oWX/AD+W/wD39X/Gj+0LL/n8t/8A v6v+NRVg6l4x0bSN
Wi0u8e9W9mz5MUenXEvnYUM2wohD4BBO0nHfFHLEOZnR/wBoWX/P5b/9/V/x o/tCy/5/Lf8A7+r/
AI1FVe+vbfTdPub67k8u2tommlfaTtRQSxwOTwD0o5Ii5mXf7Qsv+fy3/wC/ q/40f2hZf8/lv/39
X/GqVje2+pafbX1pJ5ltcxLNE+0jcjAFTg8jgjrVijkiHMyX+0LL/n8t/wDv 6v8AjR/aFl/z+W//
AH9X/GoqKOSIczJf7Qsv+fy3/wC/q/40f2hZf8/lv/39X/GoqKOSIczJf7Qs v+fy3/7+r/jR/aFl
/wA/lv8A9/V/xqKijkiHMyX+0LL/AJ/Lf/v6v+NH9oWX/P5b/wDf1f8AGoqK OSIczJf7Qsv+fy3/
AO/q/wCNH9oWX/P5b/8Af1f8aioo5IhzMl/tCy/5/Lf/AL+r/jR/aFl/z+W/ /f1f8aioo5IhzMl/
tCy/5/Lf/v6v+NH9oWX/AD+W/wD39X/GoqKOSIczJf7Qsv8An8t/+/q/40f2 hZf8/lv/AN/V/wAa
ioo5IhzMl/tCy/5/Lf8A7+r/AI0f2hZf8/lv/wB/V/xqKijkiHMyX+0LL/n8 t/8Av6v+NH9oWX/P
5b/9/V/xqKijkiHMyX+0LL/n8t/+/q/40f2hZf8AP5b/APf1f8aioo5IhzMl /tCy/wCfy3/7+r/j
R/aFl/z+W/8A39X/ABqKijkiHMyX+0LL/n8t/wDv6v8AjR/aFl/z+W//AH9X /GoqKOSIczJf7Qsv
+fy3/wC/q/40f2hZf8/lv/39X/GoqKOSIczJf7Qsv+fy3/7+r/jR/aFl/wA/ lv8A9/V/xqKijkiH
MyX+0LL/AJ/Lf/v6v+NH9oWX/P5b/wDf1f8AGoqKOSIczJf7Qsv+fy3/AO/q /wCNH9oWX/P5b/8A
f1f8aioo5IhzMl/tCy/5/Lf/AL+r/jR/aFl/z+W//f1f8aioo5IhzMl/tCy/ 5/Lf/v6v+NH9oWX/
AD+W/wD39X/GoqKOSIczJf7Qsv8An8t/+/q/40f2hZf8/lv/AN/V/wAaioo5 IhzMl/tCy/5/Lf8A
7+r/AI0f2hZf8/lv/wB/V/xqKijkiHMyX+0LL/n8t/8Av6v+NH9oWX/P5b/9 /V/xqKijkiHMyX+0
LL/n8t/+/q/40f2hZf8AP5b/APf1f8aioo5IhzMl/tCy/wCfy3/7+r/jR/aF l/z+W/8A39X/ABqK
ijkiHMyX+0LL/n8t/wDv6v8AjR/aFl/z+W//AH9X/GoqKOSIczJf7Qsv+fy3 /wC/q/40f2hZf8/l
v/39X/GoqKOSIczJf7Qsv+fy3/7+r/jR/aFl/wA/lv8A9/V/xqKijkiHMyX+ 0LL/AJ/Lf/v6v+NH
9oWX/P5b/wDf1f8AGoqKOSIczJf7Qsv+fy3/AO/q/wCNH9oWX/P5b/8Af1f8 aioo5IhzMl/tCy/5
/Lf/AL+r/jR/aFl/z+W//f1f8aioo5IhzMl/tCy/5/Lf/v6v+NH9oWX/AD+W /wD39X/GoqKOSIcz
Jf7Qsv8An8t/+/q/40f2hZf8/lv/AN/V/wAaioo5IhzMl/tCy/5/Lf8A7+r/ AI0f2hZf8/lv/wB/
V/xqKijkiHMyX+0LL/n8t/8Av6v+NH9oWX/P5b/9/V/xqKijkiHMyX+0LL/n 8t/+/q/40f2hZf8A
P5b/APf1f8aioo5IhzMl/tCy/wCfy3/7+r/jR/aFl/z+W/8A39X/ABqKijki HMyX+0LL/n8t/wDv
