Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Redraw?
Redraw? [message #465122] Tue, 06 December 2005 07:37 Go to next message
I have one composite and i'll be adding new tab folder on the fly (e.g
when an action is performed). But for now, it's need to do something with
the parent, like resize or something. What will be solution NOT to do
like that? Like, as soon as a new tab folder is added, it will be appeared
in the composite. redraw() or something needed?
Re: Redraw? [message #465127 is a reply to message #465122] Tue, 06 December 2005 09:53 Go to previous message
Originally posted by: mwilli.iastate.edu
Is it a new tab folder or just a plain tab. If it's just a tab, they
should appear already. If it's the entire tab folder, look into layout()
and it's derivatives. I was having the same problem adding things like
that during runtime, but running layout() after the item has been added
will force the parent to "place" any items that just had a layout set on
them.
Hope this helps,
Mike
> with the parent, like resize or something. What will be solution NOT to
> do like that? Like, as soon as a new tab folder is added, it will be
> appeared in the composite. redraw() or something needed?
Previous Topic:Menu in Composite
Next Topic:Dynamic placement of composites on composites
Current Time: Sun Jul 27 11:34:27 EDT 2025
Powered by FUDForum. Page generated in 1.10400 seconds
