Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Java SWT Minimized-Shell RAM Usage
Java SWT Minimized-Shell RAM Usage [message #466373] Mon, 09 January 2006 14:20 Go to next message
Originally posted by: j-hannemann.arcor.de
Hello there ...
I hope someone can help me please ?
I am trying to start a Java SWT Shell minimized as described :
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet27.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup
(or http://www.eclipse.org/swt/snippets/ -> Shell -> open a shell
minimized (iconified))
It works fine but when I look to the Task Manager of my Windows XP SP2 it
shows (depends on my Program, I know) about 20 MB of RAM used, although
its minimized.
Interesting is now that if I restore the Shell (setMinimizeed(false)) and
then minimize it again using the Windows default minimize-Button it only
takes about 1 MB RAM in the Task Manager !!!!
Nothing changing, just restore and minimize again decreased my RAM usage
from
20 MB to 1 MB !!!
Why ?? Can I REALLY minimize it just on a first attempt (to 1 MB usage) ?
I've tried to call System.gc() but this brings it only to 18,9 MB :(
I've got the usual Sun Java SDK 1.5.0_06 and SWT 3.2.3218
Please help me - I didn't find anything in the web for this issue !
Re: Java SWT Minimized-Shell RAM Usage [message #466378 is a reply to message #466373] Mon, 09 January 2006 15:52 Go to previous messageGo to next message
It's not really important to have it smaller in this case. 20Meg is not
much these days. If it is minimized and not in use, Windows will swap it
out to disk for you automatically when it needs the space. If it doesn't
need the physical memory then there is no need to swap it out. It
doesn't really cause any problems to have memory allocated and no
programs actively using it or needing the physical memory it is using.
What is important with memory is the working set (i.e. how much is
needed in an active manner to do anything). You could have megs more
that are not actively being used and this doesn't cause any problems
until it is needed, because then it needs to be swapped in.
Actually windows does a drastic swap to disk when a minimize occurs (as
you already noted). It is not actually reducing its memory usage, only
reducing the physical memory usage. The virtual memory is still the same.
Probably Windows only does the massive swap on an explicit minimize. It
probably doesn't see it when it is created as minimized.
Rich Kulp
Re: Java SWT Minimized-Shell RAM Usage [message #466380 is a reply to message #466373] Mon, 09 January 2006 17:05 Go to previous messageGo to next message
> from
> 20 MB to 1 MB !!!
windows's joke
Re: Java SWT Minimized-Shell RAM Usage [message #466795 is a reply to message #466373] Tue, 17 January 2006 14:01 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=85072
"Joerg Hannemann" <j-hannemann@arcor.de> wrote in message
news:49a273afc1b1969f7b22865c663b97c5$1@www.eclipse.org...
> Hello there ...
> its minimized.
> from
> 20 MB to 1 MB !!!
Previous Topic:SWT table flickering
Next Topic:Get table data from SWT app to EXCEL
Current Time: Fri Jul 25 22:45:43 EDT 2025
Powered by FUDForum. Page generated in 0.09621 seconds
