Home » Eclipse Projects » Standard Widget Toolkit (SWT) » New data binding framework
New data binding framework [message #464653] Sun, 27 November 2005 22:00 Go to next message
All,
Some of you know that JFace and VE have been working together on a new
data binding framework for Eclipse. In many cases, this will let you
replace pages of SWT event handlers with code like:
dataBinding.bind(textWidget, new Property(personBean, "name"), null);
There are two talks proposed about this new exciting framework at
EclipseCon:
http://canuck.gda.itesm.mx/eclipsezilla/show_bug.cgi?id=271
by myself, and
http://canuck.gda.itesm.mx/eclipsezilla/show_bug.cgi?id=89
by Boris Bokowski, a member of the JFace team
If you want to hear about this at EclipseCon, please vote today for one
or more of these submissions!
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Re: New data binding framework [message #464663 is a reply to message #464653] Mon, 28 November 2005 08:33 Go to previous messageGo to next message
We want to know when it will be ready and stabilized. :-)
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: New data binding framework [message #464700 is a reply to message #464663] Mon, 28 November 2005 18:15 Go to previous messageGo to next message
>> one or more of these submissions!
By what definition of "ready" and "stabilized"?
Officially, API freeze is scheduled for February, or before EclipseCon.
(So please vote for Boris's and my talks.)
But if you want to know if the library is ready to use, I'm using it
right now on a large-scale project, so for me it's "ready". But it's
not stabilized yet as in we're still making occasional API changes.
Most of those changes are very insigificant now. We occasionally find
additions we need to make, and this can force a refactoring.
So the question is really "how big is your project?" and "how long-term
is your investment?" If you've got a large project or a long-term
investment, I wouldn't hesitate to get involved today. Growing with a
project is the best way to really learn it backwards and forwards. And
the Eclipse data binding framework will be the standard data binding
framework for SWT for years to come, so your investment will pay
dividends for years to come.
Dave Orme
Re: New data binding framework [message #464704 is a reply to message #464700] Mon, 28 November 2005 19:16 Go to previous messageGo to next message
David,
Is there any tutorial, getting start or like document
for start
I import plugins and start tests (there are failed tests in 3.1.1)
> Best regards,
> Dave Orme
Re: New data binding framework [message #464715 is a reply to message #464704] Mon, 28 November 2005 23:35 Go to previous messageGo to next message
Haris Peco wrote:
> David,
> for start
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-ui-home/databinding-proposal/databinding.html
In addition, the code in the
org.eclipse.jface.examples.binding.scenarios
plug-in contains pretty much one example per use-case we've thought of.
This can help you get started since these examples are each pretty
simple. If you can think of scenarios we haven't thought of that can't
be handled easily, please file bug reports.
And when you file bug reports, please put "[DataBinding]" at the
beginning of your summary so we can find them easily. Thanks much in
advance!
If any tests fail for you, please file bug reports with as much
information as possible about the failure. We try to keep the test
cases clean as we develop.
Dave Orme
Re: New data binding framework [message #464739 is a reply to message #464715] Tue, 29 November 2005 08:26 Go to previous messageGo to next message
> Haris Peco wrote:
>> David,
>> for start
How i can start any examples ?
I read proposal, but i don't know start
i test yet - i use eclipse 3.1.1 and it is reason, maybe
Re: New data binding framework [message #464791 is a reply to message #464739] Tue, 29 November 2005 18:14 Go to previous messageGo to next message
Hello Haris,
>> Haris Peco wrote:
>>> David,
>>> for start
>> of. This can help you get started since these examples are each
>> pretty simple. If you can think of scenarios we haven't thought of
>> that can't be handled easily, please file bug reports.
> Thanks
How can I get and install this plug-in?
Thank you for answer
Grzegorz Zieliński
g_zielinski<at>intechion.pl
Re: New data binding framework [message #464793 is a reply to message #464791] Tue, 29 November 2005 20:09 Go to previous messageGo to next message
Grzegorz,
I do next :
download from cvs plugins :
org.eclipse.jface.databinding
org.eclipse.jface.tests.databinding
org.eclipse.jface.examples.databinding
you can do direct from eclipse (i use command line cvs in linux)
cvs -d :pserver:anonymous@dev.eclipse.org:/home/eclipse login
password is ENTER (no password for anonymous)
and
cvs -d :pserver:anonymous@dev.eclipse.org:/home/eclipse co \
and same others
import 3 projects in eclipse and it is all
you can search, export, checkout again etc
regards
> Grzegorz Zieliński
Re: New data binding framework [message #464801 is a reply to message #464793] Tue, 29 November 2005 20:27 Go to previous messageGo to next message
Hello Haris,
> Grzegorz,
> I do next :
> and
> and same others
> regards
>> Grzegorz Zieliński
Thank you! :) I'll try it.
Grzegorz Zieliński
Re: New data binding framework [message #464803 is a reply to message #464801] Tue, 29 November 2005 21:59 Go to previous message
This should work. Alternatively, you could download a recent nightly
build and just grab the JAR files out of the plugins directory.
If you try it and have problems, please post questions to the RCP
newsgroup and bug reports to Platform/UI with a subject line starting
with [DataBinding].
Dave Orme
Grzegorz Zieliński wrote:
> Hello Haris,
>> Grzegorz,
>> I do next :
>> and
>> and same others
>> regards
>>> Grzegorz Zieliński
> Grzegorz Zieliński
Previous Topic:BadGC in AIX Motif
Next Topic:SWT Browser and sessions
Current Time: Fri Jul 25 22:11:52 EDT 2025
Powered by FUDForum. Page generated in 0.67289 seconds
