Home » Eclipse Projects » Rich Client Platform (RCP) » Calling Editor
Calling Editor [message #466542] Fri, 20 April 2007 10:30 Go to next message
Originally posted by: awais.shibli.niit.edu.pk
hi
can any body tell me how to call an editor behind workbench menu action
Shibli
Re: Calling Editor [message #466550 is a reply to message #466542] Fri, 20 April 2007 15:21 Go to previous messageGo to next message
Awais Shibli wrote:
> hi
> Regards
> Shibli
I assume you are talking about manually opening an editor in the
workbench, if that is the case take a look at
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor(input,
editorId) where input is an instance of IEditorInput and editorId is the
id of the editor that is defined in the org.eclipse.ui.editors extension
point, hope that helps. - Duncan
Re: Calling Editor [message #466571 is a reply to message #466550] Sat, 21 April 2007 00:00 Go to previous messageGo to next message
thanks Duncan
this is what i have required. kindly can you also tell me how can i get
input parameter.
Shibli
"Duncan Krebs" <dkrebs@tibco.com> wrote in message
news:4248b68975a20e694e1f636e30563c41$1@www.eclipse.org...
> Awais Shibli wrote:
>> hi
>> Regards
>> Shibli
Re: Calling Editor [message #466605 is a reply to message #466571] Sun, 22 April 2007 14:17 Go to previous messageGo to next message
If you are going to open your editor for a IFile, the input can be created with: new FileInputEditor(someFile)
Re: Calling Editor [message #467114 is a reply to message #466605] Fri, 27 April 2007 15:36 Go to previous message
yup you are right i got the solution thanks
"Prakash" <grprakash@gmail.com> wrote in message
news:15365095.1177265853855.JavaMail.root@cp1.javalobby.org...
Previous Topic:Perspective Resize
Next Topic:eclipse language packs
Current Time: Sun Jun 08 16:46:22 EDT 2025
Powered by FUDForum. Page generated in 0.02893 seconds
