Home » Eclipse Projects » Standard Widget Toolkit (SWT) » UI Thread question
UI Thread question [message #466185] Wed, 04 January 2006 13:19 Go to next message
I have an application that does database lookup and might take some time
to process the request. I tried to put the call to the database in a
thread, but screen still locks up. What am I doing wrong?
buttonOK.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event event) {
Display _display = Display.getCurrent();
_display.asyncExec (new Runnable () {
public void run () {
sRun = sRun.buildGUI(value,
clientName.toLowerCase());
if(sRun.isDataExists()){
shell.dispose();
And couple of questions:
1. What is the difference between asyncExec and syncExec
2. Good tutorial on SWT Threading.
thanks,
Alex
Re: UI Thread question [message #466187 is a reply to message #466185] Wed, 04 January 2006 13:28 Go to previous messageGo to next message
Originally posted by: ingo.siebertNOSPAM.cas.de
i'm trying to help but i'm also a beginner.
Both sync and async work on the UI thread.
Sync halts the execution on the current thread and asynch doens't halt
the current thread.
For a new thread, use the normal Java classes. If you need to call
methods from the UI thread, than choose sync or async.
Ingo
Aleksandr Kravets schrieb:
> shell.dispose();
> thanks,
> Alex
Re: UI Thread question [message #466220 is a reply to message #466187] Wed, 04 January 2006 19:02 Go to previous messageGo to next message
It's exactly as Ingo described:
asyncExec still makes your code run in the UI thread - and so during the
time it takes to execute it, your UI will be blocked.
As a rule of thumb, never do someting expensive in UI thread or in
async/syncExec. The better way is to write a real thread and update the
UI via async/syncExec.
About Threading:
Check out the Job API that eclipse provides (google will help you).
For standard Java threads, check out the Thread class.
Lorenz
Ingo Siebert wrote:
> the current thread.
> Ingo
>> Hi,
>> time to process the request. I tried to put the call to the database
>> in a thread, but screen still locks up. What am I doing wrong?
>> shell.dispose();
>> thanks,
>> Alex
Re: UI Thread question [message #466231 is a reply to message #466185] Thu, 05 January 2006 01:35 Go to previous messageGo to next message
As others pointed out runnables passed to syncExec and asyncExec are
executed on the UI thread. The main purpose for these methods is to update
the UI from a non-UI thread in synchronous (blocking) or asynchronous
(non-blocking) mode as any attempt to update the UI from a non-UI thread
will result in an exception.
The simplistic approach to unblock the UI is to launch a new thread in your
event handler and when the necessary data is fetched/constructed you update
the UI with it in a runnable passed to syncExec or asyncExec. You typically
have to make sure that no new background threads are created if there is one
already running.
I'd suggest to look into the jobs API which provides convenient mechanisms
for managing complexities typically found in multi-threaded applications.
--Vladimir.
"Aleksandr Kravets" <akravets@klgerweiss.com> wrote in message
news:dph3l8$moi$1@utils.eclipse.org...
> shell.dispose();
> thanks,
> Alex
Re: UI Thread question [message #466254 is a reply to message #466231] Thu, 05 January 2006 09:28 Go to previous messageGo to next message
Thanks guys,
I played with these two methods in my code and see the difference
between the two.
Thanks for explanation!
> already running.
> --Vladimir.
>>Hi,
>> shell.dispose();
>>thanks,
>>Alex
Re: UI Thread question [message #466258 is a reply to message #466185] Thu, 05 January 2006 09:31 Go to previous message
See:
http://www.eclipse.org/swt/faq.php#uithread
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet7.java?rev=HEAD&am p;content-type=text/vnd.viewcvs-markup
> shell.dispose();
> thanks,
> Alex
Previous Topic:How to combine different images to one image?
Next Topic:Adding an Action to the Navigator View
Current Time: Thu Jul 24 21:49:09 EDT 2025
Powered by FUDForum. Page generated in 0.28219 seconds
