Home » Eclipse Projects » Rich Client Platform (RCP) » [CommonNavigator] Bind doubleClick to ViewItemDelegate
[CommonNavigator] Bind doubleClick to ViewItemDelegate [message #463372] Fri, 09 February 2007 05:11 Go to next message
I can bind doubleClick to an open action in ActionProvider by
calling actionBars.setGlobalActionHandler(id, action) in method
fillActionBars(). Now I have implemented the open action as an
IViewActionDelegate because it must know the selection. How can
I bind double-click to the IViewActionDelegate or to the action
referring it? Thanks for your advice.
Gruesse/Regards,
Peter Maas, Aachen
E-mail "cC5tYWFzQG1hZ21hc29mdC5kZQ==\n".decode("base64")
Find IObjectActionDelegates of contextmenu ([CommonNavigator] Bind doubleClick to ViewItemDelegate) [message #463678 is a reply to message #463372] Wed, 14 February 2007 10:04 Go to previous messageGo to next message
> IViewActionDelegate because it must know the selection [...]
The open action is now provided by ActionProvider again and
implements ISelectionChangedListener. But I have still the
problem to find the objectContribution actiondelegates of the
same context menu which is holding the open action . I tried
to grab them via extension registry but this gives me new
instances which does not work as desired. Thanks for your help.
Gruesse/Regards,
Peter Maas, Aachen
Re: Find IObjectActionDelegates of contextmenu ([CommonNavigator] Bind doubleClick to ViewItemDelega [message #463715 is a reply to message #463678] Wed, 14 February 2007 14:43 Go to previous messageGo to next message
And that won't work in 3.3 anyway ... the XML is still valid, but the
guys that hold onto the I*ActionDelegates will be completely different.
Later,
PW
Re: Find IObjectActionDelegates of contextmenu ([CommonNavigator] Bind doubleClick to ViewItemDelega [message #463733 is a reply to message #463715] Thu, 15 February 2007 02:59 Go to previous messageGo to next message
Guys? Do you mean the classes or the guys who made them? :)
Gruesse/Regards,
Peter Maas, Aachen
Re: Find IObjectActionDelegates of contextmenu ([CommonNavigator] Bind doubleClick to ViewItemDelega [message #463773 is a reply to message #463733] Thu, 15 February 2007 08:38 Go to previous messageGo to next message
The guys who made them are always different :-)
I mean the class that proxies an IActionDelegate, so it can be displayed
before it is instantiated (to delay plugin loading).
Later,
PW
Re: Find IObjectActionDelegates of contextmenu [message #463938 is a reply to message #463678] Tue, 20 February 2007 12:08 Go to previous message
This works now.
These problems were not related to the solution.
Gruesse/Regards,
Peter Maas, Aachen
Previous Topic:Problem with communication between Views over Selection Mechanism
Next Topic:Views vs Editors
Current Time: Sun Jul 20 22:37:17 EDT 2025
Powered by FUDForum. Page generated in 0.05564 seconds
