Home » Eclipse Projects » Standard Widget Toolkit (SWT) » No labels
No labels [message #466296] Thu, 05 January 2006 20:13 Go to next message
There is no text on Labels and Buttons using swt-win32-3139.dll in the
directory C:\x86 when I run in stand-alone mode as in the ant script
below. This runs Snippet108 to display a very simple form. That code is
below as well. An interesting note is that if I leave the application
running, something triggers a re-draw and the text gets displayed.
<path id="my.class.path">
<pathelement path="build"/>
<pathelement
location="C:/x86/org.eclipse.swt.win32.win32.x86_3.1.1.jar"/ >
</path>
<target name="x" depends="compile"
description="run the application" >
<java dir="build"
fork="true"
classname="org.eclipse.swt.snippets.Snippet108" >
<jvmarg value="-Djava.library.path=C:\x86"/>
<classpath refid="my.class.path">
</classpath>
</java>
</target>
SNIPPET..............
* Copyright (c) 2000, 2004 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* IBM Corporation - initial API and implementation
package org.eclipse.swt.snippets;
* Label example snippet: create a label (a separator)
* For a list of all SWT example snippets see
* http://www.eclipse.org/swt/snippets/
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.RowData;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class Snippet108 {
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
Label label = new Label (shell, SWT.NONE);
label.setText ("Enter your name:");
Text text = new Text (shell, SWT.BORDER);
text.setLayoutData (new RowData (100, SWT.DEFAULT));
Button ok = new Button (shell, SWT.PUSH);
ok.setText ("OK");
ok.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
System.out.println("OK");
Button cancel = new Button (shell, SWT.PUSH);
cancel.setText ("Cancel");
cancel.addSelectionListener(new SelectionAdapter() {
System.out.println("Cancel");
shell.setDefaultButton (cancel);
shell.setLayout (new RowLayout ());
shell.pack ();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: No labels [message #466345 is a reply to message #466296] Fri, 06 January 2006 15:29 Go to previous messageGo to next message
People have reported an issue like this when running with java.exe which
gets fixed by running with javaw.exe. I have never seen this problem myself
and I run with both regularly.
What VM are you using? Can you try a different one?
"Geoffrey Ritchey" <geoffritchey@hotmail.com> wrote in message
news:4b03be892b5c2279a8c742af972d247b$1@www.eclipse.org...
> <pathelement location="C:/x86/org.eclipse.swt.win32.win32.x86_3.1.1.jar"/ >
> </path>
> <java dir="build"
> fork="true"
> <jvmarg value="-Djava.library.path=C:\x86"/> <classpath
> </classpath>
> </java> </target>
> * Contributors:
> import org.eclipse.swt.widgets.Display;
> ok.setText ("OK");
> shell.pack ();
> shell.open ();
> display.dispose ();
Re: No labels [message #466369 is a reply to message #466345] Mon, 09 January 2006 12:25 Go to previous messageGo to next message
Here is the command I run and get no Text on labels and buttons:
"C:\Program Files\Java\jre1.5.0_06\bin\javaw.exe"
If I change javaw to java I get the text again.
Here is the version information:
java version "1.5.0_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
Java HotSpot(TM) Client VM (build 1.5.0_06-b05, mixed mode, sharing)
Re: No labels [message #466446 is a reply to message #466369] Tue, 10 January 2006 10:47 Go to previous messageGo to next message
In my previous post I said I changed javaw to java and it worked, but
actually it was the reverse. I changed java to javaw. One thing that
this implies is that I can't use the java 'ant task' to test. I probably
have to set up and ant task to spawn javaw instead.
This seems like a serious problem to me even if there is an easy fix. Is
there any work being done to find out what's happening here? Is there an
open bug report?
Re: No labels [message #466494 is a reply to message #466446] Tue, 10 January 2006 13:32 Go to previous message
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=91019
news:95e67562bd4064239a49b38ff0febc84$1@www.eclipse.org...
> open bug report?
Previous Topic:PDF Problem with SWT Browser on Linux/GTK SWT 3.1.1 w/ Mozilla
Next Topic:Table Cell Colors
Current Time: Wed Sep 17 04:21:58 EDT 2025
Powered by FUDForum. Page generated in 0.40341 seconds
