Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT+Swing hang application
SWT+Swing hang application [message #467108] Wed, 25 January 2006 05:53 Go to next message
Originally posted by: nicolas._no.spam_legrain.fr
I have a problem using SWT and Swing in an Eclipse RCP application.
We would like to use only swing components in SWT Shell so I create a
method that take a Shell and put a JPanel in.
public void swingInComposite(Shell shell, JPanel swingPanel) {
Composite c = new Composite(shell,SWT.NONE);
FillLayout cLayout = new FillLayout(SWT.HORIZONTAL);
c.setLayout(cLayout);
c.setSize(563, 265);
//Composite
Composite compositeEmbedded = new Composite(c, SWT.EMBEDDED);
FillLayout compositeEmbeddedLayout = new FillLayout(SWT.HORIZONTAL);
compositeEmbedded.setLayout(compositeEmbeddedLayout);
//Frame AWT => heavy weight component to avoid focus problems
Frame frameAWT = SWT_AWT.new_Frame(compositeEmbedded);
compositeEmbedded.setData(frameAWT);
//Panel AWT
Panel panelAWT = new Panel();
BorderLayout panelAWTLayout = new BorderLayout();
panelAWT.setLayout(panelAWTLayout);
frameAWT.add(panelAWT);
//Adding the swing panel
panelAWT.add(swingPanel, BorderLayout.CENTER);
If in a such Shell (shell+jpanel) I open a JOptionPane.showConfirmDialog
(...) on the shellClose event my application hang.
If I open the same JOptionPane.showConfirmDialog(...) on an empty Shell,
that's OK. I can make a choice in the JOptionPane and return to the shell.
I don't understand my problem.
Thanks for your help.
Here is a code snippet :
To test the 2 version (hang and don't hang), comment uncomment the call
to swingInComposite(Shell s, JPanel p) in initAndShowUI().
import java.awt.BorderLayout;
import java.awt.Color;
import java.awt.Frame;
import java.awt.Panel;
import javax.swing.JOptionPane;
import javax.swing.JPanel;
import javax.swing.JTextField;
import org.eclipse.swt.SWT;
import org.eclipse.swt.awt.SWT_AWT;
import org.eclipse.swt.events.ShellAdapter;
import org.eclipse.swt.events.ShellEvent;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class TestShellEvent {
public Shell shell;
public AbstractController controller;
public TestShellEvent() {}
org.eclipse.swt.widgets.Display display = org.eclipse.swt.widgets.Display
.getDefault();
TestShellEvent test = new TestShellEvent();
test.initAndShowUI();
while (!test.shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
public void initAndShowUI() {
shell = new Shell();
shell.setSize(600, 600);
shell.setText("Test");
this.controller = new Controller();
shell.addShellListener(new MyShellAdapter());
//comment this for the version that don't hang (empty shell)
swingInComposite(shell,new SampleSwingPanel());
shell.setLayout(new FillLayout());
shell.layout();
shell.setVisible(true);
* Embed a JPanel into an SWT Shell
* @param shell
* @param swingPanel
//Composite
//Panel AWT
class MyShellAdapter extends ShellAdapter {
public void shellClosed(ShellEvent e) {
//super.shellClosed(e);
try {
e.doit = controller.onClose();
} catch (Exception ex) {
ex.printStackTrace();
class SampleSwingPanel extends JPanel{
public SampleSwingPanel() {
this.setLayout(new BorderLayout());
this.add(new JTextField("test"), BorderLayout.NORTH);
abstract class AbstractController {
abstract public boolean onClose() throws Exception;
class Controller extends AbstractController {
public boolean onClose() throws Exception {
if(JOptionPane.showConfirmDialog(null,
"Quit without saving ?",
"Attention", JOptionPane.YES_NO_OPTION,
JOptionPane.QUESTION_MESSAGE)==JOptionPane.YES_OPTION)
return true;
else
return false;
I think my "swingInComposite()" method also cause some focus problems
between Swing and SWT.
Re: SWT+Swing hang application [message #467115 is a reply to message #467108] Wed, 25 January 2006 06:34 Go to previous messageGo to next message
The application seems to hang only with this in the "swingInComposite" method :
Composite compositeEmbedded = new Composite(shell, SWT.EMBEDDED);
nm a écrit :
> //Composite
> //Panel AWT
> public Shell shell;
> public static void main(String[] args) {
> .getDefault();
> display.sleep();
> display.dispose();
> shell.layout();
> * @param shell
> * @param swingPanel
> //Composite
> //Panel AWT
> try {
> return true;
> else
> return false;
Re: SWT+Swing hang application [message #467121 is a reply to message #467108] Wed, 25 January 2006 10:54 Go to previous messageGo to next message
do you try add AWT frame like Snippet135
nm wrote:
> //Composite
> //Panel AWT
> public Shell shell;
> .getDefault();
> display.sleep();
> display.dispose();
> shell.layout();
> * @param shell
> * @param swingPanel
> //Composite
> //Panel AWT
> try {
> return true;
> else
> return false;
Re: SWT+Swing hang application [message #467133 is a reply to message #467121] Wed, 25 January 2006 11:38 Go to previous messageGo to next message
Thanks for your answer.
