Home » Eclipse Projects » Rich Client Platform (RCP) » Job progress monitoring, and results in separate thread (outside the Job)
Job progress monitoring, and results in separate thread (outside the Job) [message #466756] |
Tue, 24 April 2007 11:12  |
Hi all,
Got a tricky little problem here using the Job framework and reporting progress. I have an operation that could take some time, however the work for this job is not performed by the RCP application itself - it is performed by a process on a server and the progress is reported back to the RCP application.
I currently have code that looks a bit like this:
Job job = new Job("Publishing") {
protected IStatus run(IProgressMonitor monitor) {
progressMonitor = monitor;
setProperty(IProgressConstants.KEEP_PROPERTY, Boolean.TRUE);
setProperty(IProgressConstants.ACTION_PROPERTY, getPublishingCompletedAction());
monitor.beginTask("Publishing", 100);
monitor.worked(1);
monitor.subTask("Initialising...");
setUploading(true);
processMessage(1, "Beginning Publishing process...", 0, 5);
System.out.println("PUBLISHING: Marker 1");
new Thread() {
public void run() {
try {
System.out.println("PUBLISHING: Marker 2");
// Code to start the publish on the server
System.out.println("PUBLISHING: Marker 3");
} catch (Exception e) {
e.printStackTrace();
start(); // static initialiser
System.out.println("PUBLISHING: Marker 4");
// Code to create a listener in a new thread to monitor progress
System.out.println("PUBLISHING: Marker 5");
return Status.OK_STATUS;
job.setUser(true);
job.schedule();
However, when the user clicks the button to start this action and create this job, the publishing process in our server application is started, but the job seems to end before any progress has come back, and therefore the Job progress dialog never gets updated.
I can see that the 'return Status.OK_STATUS' is being called and this seems to be ending the job. I am updating 'progressMonitor' from the listener thread but, of course, the progress monitor isn't around by the time any progress comes back that triggers the listener.
Is there a way to set this job running indefinitely (i.e. not calling 'return Status.OK_STATUS' to end the job) until the server process returns the final message that the publish has finished (at which point I can then end the Job).
Any help would be greatly appreciated. Thanks all!
Re: Job progress monitoring, and results in separate thread (outside the Job) [message #467184 is a reply to message #466756] |
Mon, 30 April 2007 09:31   |
...its funny how some threads in this forum get loads of hits and replies, and some none at all. I would have thought this was quite a common problem that developers must have come across. Obviously not!
In case someone in the future does happen to come across this and is in a similar situation, I ended up solving this is a rather hacky, but ultimately pragmatic way.
In the Job:
monitor.worked(1);
new Thread() {
public void run() {
try {
// Set the publishing flag to true. This flag will be set to false elsewhere by the thread handling incoming messages.
isPublishing = true;
while (isUploading) {
try {
Thread.sleep(2000);
job.setUser(true);
job.schedule();
Re: Job progress monitoring, and results in separate thread (outside the Job) [message #467188 is a reply to message #467184] |
Mon, 30 April 2007 10:04   |
Hi Craig,
Also, you might use WorkspaceJob and JobChangeAdapter.
Charlie
> In the Job:
> monitor.worked(1);
> new Thread() {
> public void run() {
> try {
> try {
> Thread.sleep(2000);
> job.setUser(true);
> job.schedule();
Re: Job progress monitoring, and results in separate thread (outside the Job) [message #467201 is a reply to message #466756] |
Mon, 30 April 2007 15:54  |
Originally posted by: lamont_gilbert.rigidsoftware.com
On Tue, 24 Apr 2007 11:12:36 -0400, Craig Pugsley wrote:
> Hi all,
Why are you starting the publishing inside that Thread? Thats what the
Job is for. Its redundant and that is why its masking the progress.
Current Time: Sun Jun 01 16:25:00 EDT 2025
Powered by FUDForum. Page generated in 0.03984 seconds