6v8AjR/aFl/z+W//AH9X/GoqKOSIczJf7Qsv+fy3/wC/q/40f2hZf8/lv/39 X/GoqKOSIczJf7Qs
v+fy3/7+r/jR/aFl/wA/lv8A9/V/xqKijkiHMyX+0LL/AJ/Lf/v6v+NH9oWX /P5b/wDf1f8AGoqK
OSIczJf7Qsv+fy3/AO/q/wCNH9oWX/P5b/8Af1f8aioo5IhzMl/tCy/5/Lf/ AL+r/jU0U0U6lopE
kUHGUYEZqpTYeNSTHG6F8++CuP5n8zQ4K2g1JnOx/wDI+6v/ANco/wD0FKKI /wDkfdX/AOuUf/oK
UVGL/ifKP/pKFh/gfrL82WfAf/IIvP8Ar9f/ANBWrF7bS3XhSe3hXdLNYsiL kDLFMAZP1qv4D/5B
F5/1+v8A+grW5DbXcEEcS3EBVFCgmA5wBj+/XVVly1W/T8jKlG9NfMxvC+iP oOixWMly08m4uxz8
qk9VT0X+ZJPGcVwvj/wnrGqeML6+tNKvbu2n8OSafC9pepBtuGkYqJAZULR4 IyDuByODjj1fyrz/
AJ72/wD34b/4ujyrz/nvb/8Afhv/AIusZz525Se5rGPKrI8R1bwD4om/tCI2 EFzqM9rpcWm6nbvF
HHprwYE2zO14lLBmAiQ5DdAeBPeeCNdk8TLcSaJ9quR4tj1Qat5sJxYALiLc zCX5cD5NuPl4zxXs
/lXn/Pe3/wC/Df8AxdHlXn/Pe3/78N/8XU6dx6nkHw+8N58balJHd/aNA8M3 VzZ6PF5ezyZpSGnX
Od7bAdmX3Bt2QRiut8QaLqF98Q/B2qW9vvstO+2/apd6jy/MiCpwTk5IxwDj vXZeVef897f/AL8N
/wDF0eVef897f/vw3/xdF13CzPI7HwRqEXjm71TU7XV5ZjrhvbS+sZbQIICF CpI7kT7ApZGjHy4H
APU5Nh8O/ErW9nBcWSJZvZatb2djJOm3RGnDBCZVJa4DA7eh27s9RXuXlXn/ AD3t/wDvw3/xdHlX
n/Pe3/78N/8AF0adw1OW8AaU2k+ELGxk0X+yrmGKNLlMRfvpRGoaXMbMDkjq cMccjpXT+Wad5V5/
z3t/+/Df/F0eVef897f/AL8N/wDF07ruFhvlmjyzTvKvP+e9v/34b/4ujyrz /nvb/wDfhv8A4ujm
8wsN8s0eWad5V5/z3t/+/Df/ABdHlXn/AD3t/wDvw3/xdHN5hYb5Zo8s07yr z/nvb/8Afhv/AIuj
yrz/AJ72/wD34b/4ujm8wsN8s0eWad5V5/z3t/8Avw3/AMXR5V5/z3t/+/Df /F0c3mFhvlmjyzTv
KvP+e9v/AN+G/wDi6PKvP+e9v/34b/4ujm8wsN8s0eWad5V5/wA97f8A78N/ 8XR5V5/z3t/+/Df/
ABdHN5hYb5Zo8s07yrz/AJ72/wD34b/4ujyrz/nvb/8Afhv/AIujm8wsN8s0 eWad5V5/z3t/+/Df
/F0eVef897f/AL8N/wDF0c3mFhvlmjyzTvKvP+e9v/34b/4ujyrz/nvb/wDf hv8A4ujm8wsN8s0e
Wad5V5/z3t/+/Df/ABdHlXn/AD3t/wDvw3/xdHN5hYb5Zo8s07yrz/nvb/8A fhv/AIujyrz/AJ72
/wD34b/4ujm8wsN8s0eWad5V5/z3t/8Avw3/AMXR5V5/z3t/+/Df/F0c3mFh vlmjyzTvKvP+e9v/
AN+G/wDi6PKvP+e9v/34b/4ujm8wsN8s0eWad5V5/wA97f8A78N/8XR5V5/z 3t/+/Df/ABdHN5hY
