Home » Newcomers » Newcomers » Eclipse 3.5 segmentation fault on startup
Eclipse 3.5 segmentation fault on startup [message #444870] Fri, 31 July 2009 14:32 Go to next message
Originally posted by: johnson.hawaii.edu
Greetings, all,
I installed Eclipse 3.5 (cocoa 64 bit) a week or so ago, and yesterday it
began getting a seg fault on startup. I just downloaded the 32 bit version
and it gets the same error. Indeed, my old 3.4 installation now gets the
same error: no eclipse runs anymore! So, it appears to be a problem with
my environment. Here is the log output from running 'eclipse -debug'.
Install location:
file:/Users/johnson/Desktop/eclipse-SDK-3.5-macosx-cocoa/
Configuration file:
file:/Users/johnson/Desktop/eclipse-SDK-3.5-macosx-cocoa/con figuration/config.ini
loaded
Configuration location:
Framework located:
file:/Users/johnson/Desktop/eclipse-SDK-3.5-macosx-cocoa/plu gins/org.eclipse.osgi_3.5.0.v20090520.jar
Framework classpath:
Splash location:
/Users/johnson/Desktop/eclipse-SDK-3.5-macosx-cocoa/plugins/ org.eclipse.platform_3.3.200.v200906111540/splash.bmp
Debug options:
file:/Users/johnson/Desktop/eclipse-SDK-3.5-macosx-cocoa/Ecl ipse.app/Contents/MacOS/.options
not found
Time to load bundles: 38
Starting application: 2066
Invalid memory access of location c005af87 eip=9077c688
Does anyone have any ideas on how to debug this?
Philip
Re: Eclipse 3.5 segmentation fault on startup [message #462653 is a reply to message #444870] Sun, 02 August 2009 10:58 Go to previous messageGo to next message
"Philip Johnson" <johnson@hawaii.edu> wrote in message
news:4f5850be96f52a1623c21d3c4c3b5b79$1@www.eclipse.org...
> Greetings, all,
What JVM are you using? Is it possible that you recently got a JVM update?
Re: Eclipse 3.5 segmentation fault on startup [message #466544 is a reply to message #444870] Sun, 02 August 2009 21:04 Go to previous messageGo to next message
What flavor of Linux are you running?
What's your JVM?
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Eclipse 3.5 segmentation fault on startup [message #468039 is a reply to message #462653] Mon, 03 August 2009 13:48 Go to previous message
>> Greetings, all,
Perhaps Philip recently got the OS X 10.5.7 update and that screwed with
the OS-controlled Java...
Philip, try opening the Java Preferences app and see if changing the
default Java version for your system makes any difference.
Hope this helps,
Eric
Previous Topic:JOGL in eclipse
Next Topic:viewing strings
Current Time: Sun Nov 09 16:39:02 EST 2025
Powered by FUDForum. Page generated in 0.08981 seconds
