Home » Language IDEs » C / C++ IDE (CDT) » Build Command
Build Command [message #46223] Tue, 22 October 2002 06:05 Go to next message
Originally posted by: csheen.iii.org.tw
hi...
I want to new a C project by my button in toolbar. I write
..project as same as C project.
ex.
<buildCommand>
<name>org.eclipse.cdt.core.cbuilder</name>
<arguments>
</arguments>
</buildCommand>
But i can't set Build Command to "make -f makefile". How can i set
it?
I don't want user to set it by himself.It's default value is "Use
Default".
I just know that if i don't read
<nature>org.eclipse.cdt.core.cnature</nature> in .project.
"C/C++ project" setting will not appear in the properties of my
project.
Re: Build Command [message #46495 is a reply to message #46223] Wed, 23 October 2002 02:23 Go to previous messageGo to next message
Hi!
May be I didn't quite fully understand your problem but try to do
following:
Open org.eclipse.cdt.core/plugin.xml and find there following strings
<extension
point="org.eclipse.cdt.core.CBuildCommand">
<buildcommand
command="make">
</buildcommand>
</extension>
Change value of variable 'command' and new value will appear in Eclipse
as a default value instead of make.
Hope it helps,
Igor S. Zamyatin
Interstron Ltd.
email: isz@interstron.ru
tel: +7 (095) 269-4713
cell: +7 (902) 659-5838
www: http://www.interstron.ru
Chiang Shen wrote:
> hi...
> ex.
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> it?
> Default".
> project.
Re: Build Command [message #46522 is a reply to message #46495] Wed, 23 October 2002 04:50 Go to previous messageGo to next message
Sorry...My English is poor.
Thx Zamyatin's help.
I try to change value of variable 'command'.
First, value of variable 'command' is 'make".
When i rebuild my project,i see the result in C-Build. The command is
"make -k"
Second, i change value of variable 'command' to 'make -f makefile".
"make -f makefile -k"
How to make '-k' disappear?
>"Igor S. Zamyatin" <isz@interstron.ru>
> Hi!
>following:
> <extension
> <buildcommand
> command="make">
> </buildcommand>
> </extension>
Re: Build Command [message #46550 is a reply to message #46522] Wed, 23 October 2002 06:24 Go to previous messageGo to next message
Take a look at org.eclipse.cdt.internal.core.CBuilder.
There is function parseArguments and there you can find following strings
if (nature.isDefaultBuildCmd()) {
if(!nature.isStopOnError()) {
list.add("-k");
Here '-k' adds. Comment it or change it and that's all
Igor S. Zamyatin
Interstron Ltd.
> "make -k"
> > Hi!
> >following:
> > <extension
> > <buildcommand
> > command="make">
> > </buildcommand>
> > </extension>
Re: Build Command [message #46976 is a reply to message #46550] Thu, 24 October 2002 05:49 Go to previous messageGo to next message
Thx....
I know.It means that i need to edit source code of CDT.
But i don't want to do it. Because if i do it,i can't release my
plug-in to others.
My plug-in can create a project base on C project.
When it is be created,I will put some special files in this project.
The user can use my project to design some programs.
How to make "-k" disapear if i don't edit CDT's source code?
And i don't know why it adds "-k" in this function.
Because "-k" is not a parameter of make.I can't find any make.exe
that has parameter "-k".
> list.add("-k");
>Igor S. Zamyatin
> Interstron Ltd.
Re: Build Command [message #47004 is a reply to message #46976] Thu, 24 October 2002 05:51 Go to previous messageGo to next message
As I understood option "-k" adds if user chooses "Keep going on error"
option in project's properties dialog. If he chooses "Stop on error" no
option is adding.
Igor S. Zamyatin
> Thx....
> plug-in to others.
> > list.add("-k");
> >Igor S. Zamyatin
> > Interstron Ltd.
Re: Build Command [message #48408 is a reply to message #47004] Thu, 31 October 2002 22:39 Go to previous messageGo to next message
I just new a c project,it's default value is "make".
But it's default build command is "make -k".
I just want the command is "make" not "make -k".
How to do it??
>"Igor S. Zamyatin" <isz@interstron.ru> >
>option is adding.
> Igor S. Zamyatin
Re: Build Command [message #48593 is a reply to message #48408] Sat, 02 November 2002 20:54 Go to previous message
Hi Chiang,
Currently make -k is our default and it cannot be changed (unless there has
been a change in the code in the last week) Thins move fast around here.
We have had several people request a change in this and we are looking into
it.
-Judy
"Chiang Shen" <csheen@iii.org.tw> wrote in message
news:apsr72$b9a$1@rogue.oti.com...
> How to do it??
> >option is adding.
> > Igor S. Zamyatin
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.410 / Virus Database: 231 - Release Date: 10/31/02
Previous Topic:How to find if a project is a C/C++ project
Next Topic:Feature request - build on save
Current Time: Tue Nov 04 21:19:30 EST 2025
Powered by FUDForum. Page generated in 0.21431 seconds
