Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT table flickering
SWT table flickering [message #466150] Tue, 03 January 2006 16:26 Go to next message
I have an application using SWT tables. There is a substantial
flickering going on when I have lot's of data. Searching on this I
found:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet154.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
which suggests using JTable in SWT to reduce flickering. But this means
I can't use TableViewer and other good stuff (?) if I use JTable. And,
why does flickering happen in SWT and not in Swing (I did not try this yet).
thanks,
Alex
Re: SWT table flickering [message #466151 is a reply to message #466150] Tue, 03 January 2006 16:35 Go to previous messageGo to next message
The snippet you have referenced shows how to stop flickering in an embedded
JTable using
System.setProperty("sun.awt.noerasebackground","true"). It is not meant to
suggest that this is the only way to have a table that does not flicker.
Please give more information about how many items you have in the table and
how you have created the table. When does the flicker occur? Does the
following example with a one million items flicker for you?
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet144.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
"Aleksandr Kravets" <akravets@klgerweiss.com> wrote in message
news:dpeq6q$rs5$1@utils.eclipse.org...
> I have an application using SWT tables. There is a substantial flickering
> going on when I have lot's of data. Searching on this I found:
> which suggests using JTable in SWT to reduce flickering. But this means I
> can't use TableViewer and other good stuff (?) if I use JTable. And, why
> thanks,
> Alex
Re: SWT table flickering [message #466152 is a reply to message #466151] Tue, 03 January 2006 17:08 Go to previous messageGo to next message
This is my code:
private void layoutData(Vector data,String sql) {
Label resultLabel = new Label(this, SWT.LEFT | SWT.BORDER);
table = new Table(this, SWT.BORDER | SWT.MULTI | SWT.FULL_SELECTION
| SWT.VIRTUAL);
final GridData gd = new GridData(GridData.FILL_BOTH);
gd.horizontalSpan = 2;
table.setLayoutData(gd);
table.setHeaderVisible(true);
table.setLinesVisible(true);
table.setItemCount(data.size());
table.addListener(SWT.SetData, new CallbackListener());
setLayout(new GridLayout(2,false));
GridData resultData = new GridData(GridData.FILL_BOTH);
resultData.horizontalSpan = 2;
resultData.verticalSpan = 1;
table.setLayoutData(resultData);
//table.setLayoutData (new RowData (200, 200));
GridData labelData = new GridData(GridData.FILL_HORIZONTAL);
resultLabel.setLayoutData(labelData);
RGB color = new RGB(255,204,51);
resultLabel.setBackground(new Color(getDisplay(),color));
FontRegistry fontRegistry = new FontRegistry(getDisplay());
fontRegistry.put("code", new FontData[]{new FontData("System",
7, SWT.BOLD)});
resultLabel.setFont(fontRegistry.get("code"));
resultLabel.setText(sql);
String columnNames[] = (String[])data.elementAt(0);
for(int cols = 0; cols < columnNames.length; cols++){
TableColumn column = new TableColumn(table,SWT.NONE);
column.setText(columnNames[cols]);
column.setWidth(200);
class CallbackListener implements Listener {
public void handleEvent(Event event) {
TableItem item = (TableItem)event.item;
int tableIndex = table.indexOf(item);
item.setText((String[])data.elementAt(tableIndex));
item.setBackground(tableIndex % 2 == 0 ?
getDisplay().getSystemColor(SWT.COLOR_WHITE) :
getDisplay().getSystemColor(SWT.COLOR_WIDGET_LIGHT_SHADOW));
My data contains 61,675 and 20 columns. When I select only one column,
there is some flickering. However, with 20, I get a lot flickering when
using scroller to scroll the table.
thanks,
Alex
> JTable using
>>Hi,
>>thanks,
>>Alex
Re: SWT table flickering [message #466153 is a reply to message #466152] Tue, 03 January 2006 17:11 Go to previous messageGo to next message
Also,
In Snippet144 there is some white flickering present when using the
vertical srollbar, same thing I have when scrolling table with one column.
Alex
Aleksandr Kravets wrote:
> This is my code:
> SWT.FULL_SELECTION | SWT.VIRTUAL);
> 7, SWT.BOLD)});
> thanks,
> Alex
>> embedded JTable using
>> meant to suggest that this is the only way to have a table that does
>> not flicker.
>> table and how you have created the table. When does the flicker
>> occur? Does the following example with a one million items flicker
>> for you?
>>> Hi,
>>> found:
>>> means I can't use TableViewer and other good stuff (?) if I use
>>> JTable. And, why does flickering happen in SWT and not in Swing (I
>>> thanks,
>>> Alex
Re: SWT table flickering [message #466793 is a reply to message #466153] Tue, 17 January 2006 13:17 Go to previous message
I you run with the Windows XP manifest file, the flickering in Snippet144
goes away (we worked around it on XP). Otherwise, the flickering that you
see is just the operating system drawing the table as you scroll. You can
see this on Windows 2000 in the Explorer when scrolling.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=116776
news:dpesra$vqm$2@utils.eclipse.org...
> Also,
> Alex
> > This is my code:
> > 7, SWT.BOLD)});
> > thanks,
> > Alex
> >> not flicker.
> >> for you?
> >>> Hi,
> >>> found:
> >>> thanks,
> >>> Alex
Previous Topic:Retrieve minsize for use in ScrolledComposite
Next Topic:Java SWT Minimized-Shell RAM Usage
Current Time: Fri Sep 19 10:01:35 EDT 2025
Powered by FUDForum. Page generated in 0.10011 seconds
