Home » Modeling » EMF » org.xml.sax.SAXParseException: Content is not allowed in prolog / Custom ResourceImpl / case sensiti
org.xml.sax.SAXParseException: Content is not allowed in prolog / Custom ResourceImpl / case sensiti [message #463055] Sun, 02 August 2009 11:33 Go to next message
So I'm posting this question mostly to document my issue (in case anyone
runs into the same problem, and is searching the newsgroup). My
question is about file extension case-sensitivity, and may be better
suited for a more "general" newsgroup (not EMF specific). Explanation to
follow.
Yesterday I wasted a few hours tracking down an issue because of an
oversight (and I was looking in all the wrong places). I've been
working on an RCP app (based on EMF) that registers it's own Resource
Type by implementing doLoad() / doSave() in xxxxResourceImpl and by
using the extension point org.eclipse.emf.ecore.extension_parser to
register the extension .esx with my app.
I had been doing some initial testing w/ some of my .esx files, and
things seemed to be going okay until I loaded one, and kept getting the
following error "org.xml.sax.SAXParseException: Content is not allowed
in prolog.":
(Part of my stack trace):
org.xml.sax.SAXParseException: Content is not allowed in prolog.
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at
com.example.plugins.model.esx.presentation.EsxEditor.createM odel(EsxEditor.java:848)
at
com.example.plugins.model.esx.presentation.EsxEditor.createP ages(EsxEditor.java:905)
I could not figure out why demandLoad()/load() was always returning an
XMLResourceImpl for this specific file. I laced the code with
breakpoints, and was convinced it was due to a character in the file
(like a 0x00 or a BOM sequence). Eventually I realized it was due to
the capitalization of the file in question (which was test.ESX rather
than test.esx), that caused the program to ignore my EsxResourceImpl,
and use a "default" XMLResourceImpl.
Is there a way to register a case insensitive extension with
org.eclipse.emf.ecore.extension_parser, or do I have to register 8
versions of my 3 character extension (ie. esx, esX,eSx, eSX, etc...)?
Re: org.xml.sax.SAXParseException: Content is not allowed in prolog / Custom ResourceImpl / case sen [message #463807 is a reply to message #463055] Sun, 02 August 2009 13:48 Go to previous messageGo to next message
Jeff,
Keep in mind that only Windows is case insensitive so yes, you'd have to
register explicitly all the combinations you'd want to support.
> anyone runs into the same problem, and is searching the newsgroup).
> My question is about file extension case-sensitivity, and may be
> better suited for a more "general" newsgroup (not EMF specific).
> Explanation to follow.
> the following error "org.xml.sax.SAXParseException: Content is not
> allowed in prolog.":
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: org.xml.sax.SAXParseException: Content is not allowed in prolog / Custom ResourceImpl / case sen [message #465821 is a reply to message #463807] Sun, 02 August 2009 18:47 Go to previous message
It's even worse because when doing Eclipse Development on win32 and
running e.g. under PDE then everthing works fine until you export it as
a .jar because then everything is case-sensistive :-)
Tom
Ed Merks schrieb:
> Jeff,
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Re: Duplicate case error in generated model
Next Topic:[CDO] TimeoutException on session refresh
Current Time: Fri Jul 25 22:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.05446 seconds
