Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Shell Hide On Close
Shell Hide On Close [message #464270] Sat, 19 November 2005 14:06 Go to next message
Originally posted by: simon.guertin.usherbrooke.ca
Hi there, I am using the Tray and I want to minimize my Main Shell on
the Close button click of the Main Shell. I added a Shell Adapter and
catched the Shell Closed Event and I set the Doit to false and I then
set my shell to shell.SetVisible(false);
I only want to be able to click my application but using the Tray
rightclick/quit action.
Is this the clean way to do it?
I also need my application not to block a windows shutdown process. What
is the event that SWT receives when windows is shuting down? I had this
prblem when I was implementing a similar application in Borland C++ so I
had to allow the shutdown of the application when it was a close event
on shutdown.
thanks
Simon
Re: Shell Hide On Close [message #464292 is a reply to message #464270] Sun, 20 November 2005 14:42 Go to previous messageGo to next message
hi,
"Simon Guertin" <simon.guertin@usherbrooke.ca wrote:
> Hi there, I am using the Tray and I want to minimize my Main Shell on the
> Close button click of the Main Shell. I added a Shell Adapter and catched
> the Shell Closed Event and I set the Doit to false and I then set my shell
> had to allow the shutdown of the application when it was a close event on
> shutdown.
maybe this link helps you to solve the problem:
http://lokeshshah.com/blog/?p=93
hth
Joachim
Re: Shell Hide On Close [message #464356 is a reply to message #464292] Mon, 21 November 2005 20:10 Go to previous message
Thanks for the hint but I think I will stick with my solution. It looks
to work fine.
Joachim Schreibmaier wrote:
> hi,
>>shutdown.
> hth
Previous Topic:[MenuItem] - Text Color
Next Topic:SWT : Button & Image
Current Time: Sat Jul 26 11:52:27 EDT 2025
Powered by FUDForum. Page generated in 0.03967 seconds