b5Zo8s07yrz/AJ72/wD34b/4ujyrz/nvb/8Afhv/AIujm8wsN8s0eWad5V5/ z3t/+/Df/F0eVef8
97f/AL8N/wDF0c3mFhvlmjyzTvKvP+e9v/34b/4ujyrz/nvb/wDfhv8A4ujm 8wsN8s0eWad5V5/z
3t/+/Df/ABdHlXn/AD3t/wDvw3/xdHN5hYb5Zo8s07yrz/nvb/8Afhv/AIuj yrz/AJ72/wD34b/4
ujm8wsN8s0eWad5V5/z3t/8Avw3/AMXR5V5/z3t/+/Df/F0c3mFhvlmjyzTv KvP+e9v/AN+G/wDi
6PKvP+e9v/34b/4ujm8wsN8s0eWad5V5/wA97f8A78N/8XR5V5/z3t/+/Df/ ABdHN5hYb5Zo8s07
yrz/AJ72/wD34b/4ujyrz/nvb/8Afhv/AIujm8wsN8s0eWad5V5/z3t/+/Df /F0eVef897f/AL8N
/wDF0c3mFhvlmjyzTvKvP+e9v/34b/4ujyrz/nvb/wDfhv8A4ujm8wsN8s0e Wad5V5/z3t/+/Df/
ABdHlXn/AD3t/wDvw3/xdHN5hYb5Zo8s07yrz/nvb/8Afhv/AIujyrz/AJ72 /wD34b/4ujm8wsN8
s0eWad5V5/z3t/8Avw3/AMXR5V5/z3t/+/Df/F0c3mFhvlmjyzTvKvP+e9v/ AN+G/wDi6PKvP+e9
v/34b/4ujm8wsN8s0eWad5V5/wA97f8A78N/8XR5V5/z3t/+/Df/ABdHN5hY b5Zo8s07yrz/AJ72
/wD34b/4ujyrz/nvb/8Afhv/AIujm8wsN8s0eWad5V5/z3t/+/Df/F0eVef8 97f/AL8N/wDF0c3m
FhvlmjyzTvKvP+e9v/34b/4ujyrz/nvb/wDfhv8A4ujm8wsN8s0eWad5V5/z 3t/+/Df/ABdHlXn/
AD3t/wDvw3/xdHN5hYb5Zo8s07yrz/nvb/8Afhv/AIujyrz/AJ72/wD34b/4 ujm8wsN8s0eWad5V
5/z3t/8Avw3/AMXR5V5/z3t/+/Df/F0c3mFhvlmjyzTvKvP+e9v/AN+G/wDi 6PKvP+e9v/34b/4u
jm8wsN8s0eWad5V5/wA97f8A78N/8XR5V5/z3t/+/Df/ABdHN5hYb5Zo8s07 yrz/AJ72/wD34b/4
ujyrz/nvb/8Afhv/AIujm8wsN8s0eWad5V5/z3t/+/Df/F0eVef897f/AL8N /wDF0c3mFhvlmjyz
TvKvP+e9v/34b/4ujyrz/nvb/wDfhv8A4ujm8wsN8s0yNSupRZ/54yfzSpfK vP8Anvb/APfhv/i6
I7eYXKzTSxttRlASMr1IPdj6Ucy7hY5aP/kfdX/65R/+gpRRH/yPur/9co// AEFKKjF/xPlH/wBJ
QsP8D9ZfmyLwhNdR6ddiCSFV+1uSHjLHOF9GFdD9q1D/AJ7Wv/fhv/i64/S/ t/8AwiGuf2V/yEsz
/ZPu/wCt8sbPvcfex149aqRxabPe28Pgu5htb6TzV1GeGPfJEphkCtcq3LSi byziT94SJO3mU8U3
7Z/10DD/AMNHd/atQ/57Wv8A34b/AOLo+1ah/wA9rX/vw3/xdee6j4j1+bSx qMTw6XbS3SWcnn3E
apatGkhmczmN1X98BB8yMD5eV/1gIn0S88Ra1c3FsdchhEemJJHLb24lV5Hk uo0l3Mib12xoxwqq
5VSu1CQ3Pd9zY7v7VqH/AD2tf+/Df/F0fatQ/wCe1r/34b/4uvOdS8Q65Pb2 2rwWSLIs8sNtp7Rr
