Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to connect model to GUI using JFace?
How to connect model to GUI using JFace? [message #464652] Sun, 27 November 2005 19:34 Go to next message
Hi.
I have some model class, eg.
public class Contact() {
private String lastName;
private String firstName;
public String getLastName() {
return lastName;
public String setLastName(String newName) {
lastName = newName;
How to connect it to the GUI using JFace?
I know I'll have to create interface, add listener registration to Contact()
class,
create content provider class, and use/create some viewer class.
The problem is: how to use TextViewer class? How to actually create text
boxes
on canvas and connect them to the model?
Thank you for quick answer.
Grzegorz Zieliński
g_zielinski<at>intechion.pl
Re: How to connect model to GUI using JFace? [message #464657 is a reply to message #464652] Mon, 28 November 2005 03:15 Go to previous messageGo to next message
You might want to take a look at the "Sweet" framework:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104570
Grzegorz Zieliński kirjutas mulle ühel talvisel päeval midagi seesugust:
> Hi.
> return lastName;
> lastName = newName;
> Contact() class, create content provider class, and use/create some
> viewer class.
> boxes on canvas and connect them to the model?
> Grzegorz Zieliński
Roland Tepp
Re: How to connect model to GUI using JFace? [message #464658 is a reply to message #464657] Mon, 28 November 2005 03:17 Go to previous messageGo to next message
Even better documentation could be found at
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-ui-home/databinding-proposal/databinding.html
Roland Tepp kirjutas mulle ühel talvisel päeval midagi seesugust:
>> Hi.
>> return lastName;
>> lastName = newName;
>> viewer class.
>> text boxes on canvas and connect them to the model?
>> Grzegorz Zieliński
Roland Tepp
Re: How to connect model to GUI using JFace? [message #464659 is a reply to message #464658] Mon, 28 November 2005 06:43 Go to previous messageGo to next message
Hello Roland,
> me/ databinding-proposal/databinding.html
> Roland Tepp kirjutas mulle ühel talvisel päeval midagi seesugus t:
>> https://bugs.eclipse.org/bugs/show bug.cgi?id=104570
Thank you, this looks great. There is only one problem: if I understand right,
it's still under development and still not implemented. And I have to solve
the problem right now.
Does anybody have example how to use TextViewer?
Grzegorz Zieliński
Re: How to connect model to GUI using JFace? [message #464916 is a reply to message #464659] Thu, 01 December 2005 06:45 Go to previous message
Oh, but it *is* implemented!
It isn't publicly released yet - yes, but the implementation should be
mostly there.
All you need to do is to check it out from CVS and start using it...
... and if there is something that You need that is not present ... well
that's why it is an OpenSource project ;)
> Hello Roland,
> right,
> solve the problem right now.
> Grzegorz Zieliński
Roland Tepp
Previous Topic:changing FormColors
Next Topic:ViewForm Troubles
Current Time: Sat Jul 19 02:04:50 EDT 2025
Powered by FUDForum. Page generated in 0.04799 seconds