After looking the snippet 135, I haven't seen major difference between this code
and my code. They use SWT_AWT.new_Frame() to obtain a Frame then directly add
AWT component or add a Panel before if they want to add a Swing component.
If in "swingInComposite()" there is only
Frame frameAWT = SWT_AWT.new_Frame(shell);
the application hangs when I open the JOptionPane (in the shellClosed event).
I've tried with other JDialog and the application only hangs if the JDialog
is modal (like the JOptionPane).
I think it is a threading issue.
> nm wrote:
>> Hi,
>> //Composite
>> //Panel AWT
>> public Shell shell;
>> .getDefault();
>> display.sleep();
>> display.dispose();
>> shell.layout();
>> * @param shell
>> * @param swingPanel
>> //Composite
>> //Panel AWT
>> try {
>> return true;
>> else
>> return false;
Re: SWT+Swing hang application [message #467139 is a reply to message #467133] Wed, 25 January 2006 13:34 Go to previous messageGo to next message
what mean 'application hang'
you have NPE or what ?
> this code and my code. They use SWT_AWT.new_Frame() to obtain a Frame then
> directly add AWT component or add a Panel before if they want to add a
> Swing component. If in "swingInComposite()" there is only
> event). I've tried with other JDialog and the application only hangs if
> the JDialog is modal (like the JOptionPane).
>> nm wrote:
>>> Hi,
>>> //Composite
>>> //Panel AWT
>>> shell. I don't understand my problem.
>>> public Shell shell;
>>> org.eclipse.swt.widgets.Display .getDefault();
>>> display.sleep();
>>> display.dispose();
>>> shell.layout();
>>> * @param shell
>>> * @param swingPanel
>>> //Composite
>>> //Panel AWT
>>> try {
>>> return true;
>>> else
>>> return false;
Re: SWT+Swing hang application [message #467143 is a reply to message #467139] Wed, 25 January 2006 13:05 Go to previous messageGo to next message
The GUI freeze and there is no error in the console.
I only can move the windows of my application (very slowly) and reduce/retorre
them on the task bar.
After the problem, the only way to close the program is Ctrl+Alt+Suppr
>>> nm wrote:
>>>> Hi,
>>>> //Composite
>>>> //Panel AWT
>>>> public Shell shell;
>>>> display.sleep();
>>>> display.dispose();
>>>> shell.layout();
>>>> * @param shell
>>>> * @param swingPanel
>>>> //Composite
>>>> //Panel AWT
>>>> try {
>>>> return true;
>>>> else
>>>> return false;
Re: SWT+Swing hang application [message #467147 is a reply to message #467133] Wed, 25 January 2006 13:50 Go to previous messageGo to next message
That makes some sense. There are two threads running, one is the main
SWT display thread, and then the other thread is the AWT's display
thread. When you open a modal Swing dialog from the Shell close event,
you are blocking the SWT's display thread because the modal open happens
on the SWT's thread. But the dialog is processed on the AWT's display
thread. Since the dialog doesn't return until it is closed the SWT
thread cannot process any events and so it locks up.
Rich Kulp
Re: SWT+Swing hang application [message #467159 is a reply to message #467147] Wed, 25 January 2006 17:22 Go to previous messageGo to next message
and what is solution - change swing with swt dialog or call dialog with
async ?
Re: SWT+Swing hang application [message #467163 is a reply to message #467159] Wed, 25 January 2006 17:12 Go to previous messageGo to next message
You would do:
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
do your JOptions dialog
process returned result;
Note that this means that the SWT shell's close event will continue
processing and the shell will close before the JOptions dialog comes up.
You won't be able to stop it from closing. You can't stop the SWT
display queue to wait for the JOptions dialog.
If you absolutely must do that, then there is a trick. You just run the
SWT display thread yourself. (I think this will work).
final Display display = Display.getCurrent();
final boolean[] runLoopAndContinue =
new boolean[] {true, true};
public void run() {
runLoopAndContinue[1] =
JOptionPane.QUESTION_MESSAGE)==JOptionPane.YES_OPTION);
// Do syncExec so that display queue is emptied and entry
// [0] changed on SWT UI thread.
display.syncExec(new Runnable() {
public run() {
runLoopAndContinue[0] = false; // Tell onClose to stop
looping.
display.asyncExec(null); // Wake SWT UI thread up one more
time to make sure it terminates.
while(runLoopAndContinue[0]) {
try {
display.sleep();
} catch (Throwable e) {
// process exception if you like.
return runLoopAndContinue[1];
Rich Kulp
Re: SWT+Swing hang application [message #467200 is a reply to message #467163] Thu, 26 January 2006 05:13 Go to previous message
Thank you for the informations, your trick is working.
I will try with it.
Rich Kulp a écrit :
> You would do:
> public void run() {
> public void run() {
> public run() {
> stop looping.
> try {
> display.sleep();
Previous Topic:ImageLoader save()
Next Topic:Frame being painted several times during resize
Current Time: Sat Jul 26 20:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.05111 seconds
