Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED!
Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #464976] Fri, 02 December 2005 08:08 Go to next message
Originally posted by: preetamp.aftek.com
Hi All,
I have a tabletreeviewer with SWT.CHECK style
This tree looks good on win 2k but looks improper in fedora core 3
I means on fedora the nodes at verious levels of tree should get indented to
right. The tree hirarchy should get clear.
I m attaching the sample pic.
See that node1 has child node2 which has also a child node3
The relation between node1 and node2 does not get seen properly wheare as
the relation between node2 and node3 is clear deu to indentation !
Any clue ?
~Preetam
  • Attachment: tree.jpg
    (Size: 7.90KB, Downloaded 194 times)
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #464992 is a reply to message #464976] Fri, 02 December 2005 10:37 Go to previous messageGo to next message
tabletree is apparently deprecated for issues such as this (lots of
discussions earlier in this newsgroup on it)
your best bet is to switch to a Tree with TreeColumns - the good news is
that it's "almost" a drop-in replacement :)
Preetam wrote:
> Hi All,
> Any clue ?
> Thanks
> ~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465069 is a reply to message #464992] Mon, 05 December 2005 06:45 Go to previous messageGo to next message
But I am using TableTreeViewer to build tree
how can I get Tree from it ?
I can get only TableTree and TableTreeItem
Can somebody give me a sample code for the same ?
~Preetam
"Jeremy Dowdall" <dev@myriadfinancial.com> wrote in message
news:dmppo1$pjp$1@news.eclipse.org...
> Preetam wrote:
> > Hi All,
indented to
as
> > Any clue ?
> > Thanks
> > ~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465075 is a reply to message #465069] Mon, 05 December 2005 09:49 Go to previous messageGo to next message
Thanks !
I managed that with treeviewer !
Thanks again !
~Preetam
"Preetam" <preetamp@aftek.com> wrote in message
news:dn1997$rm1$1@news.eclipse.org...
> Thanks
> ~Preetam
> > Preetam wrote:
> > > Hi All,
> indented to
> as
> > > Any clue ?
> > > Thanks
> > > ~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465077 is a reply to message #465069] Mon, 05 December 2005 09:55 Go to previous messageGo to next message
my bad, you'd need to use the TreeViewer rather than the TableTreeViewer:
TreeViewer viewer = new TreeViewer(parent, style);
Tree tree = viewer.getTree();
TreeColumn column0 = new TreeColumn(tree, SWT.LEFT);
column0.setText("col 0");
column0.setMoveable(true);
column0.pack();
TreeColumn column1 = new TreeColumn(tree, SWT.RIGHT);
column1.setText("col 1");
column1.setMoveable(true);
column1.pack();
your content providers shouldn't need to change:
viewer.setContentProvider( ITreeContentProvider );
viewer.setLabelProvider( ITableLabelProvider );
> Thanks
> ~Preetam
>>Preetam wrote:
>>>Hi All,
> indented to
> as
>>>Any clue ?
>>>Thanks
>>>~Preetam
Re: Problem with TableTreeViewer with SWT.CHECK on FEDORA CORE 3 -- HELP NEEDED! [message #465079 is a reply to message #465075] Mon, 05 December 2005 09:56 Go to previous message
oops - should've refreshed before sending... oh well, glad you got it!
Preetam wrote:
> Thanks !
> Thanks again !
> ~Preetam
>>Thanks
>>~Preetam
>>>Preetam wrote:
>>>>Hi All,
>>indented to
>>as
>>>>Any clue ?
>>>>Thanks
>>>>~Preetam
Previous Topic:Centering a Dialog on Screen
Next Topic:Problem with StatusLineManager
Current Time: Sat Jul 26 11:25:48 EDT 2025
Powered by FUDForum. Page generated in 0.07926 seconds
