Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TreeViewer inline editing
TreeViewer inline editing [message #460859] Thu, 08 September 2005 23:51 Go to next message
Originally posted by: osipov.appliedtech.ru
Is there a possibility to inline edit the names of nodes in a tree swt
widget using TreeViewer?
thanks a lot in advance for your reply.
Re: TreeViewer inline editing [message #460861 is a reply to message #460859] Thu, 08 September 2005 23:54 Go to previous messageGo to next message
I mean there is such a possibility for TableViewers using TableEditor, but
for TreeViewer I could find nothing.
Re: TreeViewer inline editing [message #460959 is a reply to message #460861] Tue, 13 September 2005 04:59 Go to previous messageGo to next message
guys, could anybody give me an answer, eh?
Re: TreeViewer inline editing [message #460979 is a reply to message #460959] Tue, 13 September 2005 14:27 Go to previous messageGo to next message
Originally posted by: mehow.remove.neurosoft.net
I used TreeViewer.setCellEditors() and TreeViewer.setCellModifier() for
this purpose. I did it once though, so I'm not an expert.
Hope this helps.
Michal
Re: TreeViewer inline editing [message #460995 is a reply to message #460979] Wed, 14 September 2005 00:06 Go to previous messageGo to next message
yep, it should help. thanks a lot indeed! did it work for your tree?
Re: TreeViewer inline editing [message #460997 is a reply to message #460995] Wed, 14 September 2005 04:31 Go to previous messageGo to next message
Yes, the only think I didn't like about it was that the TextCellEditor
was taking the whole width of a tree, while I wanted it to look like in
Navigator view when e.g. you change the name of a project. But I guess
the mechanism used there is completely different.
Michal
Re: TreeViewer inline editing [message #460999 is a reply to message #460997] Wed, 14 September 2005 05:52 Go to previous messageGo to next message
thanks for your reply once again.
Oh, right!
so it will cover my tree while I edit just one node? that is peculiar! is
there a way to set the size of a TextCellEditor?
Re: TreeViewer inline editing [message #461022 is a reply to message #460999] Wed, 14 September 2005 15:39 Go to previous messageGo to next message
> Oh, right!
Not the whole tree, only the node being edited (and only the column
being edited unless it's the only column). Try it, and you'll see yourself.
Michal
Re: TreeViewer inline editing [message #461031 is a reply to message #461022] Wed, 14 September 2005 23:52 Go to previous messageGo to next message
Ok! thanks a lot - I'll try. By the way, I would really appreciate, if you
gave me a sample code, eh? It would be really nice of you.
> Peter Osipov napisa
Re: TreeViewer inline editing [message #466004 is a reply to message #461031] Wed, 28 December 2005 11:38 Go to previous message
If you still want an alternate solution, you might find Snippet 111 of some use:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet111.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
HTH,
Paul
Previous Topic:How can I get text selection events from the Browser widget?
Next Topic:MS Office 2003 task pane
Current Time: Fri Sep 19 04:38:32 EDT 2025
Powered by FUDForum. Page generated in 0.06188 seconds
