Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How can i determine whether the UI thread has been created?
How can i determine whether the UI thread has been created? [message #465372] Sun, 11 December 2005 16:30 Go to next message
Originally posted by: wudong.liu.gmail.com
If the UI thread is created and running, i want to using the asyncExec()
to execute some code in it. If it's not, i have to create a new thread to
create the display.
but the problem is, how can i determine whether the UI thread is created
or not?
Re: How can i determine whether the UI thread has been created? [message #465374 is a reply to message #465372] Sun, 11 December 2005 19:54 Go to previous messageGo to next message
> create the display.
> or not?
try grab active shell or window and if it isn't null you are in UI thread
for example,
if (PlatformUI.getWorkbench().getActiveWorkbenchWindow() != null) {
// UI thread
Re: How can i determine whether the UI thread has been created? [message #465469 is a reply to message #465372] Wed, 14 December 2005 10:19 Go to previous message
If you know what threads exist (e.g. Thread.enumerate()), you could loop
over the threads and use Display.findDisplay(Thread) to determine if there
is a display for any of the threads.
"Wudong Liu" <wudong.liu@gmail.com> wrote in message
news:e25ffa023905baec8fbd7e1d98f80a6b$1@www.eclipse.org...
> create the display.
> or not?
Previous Topic:how to force ktable model to redraw
Next Topic:Potential bug in TableViewer with associated VIRTUAL table
Current Time: Mon Sep 01 00:04:31 EDT 2025
Powered by FUDForum. Page generated in 0.04932 seconds
