Home » Eclipse Projects » Rich Client Platform (RCP) » Recommendation for new developer
Recommendation for new developer [message #465087] Thu, 22 March 2007 14:06 Go to next message
Originally posted by: mmccaskill.healthdec.com
RCP is being considered for porting a current JFace/SWT application (which uses Spring,Hibernate,Derby). I want to know the more appropriate approach to package our various libraries/common code.
Our current structure in eclipse is broken into separate projects:
(Note I'm not using our real domain)
libs
- JARs in root, with substructure data,ws (webstart), web, swt{windows,osx,linux}, net.
domain
- has package com.comany.domain
commons
- has packages for com.company.
Would it be appropriate to make libs a plugin? (unzip jars?).
Re: Recommendation for new developer [message #465089 is a reply to message #465087] Thu, 22 March 2007 14:26 Go to previous messageGo to next message
Hi Michael,
I also use Hibernate/Derby on the client (and Hibernate/Postgres on the
server side). I've found the following structure to work well:
I use three separate copies of Eclipse IDE:
1) Client (3.3M5 for plugin development)
2) Common (3.3M5 for java project development)
3) Server (JBoss IDE 2.0 Beta for EJB3 development)
The Common IDE has several java projects that are shared by Client and
Server. Each project has its own build.xml.
Within Common, I also use a "Master" build.xml in a separate project
that calls the individual build.xml files and then transports the
resulting jar file to folders on the server and client sides.
Within the Client IDE I have a project that contains jar files for
Hibernate, Derby, other external libraries, and the jar files generated
by the Common Master build. I use the "create new project from existing
jar files" Wizard to create a new plugin project from these jars. I use
"Eclipse-Buddy-Policy: registered" within the generated plugin.
Hope this helps.
Charlie
> libs
> domain
> commons
Re: Recommendation for new development [message #465091 is a reply to message #465087] Thu, 22 March 2007 14:50 Go to previous messageGo to next message
Separate plugins for each Jar is recommended, since you'll then be able to update them individually if that's what you wanted.
As for your commons, you could have them as a single or three plugins if that's what's needed. I'd recommend separate ones, if only because stuff that's in commons.web is likelyt o have a different set of dependencies than commons.util.
Alex.
Re: Recommendation for new development [message #465093 is a reply to message #465091] Thu, 22 March 2007 15:49 Go to previous messageGo to next message
Would it really be reasonable to create a plugin for all 100+ JARs in my libs project?
Re: Recommendation for new developer [message #465095 is a reply to message #465087] Thu, 22 March 2007 16:08 Go to previous messageGo to next message
> libs
> domain
> commons
That would be my strategy. Appearantly your company has already decided
how it wants to partition its code. libraries are changeable and
upgradeable units and you will get that with plugins. Dependencies will
take a bit of learning, but you can do it all.
Re: Recommendation for new development [message #465097 is a reply to message #465093] Thu, 22 March 2007 16:10 Go to previous messageGo to next message
Thats a question for your company. If there is a valid reason for them to
be seperate jars now, then likely that same reason will hold as to why
they will be seperate plugins. But not necessarily.
I have some multi jar plugins. the seperate jars just help me maintain
proper dependency seperation in places, but i still will upgrade those
jars as a unit. I find seperate jars to be my preferred way over simply
seperate packages.
Re: Recommendation for new development [message #465101 is a reply to message #465087] Thu, 22 March 2007 17:13 Go to previous messageGo to next message
Well crap. I can't separate commons.util and commons.data since there is a circular dependency.
Re: Recommendation for new development [message #465106 is a reply to message #465101] Thu, 22 March 2007 18:58 Go to previous messageGo to next message
This is one of the reasons to use separate bundles :-) If you do, such circular dependencies can't creep in.
Alex.
Re: Recommendation for new development [message #465108 is a reply to message #465093] Thu, 22 March 2007 19:00 Go to previous messageGo to next message
I really would advise against having a single bundle with 100+ jars in them. You'll be permanently updating that bundle as and when new jars are created if you do.
Alex.
Re: Recommendation for new development [message #465146 is a reply to message #465097] Fri, 23 March 2007 08:59 Go to previous message
The only reason they are separated is because it makes sense. But ultimately, each project copies what JARs it requires into its build directory upon creating a WAR, etc.
Thanks for all the help.
Previous Topic:Text based DialogCellEditor does not allow paste
Next Topic:com.sun.jdi.ClassNotLoadedException: Type not loaded
Current Time: Wed Sep 03 21:34:06 EDT 2025
Powered by FUDForum. Page generated in 0.05983 seconds
