Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Table Column Width
Table Column Width [message #464580] Fri, 25 November 2005 07:13 Go to next message
is there a way that the columns of a table are automatically resized
depending on the text that is in it's cells.
At the moment i use the work around to determine the average character
width from a GC and multiply it with the maximum number of characters in
this column, which i think is very messy (especially because it's only the
average character width, so i have to add at least 1 or 2 pixels per
character so that the column is really big enough)
Martin
Re: Table Column Width [message #464584 is a reply to message #464580] Fri, 25 November 2005 09:24 Go to previous messageGo to next message
TableColumn.pack() will size the column to be as wide as its widest item.
It is not "automatic" in that you have to call it each time you change the
text or image for a TableItem.
"Martin" <xx@xx.com> wrote in message
news:45ad0f30aa23f90ce161d177632a7834$1@www.eclipse.org...
> depending on the text that is in it's cells. At the moment i use the work
> around to determine the average character width from a GC and multiply it
> with the maximum number of characters in this column, which i think is
> very messy (especially because it's only the average character width, so i
> have to add at least 1 or 2 pixels per character so that the column is
> really big enough)
> Thanks
> Martin
Re: Table Column Width [message #464665 is a reply to message #464584] Mon, 28 November 2005 08:40 Go to previous messageGo to next message
Originally posted by: e.s.com
is there some way to "tell" the table to resize itself to fit the text
size or to adjust according to its parent composite?
Re: Table Column Width [message #464670 is a reply to message #464665] Mon, 28 November 2005 10:20 Go to previous messageGo to next message
Call TableColumn.pack() on each of the columns and then call
table.getShell().layout(new Control[] {table});
"Erel" <e@s.com> wrote in message
news:cb2d03eb4d6fc749f8a20fd9f43b503e$1@www.eclipse.org...
Re: Table Column Width [message #464873 is a reply to message #464584] Wed, 30 November 2005 15:27 Go to previous messageGo to next message
Veronika,
Is pack() supposed to work like this for tree columns as well?
When I call pack() it only sizes to the top level items, not the
indented / child ones. this is happening for all columns.
I'm on Linux/GTK if that matters.
thanks!
>>Hi,
>>really big enough)
>>Thanks
>>Martin
Re: Table Column Width [message #464875 is a reply to message #464584] Wed, 30 November 2005 15:51 Go to previous messageGo to next message
I could be way off, but what the heck! :)
in TreeColumn's Pack routine:
int /*long*/ iter = OS.g_malloc (OS.GtkTreeIter_sizeof ());
if (OS.gtk_tree_model_get_iter_first (parent.modelHandle, iter)) {
do {
width = Math.max (width, parent.calculateWidth (handle, iter));
} while (OS.gtk_tree_model_iter_next(parent.modelHandle, iter));
OS.g_free (iter);
seems that it needs to tunnel down through all the children here, as
it's currently just getting the direct children of the parent tree
>>Hi,
>>really big enough)
>>Thanks
>>Martin
Re: Table Column Width [message #464945 is a reply to message #464875] Thu, 01 December 2005 11:14 Go to previous messageGo to next message
We have had some discussion in the past on our team about this.
The problem is that if you have a TreeItem with subitems with subitems with
subitems with subitem with subitems ..
For each subitem there is some indentation. When you pack the column, if
you include all children (expanded or not) the column could become very wide
just to accomodate this indententation for sublevels even though the
unexpanded children are not visible.
Personally I think pack on a TreeColumn should make the column as wide as
the widest expanded child. I have entered the following bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=118844
"Jeremy Dowdall" <dev@myriadfinancial.com> wrote in message
news:dml3bk$qea$1@news.eclipse.org...
> do {
> OS.g_free (iter);
> seems that it needs to tunnel down through all the children here, as it's
Re: Table Column Width [message #464951 is a reply to message #464945] Thu, 01 December 2005 12:17 Go to previous message
thanks Veronika, I definitely agree that it doesn't make sense to size
the non-expanded (and thus non-visible) items! :)
any suggestions as to a short term work-around? It doesn't seem that I
can access any size info on a per column per item basis...
>> do {
>>OS.g_free (iter);
Previous Topic:finding the base directory for RCP app
Next Topic:Non-embedded ActiveX application automation
Current Time: Mon Jul 21 09:09:06 EDT 2025
Powered by FUDForum. Page generated in 0.30018 seconds