cH7RDZXTSYYANnzh5Py4yISVO2SmWXiTX4bb7VHqFlrNtFdRoTa3cc3mNJHK iQmZYI0GZjbDAUsu
8s52EUXkGh6T9q1D/nta/wDfhv8A4uore/1Ce2im8y1XegbHkscZGf79c/4Z vNXub+/ttSk8xbCK
G1d8IPMuFMheTC9N8TW0m3kLv2jkNWf4o/sn7F4U/tz7F/Zv24ed9u2eT/x6 T7d2/j72MZ74pXYH
a/atQ/57Wv8A34b/AOLo+1ah/wA9rX/vw3/xdeZX2ralpwSHTL+103w/NPM1 leXF0ltGIljgCxxy
SRSrsZ2uCq7eVQFCI1AM9l4k1KTVHS41xDqi3llCNFjjRVeKSK3aZxG6CfC+ ZM+SRt2fMMKwp3kG
h6N9q1D/AJ7Wv/fhv/i6PtWof89rX/vw3/xdeV2PiTxJeWgM2sWsc1w1otxF bSJNNYSSXMMbRlDA
FhO2SVdkrSNleCdjk6s2t3dtqk+lal4ifT7C1nljOrSi3jkkcRW0iRszp5WT 583AQEiIejEl5Ad3
BqN3c28dxb3dlLDKoeOSOIsrqRkEEPggjvUn2rUP+e1r/wB+G/8Ai68n8L65 rSJ4fskvrK3gS10+
KGylmAkuYWgiLyLCIWkfBaQB1kVFMfzDCOTft9e1u00PRbibV5rltV0yO8uJ p4YR9jHm2qySJsRQ
FVLiRyXDAeWpPAYEu+4aHpP2rUP+e1r/AN+G/wDi6PtWof8APa1/78N/8XXm Wpa7d21450nXLW6t
pILRZdYmlt4wiF70lmnWJowN8aRjKEZYgAM26rdt4h1Q3uhxXmrQyCfaFg0u WJp7jMzqJXSWJS8H
lqpMkIT+NgpTBQvINDvVv9QNy8PmWvyorZ8luckj+/7VL9q1D/nta/8Afhv/ AIuqyf8AIRm/65R/
zevLPDsV7pHhW2u7HTrXTLuXw2xsjYjzDqVwYldS42KPOQRkhDv3CV9pIV6S bA9c+1ah/wA9rX/v
w3/xdH2rUP8Anta/9+G/+LrgLvxLJrXi6303Q/ESfYJWt0ebTzBMVYxXrsNz K4yfJh4I4A4xk5xr
3Ubkr4jvbvU/LnXR7m1giljhKai1tLfIdysh3sqhHZUwPn5XaQKd2Gh6x9q1 D/nta/8Afhv/AIuj
7VqH/Pa1/wC/Df8AxdebXWva3bW9/eLq8zeVFq96kTQw7B9juPLji4TOxlb5 ud3yjay85vaRrmtX
XjSS1uL6yEX2q4ifTvODTRQoXEcnlCHfHu2xtveUoQ/ABdAC8g0PQrC6uJrm eGcxNsRGUxoV6lhz
kn+7V+uM8Vf8ib4w/wCwJL/6LmrO0q50rStGuJfDd/4Yu9U+0Ji30C0jhW8O 1tkDhXcgnEjCTcAm
0sQURw1x1QmeiUV5m+o3dtrOoata6xJd376ErWdqbdI11K5ia8ZoREV83MRK gxqwdcgOWPJj0zWt
e1G5sbBfFEE1vc6gsP27TZ4btwPs1zI0fmfZkh6xRHaELjJJOHWqEeoUV5vB 4n1J9Y0y1udW3L9r
ktBbWT2/2y4Md3LD5s0LpzDsiBZoSpU+Ydu3lKfhzxLqDaboqtqccN5s02K2 0eOGFFu7aSK3Ms4j
C78J5k/MZVF8jkYVsgHqlVdQnktrMyRbd+9FG8ZHzMB0yPWvObfX9etPDmkX MviKBptW0QX8lzqz
Q28Vq4e2B2OkWFyLh8b1k+YR8Ebg3VabfHUvBlrdmS+l8yVSJL5YRK4E+A37 n92VIAKsvDKVOTnN
