Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to layout OK & Cancel button like in Preference dialog
How to layout OK & Cancel button like in Preference dialog [message #465967] Tue, 27 December 2005 07:15 Go to next message
Hi all,
I need to layout OK and Cancel buttons just like in Preference dialog
where the buttons are aligned right with a separator above them. I manage
to align the buttons but I fail to make separator span the entire area.
Here's my code:
//The following methods is overidden from MessageDialog class
protected void createButtonsForButtonBar(Composite parent)
Label separator = new Label(parent,SWT.SEPARATOR | SWT.HORIZONTAL);
GridData data = new GridData(GridData.FILL_HORIZONTAL);
data.horizontalSpan = 2;
separator.setLayoutData(data);
super.createButtonsForButtonBar(parent);
Any help would be greatly appreciated.
Thanks in advanced.
Setya
Re: How to layout OK & Cancel button like in Preference dialog [message #465971 is a reply to message #465967] Tue, 27 December 2005 11:15 Go to previous messageGo to next message
the problem is that the parent composite itself does not span the width
of the dialog. the easiest way to get a separator to span the whole
dialog appears to be to add it at the bottom of the dialog area when you
override createDialogArea(Composite parent).
Re: How to layout OK & Cancel button like in Preference dialog [message #465979 is a reply to message #465971] Tue, 27 December 2005 21:28 Go to previous messageGo to next message
Thanks for the response,
> override createDialogArea(Composite parent).Thanks for the response,
I've tried your suggestions before and yes the separator can span the
whole dialog, but since the OK & Cancel buttons sit at the bottom of the
dialog the separator won't sit exactly above them.
I was wondering if someone can point me to the source of various dialogs
in Eclipse itself that have this kind of layout (new package dialog, new
interface dialog, etc).
Setya
Re: How to layout OK & Cancel button like in Preference dialog [message #465981 is a reply to message #465979] Tue, 27 December 2005 23:55 Go to previous messageGo to next message
in createDialogArea(Composite parent), did you add the separator
directly to parent?
ie:
public Control createDialogArea(Composite parent) {
Composite composite = (Composite) super.createDialogArea(parent);
composite.setLayoutData(new GridData(GridData.FILL_BOTH));
Label lbl = new Label(parent, SWT.SEPARATOR | SWT.HORIZONTAL);
lbl.setLayoutData(new GridData(GridData.HORIZONTAL_ALIGN_FILL));
return composite;
>> width of the dialog. the easiest way to get a separator to span the
>> whole dialog appears to be to add it at the bottom of the dialog area
>> when you override createDialogArea(Composite parent).Thanks for the
>> response,
> Regards,
> Setya
Re: How to layout OK & Cancel button like in Preference dialog [message #465988 is a reply to message #465981] Wed, 28 December 2005 04:11 Go to previous messageGo to next message
> directly to parent?
> ie:
> return composite;
Yes, the separator spans the whole dialog horizontally, but its vertical
distance with OK & Cancel buttons is too far.
Setya
Re: How to layout OK & Cancel button like in Preference dialog [message #466000 is a reply to message #465988] Wed, 28 December 2005 10:33 Go to previous messageGo to next message
interesting... this method is spacing them perfectly on GTK; please let
me know what system you're running so I make sure to fix my dialogs
before releasing there.
thanks!
>> directly to parent?
>> ie:
>> return composite;
> Regards,
> Setya
Re: How to layout OK & Cancel button like in Preference dialog [message #466021 is a reply to message #466000] Wed, 28 December 2005 21:27 Go to previous message
> thanks!
Eclipse 3.1.0, build:I20050627-1435 on WinXP
Setya
Previous Topic:SWT and Antialiasing
Next Topic:Can I change the row color in the property views?(IPropertySource)
Current Time: Tue Sep 16 10:18:09 EDT 2025
Powered by FUDForum. Page generated in 0.04792 seconds
