Home » Eclipse Projects » Standard Widget Toolkit (SWT) » swt error opening a dialog
swt error opening a dialog [message #466353] Sun, 08 January 2006 04:00 Go to next message
Originally posted by: marguu.libero.it
Opening a dialog in order to let the user insert his own values for an
element, I obtain this error:
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at
genericUMLDiagramEditor.dialogs.ContainerPropertiesInputDial og.open(ContainerPropertiesInputDialog.java:125)
I use this code in the open method:
public String open() {
// Create the dialog window
Shell shell = new Shell(getParent(), getStyle());
shell.setText(getText());
createContents(shell);
shell.setSize(400,370);
shell.setLocation(200,200);
shell.open();
Display display = getParent().getDisplay();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
// Return the entered value, or null
return input1;
I don't understand where is the problem; I use this structure in other
classes in my project and all work fine. Thanks
Re: swt error opening a dialog [message #466355 is a reply to message #466353] Sun, 08 January 2006 09:58 Go to previous messageGo to next message
you try open dialog in non-ui thread (probably) - your display
is null - try with Display.getDefault().syncExec(...)
or in rcp PlatformUI.getWorkbench().getDisplay().sync(...)
> at
> at
> shell.open();
> display.sleep();
> return input1;
Re: swt error opening a dialog [message #466376 is a reply to message #466355] Mon, 09 January 2006 15:42 Go to previous messageGo to next message
but I don't lunch a sync (or async) runnable, symply opern the dialog (and
all my variable aren't null)
0:-(
Re: swt error opening a dialog [message #466379 is a reply to message #466376] Mon, 09 January 2006 16:59 Go to previous messageGo to next message
it is problem (probably, debug that see null variable) - you have to force
ui thread with sync/async
> 0:-(
Re: swt error opening a dialog [message #466502 is a reply to message #466353] Tue, 10 January 2006 13:40 Go to previous message
The NullPointerException is being thrown by the Runnable.run() passed into
Display.asyncExec().
There should be a second error message showing the actual cause of the
NullPointerException . If not, setup debug to break on the
NullPointerException and you will see the real cause.
"marguu" <marguu@libero.it> wrote in message
news:fed32673fd40bfb0110fc6ebf7273aa7$1@www.eclipse.org...
> at
> at
> shell.open();
> display.sleep();
> return input1;
Previous Topic:Table Cell Colors
Next Topic:SWT.EMBEDDED style
Current Time: Fri Nov 07 20:21:57 EST 2025
Powered by FUDForum. Page generated in 0.07017 seconds