J7AaH2rUP+e1r/34b/4uj7VqH/Pa1/78N/8AF15z4jj0R/iJK2t3XhyGFdOt Ds1m2SRpF8243CJm
dQhxjJw3VeOOZ/El7e32n+INLivHnt3s7xLUx2+Wu5zE4a2DAYYx8n5QGb7u SYZd2d33KO/+1ah/
z2tf+/Df/F0fatQ/57Wv/fhv/i6821bxFqkFzbR6T4jsri1FqJba7urmIf2h MZJA0YWOB/O27EXZ
Dsf5wMksCLR1jWbW3GoDWEc3Wo6jZrDfrGlrbrCLpo2LIquAPs6BiWPyluM4 ILyDQ7/7VqH/AD2t
f+/Df/F0fatQ/wCe1r/34b/4uvLk8R3pe1nivpp8RXEcuoTLbSqkfn2SSSwS xoqtEiySNuYAZQ+Y
vybRpafqGp6xrsWm23iO6Onqt08Oo20duzXioLTBLGMxkK80yZRR9zByQcl3 3DQ7/wC1ah/z2tf+
/Df/ABdH2rUP+e1r/wB+G/8Ai64DVpZfEnh3wRdXGm6ffTX08c8lpdErbszW U7kHKuQAeRweQPrU
F7eal4atpbE6olnNbWbXWm2cYQpezvJMwtE3rukSMCGNVj2NhxwNyhS77gej fatQ/wCe1r/34b/4
uj7VqH/Pa1/78N/8XXmSavq0cHiW7t9Se3j0eC6vI7WK3hEUzi7vRiT5NxBE KAlWUn5jncc1INRm
0fSNRCeIYbSUaxcG5trm4t4JLaJ555FEPmIRvkG1gJcqy5wUHzAu+4Hokl/q EckK+ZanzH258luP
lJ/v+1S/atQ/57Wv/fhv/i6y7OZrjT9HmcXQeRUdhdoqTAmJj+8VQAH9QAAD muCuUtB8QNUkWfTD
qQ1izEdukIGotH5VtuZJd2REFLl12EFBIMjJKpNgeo/atQ/57Wv/AH4b/wCL quNXmNpFdi/08202
zypgh2PvICbW34O4sAMdcjHWvOn8WT3sHhqzOoWs96YLV9VtysTvFcfa7JDv TGY3BklGMDB6YKjG
bp+pGXw14fs7vWfskkUuipaaZmJftcWbVzLhlMjYdpBlGC/usY4bLuwPWlv9 QNy8PmWvyorZ8luc
kj+/7VL9q1D/AJ7Wv/fhv/i6rJ/yEZv+uUf83rynS9BuIfB3hdnbOlW0ulX1 omBxcTTQiTnO75cz
NzwftWAB5YpJvuB6/wDatQ/57Wv/AH4b/wCLo+1ah/z2tf8Avw3/AMXXjN5f 3J0fVtYl0i9tovEm
mX++6keErPiJ5bP5VkJXbbpIpwoySM7jyJ/FP2TT4dT8PX/k+Vpvh3UPsnnY 2mB3t/s2M/xK6mIZ
JYmIN1YU9e4Hr/2rUP8Anta/9+G/+Lo+1ah/z2tf+/Df/F157o3h+01DxRqm pWEPh9rO3v7byHfT
BNII1tbZl8mUSAIuCNuFIB556Vi+Ebfwy3ghBLrPhW2um062M0lvBHFLGoKF kuj5hMiM+xHB2bsk
cFhgu+4Hrn2rUP8Anta/9+G/+Lo+1ah/z2tf+/Df/F15lLpmiah4VAGkaFPD b63ZxQ3djZIlvcrJ
PbeY8YywAIJibDNkxkE/wjd8ZQaVd+Hm8OGJPJWfTUltY1KKsEl2iKARgAEI 4wDkY7cUXYHYfatQ
/wCe1r/34b/4uori/wBQgtpZvMtW2IWx5LDOBn+/XkviPRb99UspNYkhuNSu 4ksy88CtG8Ud/Yoh
aNSAyuzSSlcggTbCflBr0DTtH/sTw/e23laZHuDyY02x+yR8oBym9stx1z0w McUXfcDf+1ah/wA9
rX/vw3/xdRx6jdyvKkd3ZO8LbJFWIko2A2D8/BwynHoQe9cv4o1VbLXtKtLn xJ/YdnPa3MjzboF8
