Home » Eclipse Projects » Standard Widget Toolkit (SWT) » adding content to a table if user scrolls down
adding content to a table if user scrolls down [message #466191] Wed, 04 January 2006 13:53 Go to next message
Originally posted by: ingo.siebertNOSPAM.cas.de
Hi!
Question:
I load 100 rows from the DB and add them to the table.
If the vertical ScrollBar of table has a value of
(scrollBar.getMaximum() / 3)
i want to load the next 100 rows and add them to the table.
It got that working.
But i tested it at a very big monitor and the 100 rows has been place
nearly complete at the table, so the value of the scrollbar never
reached (scrollBar.getMaximum() / 3). That's why the next 100 rows never
got loaded.
In Swing, i used the
getValueAt(int rowIndex, int colIndex)
method of my table model. If rowIndex was big enough, i loaded the next
100 rows.
But in SWT, there isn't such a method. The label provider only gets the
data and the column index, but not the row.
Any idea how to solve this problem in SWT?
Ingo
Re: adding content to a table if user scrolls down [message #466206 is a reply to message #466191] Wed, 04 January 2006 15:10 Go to previous messageGo to next message
Use the SWT.VIRTUAL style. It should get you pretty close to what you want.
http://publicobject.com/glazedlists/documentation/swt_virtua l_tables.html
Re: adding content to a table if user scrolls down [message #466265 is a reply to message #466206] Thu, 05 January 2006 11:05 Go to previous messageGo to next message
It works awesome!
Thank you,
Ingo
Re: adding content to a table if user scrolls down [message #466269 is a reply to message #466191] Thu, 05 January 2006 11:17 Go to previous message
See:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet201.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
"Ingo Siebert" <ingo.siebertNOSPAM@cas.de> wrote in message
news:dph5m7$q0s$1@utils.eclipse.org...
> Hi!
> Question:
> nearly complete at the table, so the value of the scrollbar never reached
> (scrollBar.getMaximum() / 3). That's why the next 100 rows never got
> loaded.
> 100 rows.
> Ingo
Previous Topic:max value
Next Topic:Table Cell Colors For two Different Tables
Current Time: Fri Jul 25 22:13:42 EDT 2025
Powered by FUDForum. Page generated in 0.28105 seconds
