Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [Drag and Drop] why are DragSourceEvent.{data, dataType} both null in dragFinished()?
[Drag and Drop] why are DragSourceEvent.{data, dataType} both null in dragFinished()? [message #465477] |
Wed, 14 December 2005 13:58  |
I have a Tree, with a DragSourceListener and a DropTargetListener, and I can drag and drop
(DROP_COPY) items within the tree, and everything works. Great!
Now I want to be able to have the user press some key (CTRL or SHIFT, maybe) and allow DROP_MOVE.
I've looked through this newsgroup, and repeatedly read both the articles:
http://www.eclipse.org/articles/Article-SWT-DND/DND-in-SWT.h tml
http://www.eclipse.org/articles/Article-Workbench-DND/drag_d rop.html
So, from those articles I learn that, in the DragSourceListener#dragFinished() method, "If a move
operation has been performed, remove the data from the source" -- see
http://www.eclipse.org/articles/Article-SWT-DND/DND-in-SWT.h tml#_ds29C ...
BUT when that method is called, both the event.data and the event.dataType are ALWAYS null. So how
am I supposed to tell what was dragged so as to be able to remove it? The example does not at all
answer the question, since it hardwires ONE drag source for all time -- not a very useable example,
for this question, since nearly all possible applications of a DragSourceListener will involve
multiple possible items as actual sources (e.g., in a Tree).
thanks,
Paul
Re: [Drag and Drop] why are DragSourceEvent.{data, dataType} both null in dragFinished()? [message #465544 is a reply to message #465477] |
Wed, 14 December 2005 20:11   |
Did you look at the setData(DragSourceEvent event) method? You can set your
drag data there.
Hope this helps
Chris
"Paul Keyser" <rolarenfan@earthlink.net> wrote in message
news:dnpq0v$ok2$1@news.eclipse.org...
>can drag and drop (DROP_COPY) items within the tree, and everything works.
>Great!
> maybe) and allow DROP_MOVE. I've looked through this newsgroup, and
> DragSourceListener#dragFinished() method, "If a move operation has been
> are ALWAYS null. So how am I supposed to tell what was dragged so as to be
> able to remove it? The example does not at all answer the question, since
> DragSourceListener will involve multiple possible items as actual sources
> (e.g., in a Tree).
> thanks,
> Paul
Current Time: Fri Jul 18 11:59:21 EDT 2025
Powered by FUDForum. Page generated in 0.03844 seconds