yRGgCrumRh0dzgc/lWF4d8R3FprM95r08Ol213+8vBcYhjS6Nnp5VMvyrYM2 FJyQrddvBdgek/at
Q/57Wv8A34b/AOLo+1ah/wA9rX/vw3/xdeXWPivUbiw0me98QfZdQll0tIrD bAv26KYW5ll2shc5
aSZcoQo8vplTmTwzq+rN4ftdSOpOIoJ9Ls1sUt4Ut9k0NoHOFQMCDO5ADAAh RjAwS8gPTftWof8A
Pa1/78N/8XR9q1D/AJ7Wv/fhv/i65rWNddYYLjR7rzpjLNAbX7M0u4Rvslk2 rh/3TKTwcP8AcHzS
RkYsWoand6x9nt/Ed1JaT6jHYRSxR27fu/sC3PmqfLILswPJyu1zhQdpCuwO 3k1W7WK6aO5spXts
iRFiOVbaG2n5+DgqfoQe9SHUbtbhLdruyEzqzrGYjuZVIDEDfkgFlye24etc X4O1CXVtB1zUrhUW
a7aGeRYwQoZ9PtWIGSTjJ9ak8V3Nra+LdFe78Qf2HGbC9AufMhTcfMtvkzMr LzyeBn5frTuwO0+1
ah/z2tf+/Df/ABdRx6jdyvKkd3ZO8LbJFWIko2A2D8/BwynHoQe9cDb+ML9b BI9VuobDWbq/00Q2
MirHIYpRa+cEjb5iu5rhc8kEMM5XjF8L6xJHZRC71hNEsrlYppr6NYIlEwsL DZEPMUxqGDyNtCg/
u+MAEEvIND1iDUbu5t47i3u7KWGVQ8ckcRZXUjIIIfBBHepPtWof89rX/vw3 /wAXXnttriWHww0W
KDUvsNzDYaSZ59q/uIZpEjL5dSn3Vk65xjJ7VPpOr6pqPiW1sLbW/tOlL9pk W9EUTtexxi0Iw6gJ
w8ssZKrjCkY3jeC7A7v7VqH/AD2tf+/Df/F0fatQ/wCe1r/34b/4uvLpPFeo rplvN/wkG2SeK3fV
Dtg/4k8rXNujRfc/d/LLOMTbm/ddflbMl94m1ZQkNrr1qNLE8yxa3c3MNutw FjgKqJfJkiY7pJ1w
qAnyeuUfcXkGh6b9q1D/AJ7Wv/fhv/i6PtWof89rX/vw3/xdebXVzrWraLqc +o6j5Mdpf6aClvbC
MW3/AB5zSykyruCpl2AcDaN2/PASvfa/qNvfXUVlrNlBYPdZbVZ54LYTEWlm UBl8iSNmcSSNjZkh
PlIVNpLvuB6j9q1D/nta/wDfhv8A4uoo7/UJJJl8y1Hlvtz5Lc/KD/f9643S 9d1K48VWVnf36PLJ
AjNZ6aU2xHyA7tcxSoJ4gXPyEHHKBgpPz9dbf6+7/wCuo/8AQFpczAs/atQ/ 57Wv/fhv/i6PtWof
89rX/vw3/wAXSUUczCwv2rUP+e1r/wB+G/8Ai6PtWof89rX/AL8N/wDF0lFH MwsL9q1D/nta/wDf
hv8A4uj7VqH/AD2tf+/Df/F0lFHMwsL9q1D/AJ7Wv/fhv/i6PtWof89rX/vw 3/xdJRRzMLC/atQ/
57Wv/fhv/i6PtWof89rX/vw3/wAXSUUczCwv2rUP+e1r/wB+G/8Ai6PtWof8 9rX/AL8N/wDF0lFH
MwsL9q1D/nta/wDfhv8A4uj7VqH/AD2tf+/Df/F0lFHMwsL9q1D/AJ7Wv/fh v/i6PtWof89rX/vw
3/xdJRRzMLC/atQ/57Wv/fhv/i6PtWof89rX/vw3/wAXSUUczCwv2rUP+e1r /wB+G/8Ai6PtWof8
9rX/AL8N/wDF0lFHMwsL9q1D/nta/wDfhv8A4uj7VqH/AD2tf+/Df/F0lFHM wsL9q1D/AJ7Wv/fh
