Home » Eclipse Projects » Standard Widget Toolkit (SWT) » FormLayout
FormLayout [message #465564] Thu, 15 December 2005 08:25 Go to next message
I'm facing some problem.
I have three composite in a composite.
The top and bottom composite are fixed sized in height.
The middle one may vary in size.
And the parent composite is resizable.
The problem is ;
when a parent composite is resized, the bottom composite comes to the area
of top composite.
I use "top composite" for the "top" form attachment of middle composite
and don't know what to put as the "bottom" attachment of the "bottom
composite".
The idea is like a window with title bar and status bar.
Re: FormLayout [message #465568 is a reply to message #465564] Thu, 15 December 2005 09:03 Go to previous messageGo to next message
As a bottom attachement use FormAttachement(100, 0) which means 100% of
parent composite and no margin so it will always go to the bottom of the
containing composite.
Stefan
Stephen wrote:
> I'm facing some problem. I have three composite in a composite.
> The problem is ;
> area of top composite.
> composite".
> Thanks
Re: FormLayout [message #465570 is a reply to message #465564] Thu, 15 December 2005 09:10 Go to previous messageGo to next message
Is this what you mean:
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new FormLayout());
Composite top = new Composite(shell, SWT.BORDER);
Composite middle = new Composite(shell, SWT.BORDER);
Composite bottom = new Composite(shell, SWT.BORDER);
FormData data = new FormData();
data.left = new FormAttachment(0, 5);
data.right = new FormAttachment(100, -5);
data.top = new FormAttachment(0, 5);
data.height = 200;
top.setLayoutData(data);
data.top = new FormAttachment(top, 5);
data.bottom = new FormAttachment(bottom, -5);
middle.setLayoutData(data);
data.bottom = new FormAttachment(100, -5);
data.height = 200;
bottom.setLayoutData(data);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Stephen" <swmk.stephen@gmail.com> wrote in message
news:4ad09448e9913f6983528fd4f44acf4d$1@www.eclipse.org...
> The problem is ;
> of top composite.
> composite".
> Thanks
Re: FormLayout [message #465579 is a reply to message #465564] Thu, 15 December 2005 09:28 Go to previous messageGo to next message
Originally posted by: wei.xie.lehman.com
Why don't use a gridlayout.
Re: FormLayout [message #465643 is a reply to message #465570] Thu, 15 December 2005 19:52 Go to previous messageGo to next message
Thank you for your reply.
I have tried in such way. There's no problem when the parent composite is
not resized. When the parent composite is rezied, the bottom composite
went to the under of top composite.
Thanks;
Stephen
Re: FormLayout [message #465656 is a reply to message #465643] Fri, 16 December 2005 05:03 Go to previous message
You should attach top of top composite to new FormAttachement(0,0);
Then attach middle to top new FormAttachement(top, margin);
Then attach bottom to middel composite new FormAttachement(middle, margin);
then attach bottom of bottom to bottom of parent compsoite new
FormAttachement(100,margin);
Do not attach bottom of top composite to middel composite and do not
attach bottom of middel composite to top of bottom composite.
At Last set a default size for all composites beyond which they cannot
be collapsed further.
Stefan
> is not resized. When the parent composite is rezied, the bottom
> composite went to the under of top composite.
> Thanks;
> Stephen
Previous Topic:KTable and Eclipse Forms
Next Topic:Setting context menu on editable CCombo
Current Time: Thu Sep 18 18:19:20 EDT 2025
Powered by FUDForum. Page generated in 0.06609 seconds
