Home » Eclipse Projects » Standard Widget Toolkit (SWT) » problems in using SWT browser
problems in using SWT browser [message #465202] Wed, 07 December 2005 23:54 Go to next message
Originally posted by: sibinjosk.tataelxsi.co.in
Hi all,
I am using swt browser control to open a a htm page inside eclipse
IDE.
I have an embedded applet inside htm file which communicates with a
localhost webserver running in the same machine. When I tried to open the
htm page it is opening the page nd applet is also loading , but the applet
fails to communicate with the localhost server.
When I open the htm using Internet Explorer from the filesystem it is
working
properly. Is there any limitation for the embedded browser in eclipse, or
whether we have to set any security policies to make it work.
Also,I want to know how to get the details in the java console for the
swt browser. I am using 3.0 version of eclipse.
Thanks in advance for any help.
sibin
Re: problems in using SWT browser [message #465349 is a reply to message #465202] Fri, 09 December 2005 10:24 Go to previous messageGo to next message
Running an applet inside the embedded Browser is problematic. To run the
applet you need to launch a VM but there is already a VM running in this
process (the one running eclipse) and you can't have two VMs running in the
same process.
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=59506
https://bugs.eclipse.org/bugs/show_bug.cgi?id=92479
https://bugs.eclipse.org/bugs/show_bug.cgi?id=101740
"sibin jos" <sibinjosk@tataelxsi.co.in> wrote in message
news:56b82373338261dcdbb13be03b7a7588$1@www.eclipse.org...
> Hi all,
> IDE.
> working
> Also,I want to know how to get the details in the java console for the swt
> sibin
Re: problems in using SWT browser [message #465581 is a reply to message #465202] Thu, 15 December 2005 10:50 Go to previous message
A: Applets usually don't show up in the SWT Browser. On Windows
(Internet Explorer), the Java plugin fails to run a second Java virtual
machine to execute the applet because two Java virtual machines cannot
run in the same process. On Linux (Mozilla), the Java plug-in has been
reported to work because it executes in its own process. See bug 59506 .
http://www.eclipse.org/swt/faq.php#browserplugins
Best Regards,
Rogério
sibin jos wrote:
> Hi all,
> eclipse IDE.
> the htm page it is opening the page nd applet is also loading , but the
> applet fails to communicate with the localhost server.
> working
> or whether we have to set any security policies to make it work.
> sibin
Previous Topic:Problem running Snippet174 - OpenGL
Next Topic:Text Widget Width
Current Time: Sun Jul 27 07:56:15 EDT 2025
Powered by FUDForum. Page generated in 0.03915 seconds