v/i6PtWof89rX/vw3/xdJRRzMLHP2LSP411RpSpcxJkouB91e2T/ADoosf8A kddU/wCuSf8AoK0V
viv4i/wx/wDSUY0PgfrL82Zeia3DpVtcQT2107PO0gMaAjBAHcj0rU/4S+z/ AOfO+/79D/4qugoq
p16c3zShr6sUaU4qylp6HP8A/CX2f/Pnff8Afof/ABVH/CX2f/Pnff8Afof/ ABVdBRU+1o/8+/xY
+Sp/P+Bz/wDwl9n/AM+d9/36H/xVH/CX2f8Az533/fof/FV0FFHtaP8Az7/F hyVP5/wOf/4S+z/5
877/AL9D/wCKqK28VWkNpDE1nelkRVOIhjIH1rpaKPa0f+ff4sOSp/P+Bz// AAl9n/z533/fof8A
xVV7fxFpdrNdTQ6ffLJdSiaY7AdzhFQHluPlRRx6fWuooo9rR/k/FhyVP5/w Of8A+Evs/wDnzvv+
/Q/+Ko/4S+z/AOfO+/79D/4qugoo9rR/59/iw5Kn8/4HP/8ACX2f/Pnff9+h /wDFUf8ACX2f/Pnf
f9+h/wDFV0FFHtaP/Pv8WHJU/n/A5/8A4S+z/wCfO+/79D/4qj/hL7P/AJ87 7/v0P/iq6Cij2tH/
AJ9/iw5Kn8/4HNL4qtBdyS/Y73ayKo/dDOQW9/cVL/wl9n/z533/AH6H/wAV XQUUe1o/yfiw5Kn8
/wCBz/8Awl9n/wA+d9/36H/xVH/CX2f/AD533/fof/FV0FFHtaP/AD7/ABYc lT+f8Dn/APhL7P8A
5877/v0P/iqP+Evs/wDnzvv+/Q/+KroKKPa0
Re: [FormToolkit] Defining TableWrapData width [message #467442 is a reply to message #467435] Tue, 31 January 2006 10:44 Go to previous messageGo to next message
I played a bit with the FormToolkit. Try to set the SWT.BORDER style on
the composite in which your tree is located.
Composite c = formToolkit.createComposite(parent,SWT.BORDER);
c.setLayout(GridLayout(1,false));
Tree t = formToolkit.createTree(c);
t.setLayoutData(GridData(SWT.FILL,SWT.FILL,true,true));
Or call FormToolkit.paintBorderFor(...) but read the javadoc for margin
issues.
The ManfiestEditor seems to use a TreeViewer. My playground was the view
example with a TreeViewer too. But it should work with a plain Tree.
Ricky
Re: [FormToolkit] Defining TableWrapData width [message #467450 is a reply to message #467442] Tue, 31 January 2006 11:25 Go to previous messageGo to next message
Originally posted by: alexixlebaulois.yahoo.fr
I tried your idea but it didn't work
