Re: PlatformUI [message #464281] |
Thu, 01 March 2007 09:24 |
Hi Kakan,
Are you calling getWorkbench() very early, or very late, in your program?
These are the times when the workbench might not be available (for
example in startup code).
Charlie
Hakan GONEN wrote:
> I know that The PlatformUI.getWorkbench() is returned null.
> But it is work in each other views class
> "Charlie Kelly" <Eclipse@CharlieKelly.com>, haber iletisinde şunları
> yazdı:<es4htp$67t$1@utils.eclipse.org>...
>> Hi Cenk,
>> You might separate the statement between each of the ".", and
>> assign to separate variables. Then you can determine which function
>> is returning null.
>> Charlie
>> Cenk Dundar wrote:
>>> Hi;
>>> I created normally class. And I want to get a ViewPart that in my
>>> application this like
>>> public class DisplayCycle {
>>> public DisplayCycle(){
>>> public void toDo(){
>>> ReadDataView readDataView =
(ReadDataView)PlatformUI.getWorkbench().getActiveWorkbenchWi ndow().getActive
> Page().findView(ConstID.READ_VIEW_ID);
>>> But I cant get it. The application throws a NullPointer exeception
>>> What is the problem?
FUDForum. Page generated in 0.03549 seconds