Re: [FormToolkit] Defining TableWrapData width [message #467454 is a reply to message #467450] Tue, 31 January 2006 11:51 Go to previous message
From the forms article:
Controls like tables, text entries, combo box etc. are rendered with a
flat one-pixel border. These borders do not come from the controls
themselves (SWT.BORDER style is not used). Instead -- if instructed -- the
toolkit will add itself as a paint listener to each control's parent, and
draw borders around controls during paint events. To make this happen, you
need to call the toolkit method paintBordersFor(parent) for each composite
where you created controls like text, tree, table etc. Note that one call
per parent is enough: there is no need to make a call for each control of
this type.
The Form toolkit knows which controls require a custom border. However,
you may create a new one that also needs a border that is not on the list.
You can give a hint to the toolkit by adding the following code:
Control myControl = new MyControl(parent);
myControl.setData(FormToolkit.KEY_DRAW_BORDER, FormToolkit.TEXT_BORDER);
// or myControl.setData(FormToolkit.KEY_DRAW_BORDER,
FormToolkit.TREE_BORDER);
toolkit.paintBordersFor(parent);
As you can see from the picture above, 'structural' controls like trees
and tables have a border style different from text areas and you can
choose which one to render for your control. Note that this is not needed
for controls created using toolkit's factory methods.
SWT.BORDER was a wrong trail but it worked for me nevertheless. As of the
size the tree try to "FILL" every parent container. But as I said I havent
used the FormToolkit much myself so I stop talking now.
Ricky
Previous Topic:Feedback *Greatly* Appreciated
Next Topic:change button's background color
Current Time: Sun Jul 27 16:27:29 EDT 2025
Powered by FUDForum. Page generated in 0.07293 seconds
